12-01-2009, 03:45 | #1 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1152345 Status: Offline Thanks Meter: 9 | no interface found I've just bought the z3x box, after activating the box, i run the qualcomm tool and plug the phone, click search, it says samsung qualcomm interface not found. Please show me step by step how to set up z3x box. thanks so much |
12-01-2009, 19:45 | #4 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,550 | Quote:
if you want work 1st choice models. each models have different way for unlock, method. When phone come to your hand, try unlock, if not success - use search button. 90% already discuss in forum. | |
12-01-2009, 21:23 | #5 (permalink) |
Member: 1152345 Status: Offline Thanks Meter: 9 | Here detail info about account, i'm not sure the box is full activated or not. when i run shell , click on card update tap, then click on wizard to read info about my account, then it gets the result below: -samsung activation (activated 2009-11-10 added 2009-11-28) -samsung qualcomm tool (extra) not available -lg tooll not available -......... what calbe should i use , is it the calbe 2 in 1? if i use this cable , do i have to plug usb and RJ45 to the box's port at the same time? Please tell me step by step . Pleaseeeeeeeeeeeeeeee!!!!!!!!!!!!!!!!! |
12-01-2009, 21:28 | #6 (permalink) | |
full activated z3x box price arround 600 usd. i told different phone differrent type of cable and instruction for unlock. when you got phone in hand - check model and search something for this model in forum, before you will ask and will open new tread. | |
12-02-2009, 01:02 | #7 (permalink) |
Member: 1152345 Status: Offline Thanks Meter: 9 | My box is samsung edition, before i bought this one from unlockcellular seller, i looked at the specs to decide buying it. I see it cover many qualcomm models that i have in hand from my customers. Could you please tell me what's different between edition and extra? |
12-02-2009, 12:00 | #10 (permalink) |
Member: 1152345 Status: Offline Thanks Meter: 9 | Mr Blang Please read massages above! I'm so confused about this box, when i run the qualcomm tool, a lot models supported in select model drop down menue. Ex: I connect the phone F480 to RJ45, nothing happen when i click search phone(samsung qualcomm interface not found), what is this issue? Which port to be used? usb port or RJ45? If usb port, it asks for phone dirver, i did installed driver for it from c:\program file\z3x\samsung but could not go through. If you need more info about box and my account, i'll give you in pv message. |
12-02-2009, 12:09 | #11 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Kolkata,Kathmandu,
Member: 306096 Status: Offline Sonork: 100.1585877 Thanks Meter: 255 | you also use usb+rj45 then you look a modem driver install and then look your phone detected with the box then do anything as you want. post you full log.....................please.................... ............ |
12-02-2009, 12:55 | #12 (permalink) |
Member: 1152345 Status: Offline Thanks Meter: 9 | please read messages above, i did try to conect rf45 and usb same time, but could not install driver for phone from c\program\z3x\samsung, what else do i install from? there's no model in samsung folder. |
No interface connected please select interface and connect first ! | lohan | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 12-14-2009 06:04 |
no interface found | gsm28 | Samsung Hardware Repair | 0 | 12-01-2009 02:20 |
nokia 7360 says no access/no network found | peraltech | Nokia Hardware & Hardware Repair | 8 | 08-16-2009 15:56 |
Nokia 6233 NO Signal and no oprator Found..? | communication_expert | Nokia Hardware & Hardware Repair | 3 | 06-30-2008 14:25 |
