Old 05-27-2015, 14:33   #1 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 929
neede root SM G920F
please need to root sm G920F Tmobile
i try root with cfautoroot phone stuck on logo
need guide for unlock this model
Old 05-27-2015, 14:35   #2 (permalink)
Member: 1761678
Sonork: 100.1615439
Thanks Meter: 370
first flash ur phone then root again
The Following User Says Thank You to tauheed9 For This Useful Post:
Old 05-27-2015, 14:38   #3 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
root with CF autoroot (for 5.0.2 version ) tested!
BR,
WAJID
The Following User Says Thank You to WAJID PNR For This Useful Post:
Old 05-27-2015, 14:49   #4 (permalink)
mach6's Avatar
Member: 2334036
Thanks Meter: 131
Root with PingPong root, no Knox trigger
[ROOT] PingPongRoot ***S6 & S6 Edge Root… | Samsung Galaxy S6 | XDA Forums
The Following User Says Thank You to mach6 For This Useful Post:
Old 05-27-2015, 14:53   #5 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 929
but how to power off this phone?
hold power phone not off
Old 05-27-2015, 14:57   #6 (permalink)
Member: 737720
Thanks Meter: 1,421
What do u mean hawo to power off? Just press the power button. And if power not working then fix that first and root the phone
The Following User Says Thank You to jawi For This Useful Post:
Old 05-27-2015, 15:00   #7 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 929
yes sir this phoen after root with CF-Auto-Root-zeroflte-zerofltexx-smg920f.tar phone stuck on logo
now i want to reflash but i cant power off for go to download mode
Old 05-27-2015, 15:05   #8 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
all you need to do is press and hold the power button and the volume down key, simultaneously for seven seconds.
Old 05-27-2015, 15:23   #9 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 929
flashing failed
Old 05-27-2015, 15:33   #10 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 929
on z3x failed too
Old 05-27-2015, 15:41   #11 (permalink)
Member: 737720
Thanks Meter: 1,421
Flash only modem or delete the md5 then flash good luck.
Old 05-27-2015, 15:48   #12 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 929
i have remove md5 but same eror
File analysis... OK
Total file size: 0xDF3EBCE0 (3571 Mb)
Searching USB Flash Interface... detected COM9
Setup connection... OK
Reading PIT from phone... OK
Sending sboot.bin... OK
Sending cm.bin... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending system.img... OK
Sending cache.img... OK
Sending hidden.img... error timeout
Done with Samsung Tool PRO v.21.1
Old 05-27-2015, 15:55   #13 (permalink)
Member: 2056267
Sonork: 100.1659198
Thanks Meter: 26
don't panic
( re-flash ur phone and start from the beginning) after u got the error follow the steps
Download IMG2TAR from -> HERE <- and extract it
1: rename SM-920F.bla.bla.tar.md5 to SM-G920F.NOT.bla.bla.tar
2: open SM-G920F.NOT.bla.bla.tar with winrar and extract recovery.img
3: put recovery.img inside IMG2TAR folder then run Convert.bat it will convert the img to tar
4: Flash recovery.tar in PDA ( if the phone enter recovery please just reboot ur phone )
5: ur S6 works fine ! LOL
The Following 3 Users Say Thank You to Tulkarm For This Useful Post:
Old 05-27-2015, 16:07   #14 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 929
Turkam
thanks verry verry much now phone working again
u are best solution for helping me
wow im so panic
now i want to unlock this phone
can give me step for rooting this?
Old 05-27-2015, 16:16   #15 (permalink)
WAJID PNR's Avatar
Member: 625961
Sonork: 100.1590447
Thanks Meter: 1,285
File analysis... OK
FOR FLASHING OR GETTING PREVOIUS CONDITION simply can do with kies
Open kies3 >tools> firmware upgrade initialization > model name (SM-920F ) > S/N (put your serial number )> then connect phone download mode/kies mode.
for rooting follow my post http://forum.gsmhosting.com/vbb/11074523-post3.html
Page generated in 0.25227 seconds with 9 queries
