Old 12-01-2009, 03:45   #1 (permalink)
Member: 1152345
Thanks Meter: 9
no interface found
Please help!
I've just bought the z3x box, after activating the box, i run the qualcomm tool and plug the phone, click search, it says samsung qualcomm interface not found. Please show me step by step how to set up z3x box. thanks so much
Old 12-01-2009, 09:04   #2 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,558
Originally Posted by gsm28 View Post
Please help!
need connect phone first
Old 12-01-2009, 19:30   #3 (permalink)
Member: 1152345
Thanks Meter: 9
z3x team please help
how to use qualcomm tool? do i need to install dirver for phone before doing anything?
Old 12-01-2009, 19:45   #4 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
yes of course.
if you want work 1st choice models.
each models have different way for unlock, method.
When phone come to your hand, try unlock, if not success - use search button. 90% already discuss in forum.
Old 12-01-2009, 21:23   #5 (permalink)
Member: 1152345
Thanks Meter: 9
Here detail info about account, i'm not sure the box is full activated or not.
when i run shell , click on card update tap, then click on wizard to read info about my account, then it gets the result below:
-samsung activation (activated 2009-11-10 added 2009-11-28)
-samsung qualcomm tool (extra) not available
-lg tooll not available
what calbe should i use , is it the calbe 2 in 1? if i use this cable , do i have to plug usb and RJ45 to the box's port at the same time? Please tell me step by step . Pleaseeeeeeeeeeeeeeee!!!!!!!!!!!!!!!!!
Old 12-01-2009, 21:28   #6 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
your box is samsung box only.
full activated z3x box price arround 600 usd.
i told different phone differrent type of cable and instruction for unlock.
when you got phone in hand - check model and search something for this model in forum, before you will ask and will open new tread.
Old 12-02-2009, 01:02   #7 (permalink)
Member: 1152345
Thanks Meter: 9
My box is samsung edition, before i bought this one from unlockcellular seller, i looked at the specs to decide buying it. I see it cover many qualcomm models that i have in hand from my customers. Could you please tell me what's different between edition and extra?
Old 12-02-2009, 01:09   #8 (permalink)
Member: 1152345
Thanks Meter: 9
One more thing now i don't see samsung tool .exe after run shell and update card. only qualcomm and smartphone tool .exe been installed. Please helpppppppppppp!
Old 12-02-2009, 07:28   #9 (permalink)
gsmdok's Avatar
Member: 546406
Thanks Meter: 71
re download from support manually
Old 12-02-2009, 12:00   #10 (permalink)
Member: 1152345
Thanks Meter: 9
Mr Blang
Please read massages above! I'm so confused about this box, when i run the qualcomm tool, a lot models supported in select model drop down menue.
Ex: I connect the phone F480 to RJ45, nothing happen when i click search phone(samsung qualcomm interface not found), what is this issue?
Which port to be used? usb port or RJ45? If usb port, it asks for phone dirver, i did installed driver for it from c:\program file\z3x\samsung but could not go through.
If you need more info about box and my account, i'll give you in pv message.
Old 12-02-2009, 12:09   #11 (permalink)
umadineshdas's Avatar
Member: 306096
Sonork: 100.1585877
Thanks Meter: 255
you also use usb+rj45 then you look a modem driver install and then look your phone detected with the box then do anything as you want.
post you full log.....................please.................... ............
Old 12-02-2009, 12:55   #12 (permalink)
Member: 1152345
Thanks Meter: 9
please read messages above, i did try to conect rf45 and usb same time, but could not install driver for phone from c\program\z3x\samsung, what else do i install from? there's no model in samsung folder.
Old 12-02-2009, 17:33   #13 (permalink)
Member: 1152345
Thanks Meter: 9
Mr Blang
Please read massages and give me the answer
Old 12-02-2009, 18:20   #14 (permalink)
Member: 1152345
Thanks Meter: 9
helpppppppppppppppppppppppppppppppppp!
Old 12-02-2009, 18:52   #15 (permalink)
Member: 1152345
Thanks Meter: 9
where is the z3x team? where's the product manager? need helppppppppppppppppppp
No interface connected please select interface and connect first ! lohan MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 12-14-2009 06:04
no interface found gsm28 Samsung Hardware Repair 0 12-01-2009 02:20
nokia 7360 says no access/no network found peraltech Nokia Hardware & Hardware Repair 8 08-16-2009 15:56
Nokia 6233 NO Signal and no oprator Found..? communication_expert Nokia Hardware & Hardware Repair 3 06-30-2008 14:25
Page generated in 0.20982 seconds with 9 queries
