01-14-2017, 17:51 | #1 (permalink) |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | NO BOX Universal Lollipop 5.1.1 Marshmallows 6.0.1 GOOGLE FRP Account Bypass Removal Here is the step by step proccess: 01. You need to download the "RealTerm" program and install it in your computer (Thanks Root Junky for the links) : rootjunkysdl.com. 02. Go to phone. You need to have a SIM in your phone for this process to work for the ORIGINAL CARRIER of the phone. 03. Go to your setup screen and connect to WIFI. 05. Using a USB cable, connect your phone to your computer. Make sure that your computer is reconizing your phone by instaling the last Samsung drivers available (Download Center: Download Software, Firmware, Drivers & Manuals | Samsung) 06. Once the phone is reconized by the computer and USB connected, we need to find out in what USB port your phone is connected to. To do that, you need to go you "Device Manager" in your computer. Click on "Modems". Then click on "SAMSUNG Mobile USB". On that screen, open the "Modem Tab". The first thing that you will find is: "PORT: COM09" (COM09 is in example, your phone could be connected to another port like COM41, COM39, and so on). 07. Now that we know our USB port number, open your RealTerm program. In the Realterm "Display" tab, make sure to check the "HALF DUPLEX" box. 08. Then, click on the "PORT" tab. Now, here we are going to enter the port number that our phone is without the COM in the Port box (For Example, COM43 = 43). The click on the "OPEN" button next to it. 09. Go to the "SEND" tab. In the first box, type the following command: at+creg?\r\n and click on "SEND NUMBERS" 10. Then, in the same box, type: atd1234;\r\n and also click "SEND NUMBERS". At this step, you need to look at the phone screen because the dealer is going to try to dial "1234". If not, keep sending the atd1234;\r\n commands. 11. When the dialer shows up, end the call and immediately click on the "MESSAGE" button. The phone is going to go to SMS to send a message to the "1234" number that the phone tried to dial. Send this 1234 number "YOUTUBE.COM" message. Send it. After the message is sent to this number, the words "Youtube.com" would became a blue internet link, click on it. The browser is going to go to Youtube. After you are in YouTube, click on the 3 dots at the upper right hand side of the screen. Click on "Settings", then click "About", then "GOOGLE Privacy Policy". the phone will ask you to choose an internet browser. Use the "Internet Browser" 12. When you are in the browser, again go to " rootjunkysdl.com " (Thanks Root Junky for the Links) and download "com.rootjunky.frpbypass-1.0.apk". 13. Then, go on Google.com and search for "Samsung App Store" : Samsung Galaxy Apps | Mobile Service | APPS | SAMSUNG Levant . Click on the "App Store" button. The Samsung is going to open and ask you to sign in. You would have to either create an account or use your existing Samsung account. Do not worry, you would get to remove it later. 14. Once you are at the Samsung account, search for "ES FILE Explorer" and install it in your phone. Once, it is installed, open the app. The app will allow you to go to the "Download" folder of your phone. There you will find the "com.rootjunky.frpbypass-1.0.apk" that you previously downloaded. Open and Install the "com.rootjunky.frpbypass-1.0.apk". The App will send you to the "Google Sign In" windows. DO NOT SING IN. Click on the three dots at the upper right hand side of the screen and click on "BROWSER SIGN IN". Then a new Google browser sign in screen will appear. Yes, you can Sign in there with your existing Google account (Again, do not worry, you can remove it later). Once you are signed in, you need to restart your phone. 15. Follow the setup instructions. The phone is not going to ask you for the Google account because you already entered. 16. Once at the home screen, click on 'Settings". Then go to "Accounts” and click on the "Samsung Account", click on "Remove Account". The phone is going to ask you for a confirmation to enter your password. Enter it and click on Remove. Go back and click on your "Google Account". Click on "Remove Account". 17. Go back to settings, and then click on "BACKUP AND RESET". Then click on "FACTORY DATA RESET". Then "RESET DEVICE". The phone will factory reset and the FRP will be removed. DO NOT FORGET TO CLICK ON THE THANKS BUTTON |
The Following 105 Users Say Thank You to GalaxyVibe For This Useful Post: |
01-21-2017, 08:54 | #2 (permalink) |
Freak Poster Join Date: Feb 2014 Location: Hangu
Member: 2129557 Status: Offline Thanks Meter: 57 | Old method bro. New method is very simple. Just select A510F in Z3X box and click Reset FRP/Reactivation lock Button. Wait for the set to be on and all done. |
The Following 7 Users Say Thank You to luqmanonline For This Useful Post: |
01-22-2017, 15:31 | #4 (permalink) |
Member: 2577670 Status: Offline Thanks Meter: 883 | Some models require the Eng Sboot which is very hard to find for free. The box requires a little more knowledge in some models. Some models are not supported in the box. This is a very easy and friendly anyone can use procedure. No eng files required, no file flashing, no odin. Very simple and effective. |
