01-16-2016, 14:38 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: yaoundé (av kennedy)
Member: 361348 Status: Offline Thanks Meter: 635 | n920c flash failed FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-N920C Software version: 24.1 File analysis... OK Total file size: 0xEF679D50 (3830 Mb) Searching USB Flash Interface... detected COM47 Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... error timeout Done with Samsung Tool PRO v.24.1 |
