01-07-2017, 08:22 | #1 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2669737 Status: Offline Thanks Meter: 0 | No permite escribir cert j200m version 5.1.1 binario=2 BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Write CERT Selected model: SM-J200M Software version: 27.7 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-J200M Android version: 5.1.1 Product code: SM-J200MZWAPET Phone version: J200MUBU2API3 PDA version: J200MUBU2API3 CSC version: J200MUWA2API3 CSC country code: PERU CSC sales code: PET HW version: MP 0.300 Phone SN: 00000000000 Chip name: EXYNOS3475 Modem board: SHANNON308 RF cal date: 20160119 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... Ok Modem board: SHANNON308 HWID: 4B 6C 38 39 59 B4 FE 63 9F 61 D7 CC 77 C6 BF 80 Calculating... Ok Initialization AT RIL... AT RIL stopped, restarting... error (0) Done with Samsung Tool PRO v.27.7 Ayuda por favor. |
01-29-2017, 00:34 | #9 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2410859 Status: Offline Thanks Meter: 0 | Tengo el mismo problema, no me deja ni siquiera RESET MSL... Searching Samsung modem... detected COM533 Reading phone info... Ok Model: SM-J200M AP version: J200MUBU2API2 CSC version: J200MUUB2API2 CP version: J200MUBU2API2 Product code: SM-J200MZKVARO Phone SN: R28H31L27ZF Unique number: CFN009806D3F723 Reading IMEI... Ok IMEI: 356514074717281 (SIGN: OK) Reseting MSL... error (0) Done with Samsung Tool PRO v.27.7 |
