01-21-2017, 23:58 | #46 (permalink) | |
No Life Poster Join Date: May 2016
Member: 2577670 Status: Offline Thanks Meter: 883 | Quote:
http://forum.gsmhosting.com/vbb/f453...l#post12294530 | |
The Following User Says Thank You to GalaxyVibe For This Useful Post: |
03-30-2017, 16:50 | #48 (permalink) |
Crazy Poster Join Date: May 2016
Member: 2569608 Status: Offline Thanks Meter: 63 | N910 reactivation lock here are the steps to remove reactivaton lock on all n910 models easy. 1. download and flash a combination 2. download galaxy apps apk and install it via adb 3. connect to wifi on combination, make sure date and time is set to automatic. 4. click on the newly installed galaxy apps icon and sign into a pre existing samsung account. 5. put the phone in download mode and flash back stock. 6. extract the modem from the combination file you just flashed. once your phone is at welcome screen, put the phone back in download mode and flash the MODEM you extracted from the combination. 7. once it flashes and its back and welcome screen, connect to wifi and go through setup. 8. then it will ask for samsung account. sign into the one you used on the combination. 9. once your at home screen go to settings and do a factory reset. 10. now flash back stock MODEM and go through setup wizard and it will not ask for samsung account. for those who do not know how to install an apk with adb do this. 1. on the combination file go to ABOUT DEVICE, tap on build number until it says developer options has been enabled. then hit the back button and go into developer options. 2. turn on usb debugging. 3. download the galaxy apps apk and place it into your adb folder. ( i would rename the apk to make it easy because when you download the apk it has a long name. just use like 3 letters ) 4. inside the adb folder hold shift and right click. 5. then click on open new command window here 6. now type "adb devices' 7. if it shows "device" then your good 8. now type adb install "galaxy apps.apk ( or what ever you named the apk file ) let it say success and it is now installed if this helped you please press thanks |
The Following 13 Users Say Thank You to jrotc1sg For This Useful Post: |
04-28-2017, 21:27 | #50 (permalink) | |
Major Poster Join Date: May 2016
Member: 2574656 Status: Offline Thanks Meter: 8 | Quote:
08-14-2017, 05:41 | #52 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 307625 Status: Offline Thanks Meter: 25 | GalaxyVibe i have samsung N910A 6.0.1 i did try every method on this forum and web side no success ,,the only way to remove reactivation account is via GSPN PROGRAM CALLED SAMSUNG CAPTURE TOOL if aim wrong please correct me........... |
11-22-2017, 13:02 | #54 (permalink) | |
Freak Poster Join Date: Dec 2006 Location: Khartoum-Sudan
Member: 420318 Status: Offline Sonork: 100.1661057 Thanks Meter: 65 | Quote:
the new account remain after format but this is not a problem at all | |
02-16-2019, 09:02 | #56 (permalink) |
Freak Poster Join Date: Feb 2010 Location: sharjha
Member: 1236922 Status: Offline Sonork: sajer007 Thanks Meter: 101 | Using Version...1.0.0.0062 Selected Port USB Serial Port COM17 Selected Model Samsung GSM Selected Task SAMSUNG RLOCK_ADB Searching ADB device Please wait.. Device Detected... SELinux := Enforcing model:= SM-N910V Android Version:= 5.1.1 Description Version:= trltevzw-user 5.1.1 LMY47X N910V****** release-keys Platform:= apq8084 [ qcom ] [ MDM9625M ] Baseband:= N910V******* VER:= N910VV************* Carrier := VZW_USA EFS CSC := VZW Knox Warranty := Not Void AP UART Status := Disable. Security Patch := 01-12-2015 ABI:= armeabi-v7a SDK Ver:= 22 Simstatus:= READY ANDROID-ID = de245785_0000A66824 SU Version..kingo 141 Device is Secure Rooted..uid=0 System Permission is Read/Write... SAMSUNG RLOCK_ADB UNLOCK STARTED... Starting RLOCK Remove. Phone Found Wait... Model := SM-N910V SWVer := N910VV****** UNIQID := CR200DE24578522 Phone IMEI := 9900****** REACTIVATION LOCKED... Fail to get reply for task2..NY7RDYQwDENXqilN4BMkWMP7b3G2dUhR1DgvdtfB9bI GsbNUzUJqj1KsO6IAEHpcGcuKV+O/rfU9BEzfooJt7hj2tIN8ZphkSTGDKHf8OycrWLvbCh+fLWLlRC TlYj/W3RX0GtORfhd0eh7s0/Pksf0A Please Reflash such phone... !!! success !!!! Total Time Take...00:01:59 Log Saved |
10-02-2019, 12:38 | #57 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2667139 Status: Offline Sonork: [email protected] Thanks Meter: 0 | |