The Following 6 Users Say Thank You to GalaxyVibe For This Useful Post: |
01-24-2017, 17:09 | #5 (permalink) | |
Freak Poster Join Date: Mar 2013 Location: Madrid
Member: 1898289 Status: Offline Thanks Meter: 39 | Quote:
Port OK, Half Duplex activated, WIFI connected and activated SIM card inside. | |
The Following User Says Thank You to mandango For This Useful Post: |
01-24-2017, 23:40 | #7 (permalink) |
Member: 1898289 Status: Offline Thanks Meter: 39 | I'll check again one by one, I can before with this way and sideload, but this recent one no lucky by both ways. Maybe has last December security patch, should be higher security than Agoust and previous, but I can't afirm is that way is fixed or not. |
01-25-2017, 06:02 | #8 (permalink) |
Member: 2577670 Status: Offline Thanks Meter: 883 | This method should not be patched. This method uses the dialer of the phone which should be always enabled because the phone should always be ready to dial emergency numbers like 911. That is why the method should work every time if the process is followed step by step. |
The Following 2 Users Say Thank You to GalaxyVibe For This Useful Post: |
01-25-2017, 06:50 | #9 (permalink) |
Member: 2577670 Status: Offline Thanks Meter: 883 | There is another dialer for removing the FRP lock. It is called "FRP Fast Call". This computer program should make the call for the FRP removal easier than Realterm. Here is a link posted by "birindar" (Thank you birindar for your link): http://www.phonica.one/media/FRP%20C...BIRINDAR)).zip Last edited by GalaxyVibe; 01-25-2017 at 06:56. |
The Following 12 Users Say Thank You to GalaxyVibe For This Useful Post: |
01-28-2017, 01:27 | #10 (permalink) | |
Member: 2577670 Status: Offline Thanks Meter: 883 | Quote:
14. Try by downloading the Quick Shortcut Maker apk from the link below: https://quickshortcutmaker.en.uptodown.com/android 15. Copy the apk from your computer to an SdCard. Slice in the SD card in your phone. 16. Open the ES Files program and search for the "Quick Shortcut Maker apk" in your SD Card. 17. Install it in your phone and open the apk. After opening the Quick Shortcut Maker apk, search on the search bar of it "Google Account Manager". 18. Then scroll down and select: Google Account Manager Type Email and Pasword com.google.android.gsf.login/ com.google.android.gsf.login.EducLoginActivity 19. Then, select 'Try" 20. The App will send you to the "Google Sign In" windows. DO NOT SING IN. Click on the three dots at the upper right hand side of the screen and click on "BROWSER SIGN IN". Then a new Google browser sign in screen will appear. Yes, you can Sign in there with your existing Google account (Again, do not worry, you can remove it later). Once you are signed in, you need to restart your phone. 21. Follow the setup instructions. The phone is not going to ask you for the Google account because you already entered. 22. Once at the home screen, click on 'Settings". Then go to "Accounts” and click on the "Samsung Account", click on "Remove Account". The phone is going to ask you for a confirmation to enter your password. Enter it and click on Remove. Go back and click on your "Google Account". Click on "Remove Account". 23. Go back to settings, and then click on "BACKUP AND RESET". Then click on "FACTORY DATA RESET". Then "RESET DEVICE". The phone will factory reset and the FRP will be removed. DO NOT FORGET TO CLICK ON THE THANKS BOTTON | |
The Following 7 Users Say Thank You to GalaxyVibe For This Useful Post: |
01-29-2017, 03:24 | #11 (permalink) |
Freak Poster Join Date: Jul 2012 Location: UK
Member: 1779384 Status: Offline Thanks Meter: 13 | worked for me thanks. s7 edge on 6.0.1 frp successfully turned off. many thanks followed instructions at the top of this thread |
The Following User Says Thank You to bigclive33 For This Useful Post: |
02-04-2017, 19:41 | #13 (permalink) |
Member: 2577670 Status: Offline Thanks Meter: 883 | The Member "bigclive33" posted in this thread: "Worked for me thanks. s7 edge on 6.0.1 frp successfully turned off. many thanks. Followed instructions at the top of this thread" I personally used this method in many phones mentioned in the mai n post of this thread including A Galaxy S7 Edge for Sprint SM-G935P 6.0.1, Galaxy S7 for MetroPCS SM-G930T1 6.0.1, Galaxy S7 Edge for T-Mobile SM-G935T 6.0.1 Marshmallows and the FRP was removed in all of them using this method. Try it, it is safe and secure. No BOX needed. No Sboot or Combination files needed. Just follow the instruction step by step. |
02-04-2017, 22:09 | #14 (permalink) |
Insane Poster Join Date: Jul 2013
Member: 1978553 Status: Offline Thanks Meter: 1 | ok still trying. use the new dialer once and it work but kick out. tried again but nothing. whats the best way to reset everything and start again. thanks for the input. |
The Following User Says Thank You to day52007 For This Useful Post: |
