12-08-2018, 15:52 | #1 (permalink) |
Junior Member Join Date: Mar 2012 Location: dublin ireland
Member: 1732178 Status: Offline Thanks Meter: 2 | g390f not detected UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-G390F Software version: 34.3 Checking Login and Password... OK Ballance: 35 crd. You have 35 credit(s) left. This operation takes 5 credits.Continue? Yes ADB device not selected Done with Samsung Tool PRO v.34.3 |
