Old 03-20-2017, 18:50   #1 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,645
Talking N920a read code done latest build aq1
UNLOCK INSTRUCTIONS:
To unlock NEW security type:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
To unlock OLD security type:
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button and select 'Unlock' for direct unlock.
To read security codes (all security types):
4. Press 'Read codes' button to read security codes.
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
To reset Google account activation or Samsung reactivation lock:
1. Power on phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
Operation: Read Codes
Selected model: SM-N920A
Software version: 27.8
Searching Samsung modem... detected COM209
Reading phone info... Ok
Model: SM-N920A
AP version: N920AUCS4CQA1
CSC version: N920AATT4CQA1
CP version: XXXXXXXXXXXXXX
Product code: SM2N920AZWEATT
Phone SN: R38G907RYBX
Unique number: 05157DF5DA99A211
Reading IMEI... Ok
IMEI: 353877075485601 (SIGN: OK)
Checking hash file... Ok
Reading data from phone... Ok
Modem board: SHANNON333
HWID: 48 89 56 CF B6 05 00 00 00 00 00 00 00 00 00 00
Reading NV data... Ok
Checking NV data... Ok
Calculating... Ok
Please wait, calculating codes... OK (time - 00:00:04)
Freeze code: 52963729
NET lock: 41316191
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.27.8
The Following 2 Users Say Thank You to ghacks For This Useful Post:
Old 03-26-2017, 19:11   #2 (permalink)
Member: 2058197
Thanks Meter: 32
did you downgrade the modem?
Old 03-26-2017, 19:22   #3 (permalink)
Member: 2202707
Sonork: whatsapp +59170073722
Thanks Meter: 212
combination N920AUCU4APL1
The Following 2 Users Say Thank You to tomelich For This Useful Post:
Old 08-23-2017, 20:21   #4 (permalink)
Member: 819163
Thanks Meter: 45
Working perfectly. Even on 7.0
Old 08-24-2017, 18:43   #5 (permalink)
georgeodoom's Avatar
Member: 2296236
Thanks Meter: 143
How bro
Sent from my iPhone using Tapatalk
Old 08-26-2017, 00:57   #6 (permalink)
Member: 2529775
Thanks Meter: 68
hope this helps
Originally Posted by georgeodoom View Post
How bro
Flash this modem
https://drive.google.com/file/d/0B9-...ew?usp=sharing
The Following 2 Users Say Thank You to kbdaking1 For This Useful Post:
Old 08-26-2017, 14:58   #7 (permalink)
Member: 2296236
Thanks Meter: 143
Originally Posted by kbdaking1 View Post
Have you tested on v 7.0 without baseband unknown
Old 08-26-2017, 21:06   #8 (permalink)
Member: 2529775
Thanks Meter: 68
what did u flash to get unkinown baseband
Old 08-26-2017, 22:16   #9 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,645
CP version: G928AUCU4APK1
thats correct modem bro u can ue that..
Old 10-03-2017, 09:23   #10 (permalink)
salo_ustad's Avatar
Member: 413160
Sonork: 100.1657278
Thanks Meter: 96
Reading phone info... OK
Model: SM-N920A
CP version: N920AUCU4APK1
Product code: SM4N920AZKAATT
Phone SN: RF8H60V9EPN
Unique number: 1215FC29CA473205
Reading IMEI... OK
IMEI: 356715079000801 (SIGN: OK)
Checking hash file... OK
Reading data from phone... OK
HWID: 18 70 4C 8C 16 07 00 00 00 00 00 00 00 00 00 00
Reading NV data... OK
Checking NV data... OK
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:02)
Freeze code: 40479040
NET lock: 30683519
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
Done with Samsung Tool PRO v.29.4
Page generated in 0.26254 seconds with 8 queries
