GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Z3X-Team Products (https://forum.gsmhosting.com/vbb/f453/)
-   -   no interface found (https://forum.gsmhosting.com/vbb/f453/no-interface-found-871137/)
gsm28 12-01-2009 03:45
no interface found
Please help!
I've just bought the z3x box, after activating the box, i run the qualcomm tool and plug the phone, click search, it says samsung qualcomm interface not found. Please show me step by step how to set up z3x box. thanks so much
blang 12-01-2009 09:04
Originally Posted by gsm28 (Post 5093142)
Please help!
need connect phone first
gsm28 12-01-2009 19:30
z3x team please help
how to use qualcomm tool? do i need to install dirver for phone before doing anything?
blang 12-01-2009 19:45
yes of course.
if you want work 1st choice models.
each models have different way for unlock, method.
When phone come to your hand, try unlock, if not success - use search button. 90% already discuss in forum.
gsm28 12-01-2009 21:23
Here detail info about account, i'm not sure the box is full activated or not.
when i run shell , click on card update tap, then click on wizard to read info about my account, then it gets the result below:
-samsung activation (activated 2009-11-10 added 2009-11-28)
-samsung qualcomm tool (extra) not available
-lg tooll not available
what calbe should i use , is it the calbe 2 in 1? if i use this cable , do i have to plug usb and RJ45 to the box's port at the same time? Please tell me step by step . Pleaseeeeeeeeeeeeeeee!!!!!!!!!!!!!!!!!
blang 12-01-2009 21:28
your box is samsung box only.
full activated z3x box price arround 600 usd.
i told different phone differrent type of cable and instruction for unlock.
when you got phone in hand - check model and search something for this model in forum, before you will ask and will open new tread.
gsm28 12-02-2009 01:02
My box is samsung edition, before i bought this one from unlockcellular seller, i looked at the specs to decide buying it. I see it cover many qualcomm models that i have in hand from my customers. Could you please tell me what's different between edition and extra?
gsm28 12-02-2009 01:09
One more thing now i don't see samsung tool .exe after run shell and update card. only qualcomm and smartphone tool .exe been installed. Please helpppppppppppp!
gsmdok 12-02-2009 07:28
re download from support manually
gsm28 12-02-2009 12:00
Mr Blang
Please read massages above! I'm so confused about this box, when i run the qualcomm tool, a lot models supported in select model drop down menue.
Ex: I connect the phone F480 to RJ45, nothing happen when i click search phone(samsung qualcomm interface not found), what is this issue?
Which port to be used? usb port or RJ45? If usb port, it asks for phone dirver, i did installed driver for it from c:\program file\z3x\samsung but could not go through.
If you need more info about box and my account, i'll give you in pv message.
umadineshdas 12-02-2009 12:09
you also use usb+rj45 then you look a modem driver install and then look your phone detected with the box then do anything as you want.
post you full log.....................please.................... ............
gsm28 12-02-2009 12:55
please read messages above, i did try to conect rf45 and usb same time, but could not install driver for phone from c\program\z3x\samsung, what else do i install from? there's no model in samsung folder.
gsm28 12-02-2009 17:33
Mr Blang
Please read massages and give me the answer
gsm28 12-02-2009 18:20
helpppppppppppppppppppppppppppppppppp!
gsm28 12-02-2009 18:52
where is the z3x team? where's the product manager? need helppppppppppppppppppp
Page generated in 0.14156 seconds with 6 queries
