09-19-2015, 21:42 | #1 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2455416 Status: Offline Thanks Meter: 0 | Note 3 N900W8 problem with driver installation I want to unlock my N900W8 with the direct unlock option from z3x. But when I put it in DM-Modem-ADB mode, all my computers (because itred 3 different one) are not recognizing the cellphone. It's shows as Unknow Device. Please help! Thanks |
09-19-2015, 23:07 | #2 (permalink) |
No Life Poster Join Date: Oct 2011 Location: ireland Age: 46
Member: 1670851 Status: Offline Thanks Meter: 267 | did u tried to enable CP logging in recovery menu?? if not possible, choose activate diag in samsung tool in "repair"tab first then repeat unlock process |
04-09-2016, 18:32 | #6 (permalink) |
Freak Poster Join Date: Dec 2003 Location: www.cprauctions.com Age: 57
Member: 46347 Status: Offline Thanks Meter: 5 | This is the log UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC'. 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-N9008 Selected port: COM9 USB Serial Port Software version: 25.1 Reading phone info... Reading IMEI... OK IMEI: 0 Unlocking... error (1) Done with Samsung Tool PRO v.25.1 |
