02-16-2018, 06:10 | #1 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | NEED Remove G610F FRP 7.0 i need help to remove frp G610F 7.0 G610FXXU1BRA4 Security Patch Level 2017-08-01 i try to downgrade phone but no sucsess, i try to flash only system img from downgrade version but after flash phone stuck on startup logo with ( custom binary block) i try talk back Trick and use Calculator But when i enter this code (+30012012732 now press + then Dp menu only blink for 1 second. by Quick shortcut also not work even google account manager is installed, any solution for remove frp ??? |
02-16-2018, 06:21 | #2 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Pakistan
Member: 682736 Status: Offline Thanks Meter: 457 | Quote:
from support area. after flash Hard reset and Reset frp video available on youtube... | |
02-16-2018, 07:04 | #3 (permalink) | |
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | Quote:
as wrote in my post. phone is not possible to downgrade as i already try with many version also try with yours... always get error at boot loader writing & when i try to flash only system then also phone stuck on logo But after wipe phone show on start up logo (Custom binary block by FRP) | |
02-19-2018, 08:10 | #5 (permalink) |
Freak Poster Join Date: Mar 2014 Location: Earth
Member: 2148096 Status: Offline Sonork: 100.1674885 Thanks Meter: 27 | Nougate FRP Remove Follow This Tutr: https://www.youtube.com/watch?v=CHGHsrBzGXQ |
02-20-2018, 06:48 | #6 (permalink) | |
02-20-2018, 07:02 | #7 (permalink) |
Freak Poster Join Date: Dec 2008 Location: uae.abudhabi
Member: 930738 Status: Offline Sonork: 100.1652204 Thanks Meter: 8 | https://www.youtube.com/watch?v=BHAzpiaTOUs check this option |
02-22-2018, 19:22 | #11 (permalink) |
Freak Poster Join Date: May 2010
Member: 1296452 Status: Offline Thanks Meter: 67 | flash with latest version downloaded from sammobile phone will be back to its frp status then download combination file and write only boot and sboot perform hard reset ..... flashing boot and sboot will enable adb just reset frp in adb mode after that flashed again with latest version |
02-22-2018, 19:35 | #12 (permalink) |
Junior Member Join Date: Jan 2016 Location: missouri, USA
Member: 2515120 Status: Offline Thanks Meter: 9 | flash the factory binary firmware. then take stock firmware and flash the CSC first. then you can flash the BL, AP, CP. When flashing the AP you must extract it with 7zip and re-tar all the .img files except userdata. |
02-24-2018, 10:38 | #13 (permalink) | |
02-24-2018, 14:10 | #15 (permalink) |
Insane Poster Join Date: Jul 2007 Location: kuwait@philippines
Member: 550551 Status: Offline Thanks Meter: 25 | G610FD and G630FD same reflash to version 7.0. bypass any samsung account apk then used z3x or FRP tools adb frp reset here is intruction https://www.youtube.com/watch?v=rhbM44zrPLo |
