04-15-2014, 07:28 | #32 (permalink) |
Junior Member Join Date: Aug 2013
Member: 2013774 Status: Offline Sonork: [email protected] Thanks Meter: 4 | yess.........update windows,solved your problem...tested by m |
11-13-2014, 07:59 | #34 (permalink) |
Freak Poster Join Date: Dec 2013 Location: Lahore
Member: 2093017 Status: Offline Sonork: 100.1650959 Thanks Meter: 117 | what are you all of doing? one solution for all of you and you all give suggesion update windows, blah blah 1:first remove all drivers from device manager z3x box com port etc. 2: download this and install if it,s say already install remove first then install. 3: restart system and now connect your box driver not found yellow marks on device manage don,t worry. 4:Now go to device manager and then see yellow mark on smart card driver. 5:right click on it choose driver install from already install driver 2nd option. then you see card driver 2009 and 2007 version. 5: selct 2007 version and your driver 100% installed now connect box if it,s gives box driver error don,t worry open samsung tool and it,s detect your box and you are successfully running z3x on win 7 32bit and 64bit . (Pressed thanks if you like solution ) Link : http://www.4shared.com/file/uDgPn6Ew..._stdrk200.html |
The Following User Says Thank You to AndroidExpert12 For This Useful Post: |
11-14-2014, 22:33 | #35 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2292431 Status: Offline Thanks Meter: 0 | I need to update z3x box After registered if ask me to update the card firmware but when I try to update say cannot connect to the server I have windows 8.1 64bit Firewall OFF antivirus OFF 15mb Internet speed But no luck Any help is appreciated |
12-13-2014, 19:44 | #37 (permalink) |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | I face same problem , Box driver install successfully but Smart card driver not found. I install Shell 4.7 and i use windows7 23bit. Z3X team please solved the problem next update. |
01-06-2016, 17:36 | #38 (permalink) | |
Junior Member Join Date: May 2014
Member: 2191626 Status: Offline Thanks Meter: 6 | Quote:
tanks my friend. | |
07-05-2017, 06:02 | #39 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2732840 Status: Offline Sonork: [email protected] Thanks Meter: 0 | i want usb driver for my cm2 dongle |
