09-11-2016, 14:13 | #1 (permalink) |
No Life Poster Join Date: Oct 2008 Location: PAKISTAN
Member: 882981 Status: Offline Sonork: 161363 Thanks Meter: 306 | Note 4 sm-n910k imei 000000000 write cert error 5.1.1 WRITE CERT ERROR BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-N910K Selected port: COM160 RIM Virtual Serial Port v2 Software version: 26.6 Waiting ADB device... OK Reading phone info... Model: SM-N910K Android version: 5.1.1 Product code: Phone version: N910KKTU0DPD2 PDA version: N910KKTU1COI2 CSC version: N910KKTC1COI2 CSC country code: KOREA CSC sales code: KTC HW version: Phone S/N: 00000000000 Modem board: SS303 RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 17 00 00 EA 11 F1 A0 E3 21 F1 A0 E3 31 F1 A0 E3 Checking certificate file... OK KEY ID: 0451 Detected modem type currently is not supported Done with Samsung Tool PRO v.26.6 |
