Old 02-06-2018, 16:21   #1 (permalink)
dayman22's Avatar
Member: 46621
Thanks Meter: 30
N950FXXU3ARA2 frp
hi after flash COMBINATION N950FXXU3ARA2 i cant remove frp , software say frp removed but after flash stock u3 frp still on the phone , any help br
The Following User Says Thank You to dayman22 For This Useful Post:
Old 02-06-2018, 16:33   #2 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 886
Flash stock without csc
Sent from my SM-G935T using Tapatalk
Old 02-06-2018, 17:53   #3 (permalink)
dayman22's Avatar
Member: 46621
Thanks Meter: 30
not work still frp
Old 02-06-2018, 17:54   #4 (permalink)
souma_k's Avatar
Member: 1933823
Thanks Meter: 886
You get to the phone menu?
Old 02-06-2018, 19:06   #5 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 210
same problem. Not possible to go to menu. Without CSC, phone stuck on logo, or other test reboot on 'installing application".
Old 02-06-2018, 20:32   #6 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 210
I retry, after combination, flash without csc, frp still on.
Thanks for help
Old 02-06-2018, 20:34   #7 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 210
This my log when flashing:
My stock rom is N950FXXU3BR and adb is off ofter flash
[ 06/02/2018 21:03:00 ] Operation: Flash
[ 06/02/2018 21:03:00 ] Selected model: SM-N950F
[ 06/02/2018 21:03:00 ] Software version: 30.5
[ 06/02/2018 21:03:00 ] Searching phone and switching to flash mode... OK
[ 06/02/2018 21:05:00 ] Operation: Flash
[ 06/02/2018 21:05:00 ] Selected model: SM-N950F
[ 06/02/2018 21:05:00 ] Software version: 30.5
[ 06/02/2018 21:05:00 ] File analysis... OK
[ 06/02/2018 21:05:00 ] Total file size: 0x8A51A564 (2213 Mb)
[ 06/02/2018 21:05:00 ] Searching USB Flash interface... COM10 detected
[ 06/02/2018 21:05:00 ] Setup connection... OK
[ 06/02/2018 21:05:00 ] Reading PIT from phone... OK
[ 06/02/2018 21:05:00 ] Sending sboot.bin... OK
[ 06/02/2018 21:05:00 ] Sending param.bin... OK
[ 06/02/2018 21:05:00 ] Sending up_param.bin... OK
[ 06/02/2018 21:05:00 ] Sending cm.bin... OK
[ 06/02/2018 21:05:00 ] Sending nad_fw.bin... OK
[ 06/02/2018 21:05:00 ] Sending nad_refer.bin... OK
[ 06/02/2018 21:05:00 ] Sending boot.img... OK
[ 06/02/2018 21:05:00 ] Sending recovery.img... OK
[ 06/02/2018 21:05:00 ] Sending system.img... OK
[ 06/02/2018 21:07:00 ] Sending userdata.img... OK
[ 06/02/2018 21:08:00 ] Sending modem.bin... OK
[ 06/02/2018 21:08:00 ] Sending modem_debug.bin... OK
[ 06/02/2018 21:08:00 ] Flashing done (time - 00:02:41)
[ 06/02/2018 21:15:00 ] Operation: Flash
[ 06/02/2018 21:15:00 ] Selected model: SM-N950F
[ 06/02/2018 21:15:00 ] Software version: 30.5
[ 06/02/2018 21:15:00 ] Searching phone and switching to flash mode... OK
[ 06/02/2018 21:22:00 ] Operation: Flash
[ 06/02/2018 21:22:00 ] Selected model: SM-N950F
[ 06/02/2018 21:22:00 ] Software version: 30.5
[ 06/02/2018 21:22:00 ] File analysis... OK
[ 06/02/2018 21:22:00 ] Total file size: 0x15F83BE61 (5624 Mb)
[ 06/02/2018 21:22:00 ] Searching USB Flash interface... COM10 detected
[ 06/02/2018 21:22:00 ] Setup connection... OK
[ 06/02/2018 21:22:00 ] Reading PIT from phone... OK
[ 06/02/2018 21:22:00 ] Sending sboot.bin... OK
[ 06/02/2018 21:22:00 ] Sending param.bin... OK
[ 06/02/2018 21:22:00 ] Sending up_param.bin... OK
[ 06/02/2018 21:22:00 ] Sending cm.bin... OK
[ 06/02/2018 21:22:00 ] Sending boot.img... OK
[ 06/02/2018 21:22:00 ] Sending recovery.img... OK
[ 06/02/2018 21:22:00 ] Sending system.img... OK
[ 06/02/2018 21:27:00 ] Sending userdata.img... OK
[ 06/02/2018 21:28:00 ] Sending modem.bin... OK
[ 06/02/2018 21:28:00 ] Sending modem_debug.bin... OK
[ 06/02/2018 21:28:00 ] Flashing done (time - 00:06:40)
The Following User Says Thank You to orangade For This Useful Post:
Old 02-06-2018, 21:07   #8 (permalink)
-Mosin-'s Avatar
Member: 1948608
Thanks Meter: 1,468
After combination, just flash only this from stock firmware: Sboot/boot/recovery/system.
If Device get stuck than flash again only sboot/boot.
Once Done go to setting,enable OEM and make hard reset.
The Following User Says Thank You to -Mosin- For This Useful Post:
Old 02-07-2018, 09:15   #9 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 210
Thanks for help,
I flash combination rev3
verify if adb is enabled, ok.
Flash only boot,sboot, recovery, system from stock
mobile stuck on logo
Flash only boot and sboot from stock rom
I have already try this method from s8 working solution link but i try with 'cache' from stock but same problem.
Another idea please?
Old 02-07-2018, 09:20   #10 (permalink)
Member: 457143
Thanks Meter: 10
please give N950f binary 3 combination file link
Old 02-07-2018, 09:39   #11 (permalink)
Asad ali khan's Avatar
Member: 2454192
Sonork: 100.1674433
Thanks Meter: 600
flash with home csc just skip omr.img
Old 02-07-2018, 10:27   #12 (permalink)
dayman22's Avatar
Member: 46621
Thanks Meter: 30
after flash with csc only logo , when hard reset still frp
Old 02-07-2018, 12:08   #13 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 210
I don't have omr.img..?? With csc stuck logo...
Just search on forum bro: n950FXXU3xxx combination file
Old 02-07-2018, 13:24   #14 (permalink)
markhaines1985's Avatar
Member: 2532914
Thanks Meter: 1,113
FLASH the entire stock rom. Instead of flashing csc flash file that starts with HOME.
Old 02-07-2018, 13:36   #15 (permalink)
dayman22's Avatar
Member: 46621
Thanks Meter: 30
tried with HOME , without HOME always frp on
Page generated in 0.34420 seconds with 7 queries
