06-21-2018, 10:29 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Algeria
Member: 274054 Status: Offline Thanks Meter: 400 | New Solution Remove FRP S8 Plus SM-G955F Last Security this is new solution to remove frp S8 Plus SM-G955F last security tested by me with many phone like this 2018 security first you need combination write (COMBINATION_FA70_G955FXXU1AQD1_TESTED_V7-V8) (after writing go to setting and factory reset) Code: Operation: Flash Selected model: SM-G955F Software version: 32.7 File analysis... OK Total file size: 0x7CDDDD7C (1997 Mb) Searching USB Flash interface... COM756 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending up_param.bin... OK Sending cm.bin... OK Sending nad_fw.bin... OK Sending nad_refer.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Sending modem.bin... OK Sending modem_debug.bin... OK lashing done (time - 00:01:57) and uncheck from AP (userdata) and from CSC_home uncheck (meta-data/download-list) LOG Code: Operation: Flash Selected model: SM-G955F Software version: 32.7 File analysis... OK Total file size: 0xEA5979CA (3749 Mb) Searching USB Flash interface... COM756 detected Setup connection... OK Reading PIT from phone... OK Sending sboot.bin.lz4... OK Sending param.bin.lz4... OK Sending up_param.bin.lz4... OK Sending cm.bin.lz4... OK Sending boot.img.lz4... OK Sending recovery.img.lz4... OK Sending system.img.lz4... OK Sending cache.img.lz4... OK Sending hidden.img.lz4... OK Flashing done (time - 00:02:55) active OEM unlock and dubeg on) than factory setting from menu to finish work write full firmware (BL-AP-CP-CSC) LOG Code: Operation: Flash Selected model: SM-G955F Software version: 32.7 File analysis... OK Total file size: 0x15DAE4DFE (5594 Mb) Searching USB Flash interface... COM756 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin.lz4... OK Sending param.bin.lz4... OK Sending up_param.bin.lz4... OK Sending cm.bin.lz4... OK Sending boot.img.lz4... OK Sending recovery.img.lz4... OK Sending system.img.lz4... OK Sending userdata.img.lz4... OK Sending modem.bin.lz4... OK Sending modem_debug.bin.lz4... OK Sending cache.img.lz4... OK Sending hidden.img.lz4... OK Flashing done (time - 00:05:52) |
The Following 8 Users Say Thank You to FayGsmDz For This Useful Post: |
