07-21-2017, 04:41 | #46 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Quote:
Run these commands from your adb folder, it will take care of all your problems. adb shell pm hide com.samsung.sprint.chameleon adb shell pm hide com.samsung.android.securitylogagent adb shell pm hide com.samsung.sdm adb shell pm hide com.wssyncmldm adb shell pm hide com.samsung.sprint.setupwizard adb shell pm hide com.sec.sprint.wfc adb shell pm hide com.sprint.ce.updater adb shell pm hide com.sprint.dsa adb shell pm hide com.sprint.fng adb shell pm hide com.sprint.international.message adb shell pm hide com.sprint.ms.smf.services adb shell pm hide com.sprint.psdg.sw adb shell pm hide com.sprint.voicemail adb shell pm hide com.sprint.w.installer adb shell pm hide com.sprint.zone If it fails with something like "User not allowed..." then root it first and replace every instance of adb shell pm hide WITH adb shell su -c pm hide | |
The Following User Says Thank You to BillA For This Useful Post: |
01-10-2018, 16:13 | #47 (permalink) | |
Freak Poster Join Date: Sep 2015
Member: 2465022 Status: Offline Thanks Meter: 13 | Quote:
Great info on the Note 7 Rev 2 Unlock Method. I have 6 of the Sprint Version of the Note 7 I just acquired yesterday! Three of the Six have the 60% battery block but still boot up and work. The other Three are bricked and will not charge. Do you guys have any solution or work around to get the bricked Note 7 to come back to life so I can unlock them and get them back to 100% battery life? I have been looking around and all I have found is to replace the battery with a charged battery and then flash it with a Combo File then unlock it then flash it back to battery chargeable revision hopefully the Sprint Version never went to Revision 3. I dont think it did honestly. I know that Tmobile and Verizon both did though. Let me know please if anyone has recommendations for the dead bricked Note 7 with latest Sprint update. | |
01-16-2018, 02:31 | #48 (permalink) | |
The reason for the "totally" bricked ones is that they have been updated to the latest Rev3 which completely disables charging, and once the battery runs out completely it won't charge or even power up into download mode either. The solution is to open up the phone and attach the battery to an external charger, then reattach it and flash it to whatever you want. Problem is that once the phone is on Rev3 you can't flash any lower than that. Good luck. Here's an updated security/bootloop disabler which works even on non-rooted samsung devices. Just run this script BEFORE flashing an eng-boot to disable Samsung's Security+OTA. Some commands may show an error, which is fine since this is a generic script for many different models. I'd recommend running it again immediately AFTER the eng-boot flash just to be on the safe side. Must have ADB enabled, and to undo it simply do a factory reset or flash a full stock over it. Samsung_Security+OTA_Disabler_(BillA_v2017-12-01).ZIP https://www.androidfilehost.com/?fid=673791459329068841 Unzip it and run this batch file which should be at top of the folder: _Samsung_Security+OTA_Disabler_(BillA_v2017-12-01).BAT | |
03-19-2018, 11:40 | #49 (permalink) | |
Freak Poster Join Date: Mar 2002 Location: Saudi Arabia/Philippines Age: 47
Member: 10468 Status: Offline Thanks Meter: 121 | Quote:
id tried this solution but it wont work, tried to DG binary3 to binary2 FW but still it has error | |
