09-08-2014, 05:26 | #1 (permalink) |
Freak Poster Join Date: May 2012
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 27 | note 3 sm-n900w8 no baseband after read qn file i read the qcn file and after restart no more baseband or imei tried to write the backup but have this error Selected model: SM-N900W8 Selected port: COM81 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Checking phone at COM81 Detected ID: 00000FF3 (MSM8974) SW Version: Reading ESN... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping Provisioning Item Files... OK Done with Samsung Tool v.18.1 Selected model: SM-N900W8 Selected port: COM81 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading QCN file... OK Checking phone at COM81 Detected ID: 00000FF3 (MSM8974) SW Version: Checking paths... error Done with Samsung Tool v.18.1 Selected model: SM-N900W8 Selected port: COM81 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching Samsung modem... detected COM80 Reading phone info... Software version: =1,1 IMEI: Done with Samsung Tool v.18.1 it's the same backup. the good one always it show me a port in the top (lie now cop81 but found modem on com80) the phone was unlocked by code, working well just did a qcn backup (rooted and knox disabled) |
09-08-2014, 14:21 | #4 (permalink) |
Member: 1754412 Status: Offline Sonork: 100.1620116 Thanks Meter: 27 | i flashed the phone with same firmware same problem i don't want right now to try the cert because is still the original and unlocked wait solution thanks |
09-08-2014, 20:38 | #14 (permalink) |
No Life Poster Join Date: Jul 2009 Location: PAKISTAN Age: 34
Member: 1082907 Status: Offline Sonork: 100.1606954 Thanks Meter: 342 | read this carefully what said blang We have releasing today new functions for some type of phones called: 1 CERT reading for Exynos based phones, 2 CERT writing for Exynose & Qualcomm based phones, 3 WIPE efs for Quaclomm based phones. and Small FAQ: q> Can i use i9500 CERT for N900x? a> No you can’t. you can use only same phone models certificate!!!! BUT you can use N900 CERT for N900x models!!! Autodetect CETRT compatibility exist, if CERT file compatible you will see this line in log: Checking for compatible phone and cert... OK q> Why unlock button for NEW QUALCOMM PHONES not active? a> You can’t unlock phone now using normal method BUT if you will wipe phone and write any CERF from working phone you will have fully unlocked phone with network and imei (from CERT). q>Why IMEI REPAIR button for NEW QUALCOMM PHONES not active? a>You can’t repair imei on NEW phones using normal method BUT You can WIPE phone and write any CERT and your phone will fully working. q>What will be if i will flash phone after write CERT.? a> ALl will be ok with phone, CERT writing original method for get working phone without any patching. q>Exist some new GT-i9500 which can’t be repaired using regular method, new solution useful for this? a>Yes useful but only if you have needed CERT, at least you can use any i9500 CERT to get working phone. q>I have CERT FAIL on SM-G900H any solution useful for this? a>Yes but only if you have needed CERT, at least you can use any working good CERT from SM-G900H. q>Why need CERT read/write for such old phones like i9300? a>If you will write CERT, phone will not lost network after update firmware. q> Where i can get/buy/generate CERT for my phone with MY phone imei inside? a> You cant generate this. You can try get from any sams insiders or buy from sams insiders. WE NOT SELLING ANY CERT FILES AND CAN'T CREATE THIS FILES!!! its UNIUE i think after read it clear your mind |
09-08-2014, 21:27 | #15 (permalink) |
No Life Poster Join Date: Mar 2008 Location: Kanada
Member: 737720 Status: Offline Thanks Meter: 1,421 | U read agian dear read this part you can use N900 CERT for N900x models!!! Autodetect CETRT compatibility exist, if CERT file compatible you will see this line in log: Checking for compatible phone and cert... OK If cert file compatible it means if not u can't write. Which u will see it not bcs n900w8 is Deffrent model. |
