Old 02-07-2018, 14:44   #16 (permalink)
bk.gsm's Avatar
Member: 869809
Sonork: 100.1585798
Thanks Meter: 569
hi
flash the entire combination then from stock firmware only flash sboot\cm\boot\system\recovery\modem..phone will goes to recovery just press reboot..when phone complete the setup just go to settings by swiping the notification screen down..u will see the settings icon press it and enable developer menu and enable oem...
with best regards..
Old 02-07-2018, 15:02   #17 (permalink)
markhaines1985's Avatar
Member: 2532914
Thanks Meter: 1,138
Originally Posted by dayman22 View Post
tried with HOME , without HOME always frp on
YOU CANT ERASE FRP WHILE COMBO IS ON..the point of flashing the combo is to enable adb...so when you flash stock back with home instead of csc adb is enabled so you can then bypass frp with stock rom installed
1. flash combo
2. flash stock rom back with home instead of csc
3. use z3x to bypass frp via adb
The Following 2 Users Say Thank You to markhaines1985 For This Useful Post:
Old 02-07-2018, 18:16   #18 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 211
Originally Posted by bk.gsm View Post
hi
with best regards..
Thanks but I try 2 times but not work:
I Flash combination
Flash only sboot, cm, boot, system, recovery modem, from stock
phone not go to recovery but stuck on logo.
Thanks for idea....
Old 02-10-2018, 01:35   #19 (permalink)
Member: 2532914
Thanks Meter: 1,138
let me say this again...you flash the entire stock rom after you flash the combo file....the only thing you do different is flash home file in csc slot. dont skip any files..flash the entire rom
The Following User Says Thank You to markhaines1985 For This Useful Post:
Old 02-12-2018, 18:19   #20 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 211
Thnaks ; I try two time the full procedure but doesn't work.
I flash entire stock rom with normal CSC (not the csc home)
I flash combination
I flash entire stock rom with Home csc
Phone reboot but frp still on, and phone ask gmail.
Any ideas please, I search always, thanks for all.
Old 02-12-2018, 18:26   #21 (permalink)
orangade's Avatar
Member: 521955
Thanks Meter: 211
My stock rom is N950FXXU3BRA8 . I download bra2 version perhaps its the problem.
Anybody have bypass frp of n950f bit3 ?
Old 02-12-2018, 21:28   #22 (permalink)
Member: 2596108
Thanks Meter: 53
I flash combination
use z3x to bypass frp now... you flashed home csc you now have adb
The Following User Says Thank You to wirelessinfinit For This Useful Post:
Old 02-13-2018, 02:27   #23 (permalink)
Member: 2532914
Thanks Meter: 1,138
they dont listen. i told them 3 freaking times you cant wipe the frp while combo rom is on the phone..FOR THE LAST FREAKING TIME. YOU FLASH THE COMBO SO WHEN YOU FLASH FULL STOCK ROM BACK WITH HOME INSTEAD OF CSC YOU WILL THEN HAVE ADB ENABLED SO YOU THEN CAN BYPASS FRP.
READ
READ
READ
Old 02-13-2018, 16:00   #24 (permalink)
Member: 2792776
Sonork: 1577835
Thanks Meter: 14
i also tried all solution but not work on U3 version
is there any one who did this boot version
Old 02-13-2018, 16:01   #25 (permalink)
Member: 2792776
Sonork: 1577835
Thanks Meter: 14
READ
READ
READ
my friend when its ready to getting ON
in start its again gone to download mode not getting stable on ADB command
Old 02-14-2018, 10:07   #26 (permalink)
Y2ksalman's Avatar
Member: 194511
Sonork: 100.1577836
Thanks Meter: 1,580
100 % worked for me
1st download combination
[up_vnROM.net]_COMBINATION_FA71_N950FXXU3ARA2_CL12771072_QB16471 415
flash with z3x
reset frp selecting g935p
then go on dialer or calc write *#0808# select last option DM + MODEM + ADB
then go again setting and do full reset after it will reboot then take it again into download mode
[up_vnROM.net]_N950FXXU3BRA2_N950FOXM2BRA1_XEF_FULL
and flash with BL AP and CSC
on BL just select sboot.bin
on AP just select boot.im recovery.img & system.img
on CSC (HOME) select only cache.img
FLASH fone and u will c it will bypassed
The Following 9 Users Say Thank You to Y2ksalman For This Useful Post:
Old 02-14-2018, 14:02   #27 (permalink)
Member: 1713296
Thanks Meter: 67
Originally Posted by Y2ksalman View Post
100 % worked for me
flash with z3x
download link for combination file?
The Following 2 Users Say Thank You to NsNobel2 For This Useful Post:
Old 02-14-2018, 16:10   #28 (permalink)
Y2ksalman's Avatar
Member: 194511
Sonork: 100.1577836
Thanks Meter: 1,580
Combination
https://drive.google.com/uc?id=1HdL2...xport=download
Full Firmware
https://drive.google.com/uc?id=1E68W...xport=download
The Following 3 Users Say Thank You to Y2ksalman For This Useful Post:
Old 02-15-2018, 01:52   #29 (permalink)
Member: 2802156
Thanks Meter: 134
100 % worked for me
flash with z3x
Any solution for OEM UNLOCK missing? This is due to the new RMM lock on some later model phones including this one.
The Following User Says Thank You to gsm_service4u For This Useful Post:
Old 02-19-2018, 18:14   #30 (permalink)
Member: 2324261
Thanks Meter: 102
Explain
You can explain ok? Instructions not ok..
reset frp selecting g935p (TWO WAYS: DOWNLOAD AND ADB)
explain ok please
Page generated in 0.37793 seconds with 7 queries
