10-14-2018, 22:38 | #1 (permalink) |
Junior Member Join Date: Sep 2005 Location: egypt Age: 43
Member: 181674 Status: Offline Thanks Meter: 1 | SM-N950u t-mobile can't unlock [Answered] cant unlock any help this is log UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will appear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Unlocking using Server: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-N950U Selected port: COM21 SAMSUNG Mobile USB Serial Port Software version: 33.8 Checking Login and Password... OK Ballance: 33 crd. You have 33 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-N950U Android version: 8.0.0 PDA version: N950USQS5CRG9 CSC version: N950UOYN5CRG9 Phone version: N950USQS5CRG9 Product code: SM2N950UZKATMB CSC country code: USA CSC sales code: TMB Phone SN: R28K91Q9JXA IMEI: 358505086766611 HW version: REV1.0 RF cal date: 2018.09.19 Chip name: MSM8998 Modem board: MSM8998 Security patch: 2018-08-01 Boot Warranty bit: 0 Searching Samsung diag port... detected COM21 Reading phone info... OK Reading data from phone... error (0), skip Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM6 detected Reading data from phone... OK Calculating... error (0) Done with Samsung Tool PRO v.33.8 best regards |
