04-01-2016, 12:27 | #1 (permalink) |
Freak Poster Join Date: Apr 2004 Age: 44
Member: 62154 Status: Offline Thanks Meter: 17 | N920T unlock problem How are you, i have one N920T after unlock phone still lock, it is the following log UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-N920T Software version: 25.0 Waiting ADB device... OK Reading phone info... Model: SM-N920T Android version: 5.1.1 Product code: SM2N920TZKETMB Phone version: N920TUVU2COI5 PDA version: N920TUVU2COI5 CSC version: N920TTMB2COI5 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone S/N: RF8GB0N3YRT Modem board: SHANNON333 RF cal date: 20151107 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK Reading nv data... OK Checking NV data... OK Calculating... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.25.0 phone original firmware is N920TUVS2COKC, after unlock still lock, and i downgrade to lower version , but still same, please help. nang |
04-06-2016, 05:21 | #6 (permalink) | |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | 23.9 done yes 25.0 have a lot bug for some models Quote:
UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-N920T Software version: 23.9 Waiting ADB device... OK Reading phone info... Model: SM-N920T Android version: 5.1.1 Product code: SM-N920TZWATMB Phone version: N920TUVU2COI5 PDA version: N920TUVU2COI5 CSC version: N920TTMB2COI5 CSC country code: USA CSC sales code: TMB HW version: REV0.2 Phone S/N: RF8GA1QY5WP Modem board: SHANNON333 RF cal date: 20151019 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Writing nv data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.23.9 | |
