01-10-2012, 11:36 | #1 (permalink) |
Junior Member Join Date: Dec 2005 Location: Bournemouth UK
Member: 205467 Status: Offline Thanks Meter: 3 | Nexus S i9020 IMEI and EFS repair - how?im out of ideas. Z3X supports both imei and efs repair but how to do that if the software needs the phone connected in usb modem mode? here is a log Count supported models - 290 Starting ADB Server... OK Checking ROOT... FALSE Reading Phone Info... OK Android Version: 2.3.1 Model: Nexus S Product Code: Not Active Phone Version: I9020XXKB1 IMEI: 004999010640000 Rooting Phones... OK Reading Data From Phone... OK Writing Data To Phone... OK Searching Samsung USB Modem... Not Found Done with Samsung Tool ver 11.9 is there any patched firmware that will allow to enter test mode to change the connection settings like we do in many samsung phones? or someone knows how to do it in other way. Searched forums websites support sections and nothing found. I also add that checked all possible ways phone rooted bootloader unlocked with PDAnet and w/o checked on almost every rom version available including ICS SPT supports this operations by patched firmware but i allways preffered z3x. Please help...Thanks |
01-10-2012, 12:56 | #3 (permalink) |
Member: 205467 Status: Offline Thanks Meter: 3 | USB Deb...ing enabled otherwise phone will not connect to ADB once the repair process started. Standard codes like *#9090# do not work. the only code that works on this phone is *#*#4636#*#* but its only for info about battery usage wifi phone info etc |
01-10-2012, 13:20 | #6 (permalink) |
Member: 205467 Status: Offline Thanks Meter: 3 | Nexus s does not have an KIES mode to select and codes like *#1234# not work on this phone. If z3x team implementet option to repair imei and efs in their software there must be a way to connect it in modem mode but how? I treid UART cables from z3x nspro even from vygis - not working . |
01-10-2012, 18:31 | #9 (permalink) |
Member: 205467 Status: Offline Thanks Meter: 3 | Please product supporters help us out in this....There must be a way to connect the phone as a usb modem or maybe there is a bug in the repair procedure in software? Only u can save many nexus s phones ... |
01-11-2012, 11:00 | #12 (permalink) |
Member: 205467 Status: Offline Thanks Meter: 3 | philzfog16 if its not supported in z3x then why in version 10.7 states that first in the world imei and efs repair for i9020 & i9023 (beta).if its not supported he should inform that one of his updates will not work. Thats how i see it anyway. shak360 with all do respect did u even read the first post?You are asking question that u have answer for allready...all the answers for your questions are in the first post of this topic.i described everything as best as i could so please read it carefully and then maybe try to help... Yes SPT supports this operation but as i stated dont have spt as preffer z3x.but looks like its time to change tools. |
02-26-2012, 10:50 | #13 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1396522 Status: Offline Thanks Meter: 2 | hello. is their anymore news on fixing this problem as im having the very same problem as zikmaster. i have tried flashing with a couple of different firmwares. i even flashed with i9023 firmwares and still cant get the imei repaired i was wondering would the i9003 flash files work on this fone? |
02-28-2012, 21:19 | #15 (permalink) | |
No Life Poster Join Date: Mar 2011 Location: FIND ME Age: 32
Member: 1538904 Status: Offline Sonork: 100.1603095 Thanks Meter: 198 | Quote:
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
