Old 08-03-2014, 12:28   #46 (permalink)
Member: 1431846
hi... is there any possibility that you can post the complete list of supported models for this file..
and i have i9305 with 3g network problem..will this file fix it ...thanks
Old 08-03-2014, 15:02   #47 (permalink)
Member: 1994657
Thanks Meter: 93
Originally Posted by BabooG View Post
Hi,
I think the problem is fixed 50%.
Samsung I747 Android 4.3
Problem 1: After the Unlock phone will take 10-15 minutes to pickup signal.
Problem 2: After the unlock, you will only get edge.
This solution fixes the problem 2.
But this solution does not address problem 1 listed above.
Here is the log
Selected model: I747
Selected port: COM130 SAMSUNG Mobile USB Serial Port
Selected port speed: 115200
Reading phone info...
Reading IMEI... OK
IMEI: 35153706004xxxx
Build: M8960A-AAAANAZM-1.0.443089
Writing NVM... OK
Done with Samsung Tool v.17.9
Use samsung tools 16.9 and make network repair, it will fix both problems.
Old 08-03-2014, 21:17   #48 (permalink)
Member: 2233192
Old 08-03-2014, 21:22   #49 (permalink)
manule's Avatar
Member: 786607
Thanks Meter: 66
Gibt me steps Ehen i want Write it say Not detect
Old 08-03-2014, 22:22   #50 (permalink)
.:iTRi:.'s Avatar
Member: 240068
Thanks Meter: 201
i have i9505 whene i enter *#9090# and choose DM\DUM over HS-USB
phone reboot any solution
Old 08-03-2014, 23:31   #51 (permalink)
Member: 28559
Thanks Meter: 85
PLEASE ADD Network, 3G/4G FIX NVM for galaxy s3 mini from at&t g730a. i have network problems with all of this model phones unlocked with z3x.
Old 08-04-2014, 06:00   #52 (permalink)
Member: 2201664
i have a N7105 singapore set i have flash the firmware & IMEI there no network for 2G/3G only support 4G network ! can anyone help me to solve that problem...??
Old 08-04-2014, 22:58   #53 (permalink)
Member: 118601
Thanks Meter: 200
how to fix network registration on I9500 after repair Imei and baseband? can we use this file for fix network here?
Old 08-04-2014, 23:30   #54 (permalink)
Member: 1994657
Thanks Meter: 93
Only works with super IMEI, you must write the IMEI with phone rooted with a sim card inserted and after you get service you cant remove the root or phone wont connect.
Old 08-05-2014, 07:08   #55 (permalink)
Member: 118601
Thanks Meter: 200
but i have write Root and write IMEI with 16.9 but at the end i still can't connect or registered on network only emergency mode. with other version of soft Z3x, it ended with IMEI NULL
Old 08-05-2014, 07:27   #56 (permalink)
Member: 552674
Thanks Meter: 18
Originally Posted by blang View Post
This thread regarding problem of NO NETWORK or network without 3G/4G/LTE with new qualcomm phones after imei repair or UNLOCK:
such as:
i747,i737,i9505,m919n etc.
If you you have any problem with netowork after unlock/imei repair, please write to phone this NVM. To be sure try write 2 times 1 by 1, if phone restart while writing, repeat again write nvm.
Please all time use last version, post log and result of your job. Time to fix this problem forever. We need testing and results.
Waiting for your job.
Please dont ask about S4,Note3,G7102,S7275R new qualcomm now, we remember and working on it. Just solution will be ready, we will add, and like usually absolulty free without any credits stay here.
Crack!!!
Thank you, I have days fighting with this problem, my qcn method stopped working.
Old 08-07-2014, 00:09   #57 (permalink)
Member: 1994657
Thanks Meter: 93
It should worked I did it to many i9500 with 4.4.2 and worked, please try again.
Old 08-09-2014, 11:05   #58 (permalink)
nhumanh's Avatar
Member: 56938
Sonork: 100.1590777
Thanks Meter: 152
Selected model: I9505
Selected port: COM60 SAMSUNG Mobile USB Serial Port
Reading IMEI... OK
IMEI: 35737705xxxxx5
Build: M9615A-CEFWTAZM-4.0.17135
Writing NVM... OK
Done with Samsung Tool v.17.5
IT's work perfert on i9505 XXUFNC4 thanks bro
Old 08-09-2014, 12:06   #59 (permalink)
Member: 2203944
Thanks Meter: 6
you are a boss ,no team like yours.best regard master
Old 08-12-2014, 07:32   #60 (permalink)
Member: 751538
Thanks Meter: 22
I have an I8730 (4.1.2) that lost 3G/4G signal after unlock. Can I use this file somehow? There is no NVM read/write option for this model, even in the latest version (18.0).
Page generated in 0.35420 seconds with 9 queries
