05-19-2014, 07:43 | #1 (permalink) |
Junior Member Join Date: May 2014
Member: 2181604 Status: Offline Thanks Meter: 0 | No answer from phone imei clean s4 Root your device *#0808# select dm+modem+adb Select correct model Select the correct port Click on repair Put the original imei and press ok... Then I get the following ? Selected model: I337 Selected port: COM1 Communications Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.17.4 Done with Samsung Tool v.17.4 |
05-19-2014, 08:28 | #4 (permalink) | |
No Life Poster Join Date: Mar 2013 Location: pakistan Age: 34
Member: 1899191 Status: Offline Sonork: 100.1625109 Thanks Meter: 136 | Quote:
second u not active ur fone on proper setting thats y u facing this problm if u not understand ur this problm.......contect me on skype i wil help u | |
05-19-2014, 08:44 | #6 (permalink) |
Member: 2181604 Status: Offline Thanks Meter: 0 | THANKS IT WORKED ONLY THING IS IT SAYS WHAT IT SAYS BELOW AND UNDER IMEI IT SAYS UNKNOWN IT CLEAN ED IT AND WORKING GOOD HOW CAN I TAKE OF UNKNOWN IMEI ? *** BLESS Selected model: I337 Selected port: COM7 SAMSUNG Mobile USB Serial Port* Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SAMSUNG-SGH-I337 Android version: 4.3 Product code: SGH-I337ZWAATT Phone version: I337UCUEMK2 PDA version: I337UCUEMK2 CSC version: I337ATTEMK2 IMEI:*356565051118638 Phone S/N: R31D41BR3AT Checking Super user right... true Backuping MMCBLK... OK Writing data to phone... OK Rebooting phone... OK Waiting phone... Please, allow USB debugging on phone... Please, allow USB debugging on phone... OK Bypass MSL... error Done with Samsung Tool v.17.4 |
05-19-2014, 09:06 | #7 (permalink) |
Member: 2181604 Status: Offline Thanks Meter: 0 | 1]Via the USB connected to the Z3x box right ??[/QUOTE] via usb means attach phonr with pc usb port not z3x usb port[/QUOTE] I attached to z3x usb port and it did it but now says unknown imei works good just says unknown imei ? Was it because I was supposed to put to usb from pc ? |
05-20-2014, 15:08 | #12 (permalink) |
No Life Poster Join Date: Jun 2008 Location: dunja
Member: 786607 Status: Offline Thanks Meter: 66 | no answer from phone even trough dl modus or on modus what is this faulty Selected model: S5830 Selected port: COM67 SAMSUNG Android USB Diagnostic Serial Port (WDM) Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.17.5 Selected model: S5830 Selected port: COM45 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.17.5 Selected model: S5830 Selected port: COM45 Z3X BOX Serial Port Selected port speed: 115200 File analysis... OPS file not exist Done with Samsung Tool v.17.5 Selected model: S5830 Selected port: COM45 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.17.5 |
05-20-2014, 16:50 | #13 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Canada
Member: 119464 Status: Offline Thanks Meter: 288 | Check drivers first make sure u install Samsung drivers first or try another pc if still same then it ll be hardware issue . Regards Sent from my SGH-I747M using Tapatalk |
