01-31-2017, 17:11 | #1 (permalink) |
Freak Poster Join Date: Aug 2009
Member: 1095293 Status: Offline Thanks Meter: 1 | need help for j700h imei EFS/NV DATA operations: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. Operation: Write CERT Selected model: SM-J700H/DS Software version: 27.6 Waiting ADB device... Ok Reading phone info... Model: SM-J700H Android version: 5.1.1 Product code: Phone version: J700HXXU2APC1 PDA version: J700HXXU2APC5 CSC version: J700HODD2APC1 CSC country code: India CSC sales code: INU HW version: Phone SN: R21H60BNWXT Chip name: EXYNOS7580 Modem board: SHANNON310 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.6 |
01-31-2017, 17:13 | #2 (permalink) |
Member: 1095293 Status: Offline Thanks Meter: 1 | Need help for j700h/ds imei corrupted BACKUP INSTRUCTIONS: EFS/NV DATA operations: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. Operation: Info Selected model: SM-J700H/DS Software version: 27.6 Searching Samsung modem... detected COM28 Reading phone info... Ok Model: SM-J700H AP version: J700HXXU2APC5 CSC version: J700HODD2APC1 CP version: J700HXXU2APC1 Product code: XXXXXXXXXXXXXX Phone SN: R21H60BNWXT Unique number: CAJ0318B7C08243 Reading IMEI... Ok IMEI: 000000000000000 (SIGN: NG_SIGN) IMEI 2: 000000000000000 (SIGN: NG_SIGN) Done with Samsung Tool PRO v.27.6 |
