Old 05-08-2015, 03:18   #1 (permalink)
OscarR87's Avatar
Member: 2213954
Thanks Meter: 39
Note 4 Verizon N910V Cert Done
Checking certificate file... OK
KEY ID: 0772
Waiting ADB device...
Please, allow USB debugging on phone... OK
Reading phone info...
Model: SM-N910V
Android version: 5.0.1
Product code: Not Active
Phone version: N910VVRU1BOAF
PDA version: N910VVRU1BOAF
CSC version: N910VVZW1BOAF
CSC country code: USA
CSC sales code: VZW
HW version: N910V.05
Phone S/N: 00000000000
Modem board: MDM9625M
RF cal date: 2014.10.28
IMEI:
Initialization AT RIL... OK
Bypass MSL... OK
Checking for compatible phone and cert... OK
Phone KEY ID: 0772
Writing CERT... OK
Checking CERT status... OK
Rebooting phone... OK
Done with Samsung Tool v.20.5
Got 4G LTE and Network working on the device.
Image for Proof
The Following 2 Users Say Thank You to OscarR87 For This Useful Post:
Old 05-10-2015, 04:57   #2 (permalink)
Member: 755471
Thanks Meter: 18
Which model you select on z3x?
Old 05-10-2015, 08:05   #3 (permalink)
maxpro12's Avatar
Member: 1369772
Thanks Meter: 297
Look at LOG, selected Model: SM-N910V
Old 05-10-2015, 14:55   #4 (permalink)
Member: 755471
Thanks Meter: 18
But in Z3x no SM-N910V
Old 05-11-2015, 00:02   #5 (permalink)
Member: 1105429
Thanks Meter: 118
SM-N910V is not in the supported list.. are you positive?
Old 05-11-2015, 01:02   #6 (permalink)
Member: 90682
Thanks Meter: 21
Fixed VERIZON Note 4 N910V with CERT to work with TMOBILE or AT&T 4G LTE?
Anyone have issue with VERIZON Note 4 N910V both WIFI & TMOBILE 4G LTE dropping connections ON & OFF?
Any quick fix or flash QCN fix this issue for VERIZON Note 4 N910V on TMOBILE 4G LTE Network?
Old 05-11-2015, 01:44   #7 (permalink)
shedeed's Avatar
Member: 527884
Sonork: 100.1583794
Thanks Meter: 850
you just Need Tested QCN Read It From Working Device
Old 05-11-2015, 07:50   #8 (permalink)
Member: 755471
Thanks Meter: 18
so what is Verizon note 4 16 digit password?
Old 05-11-2015, 22:45   #9 (permalink)
OscarR87's Avatar
Member: 2213954
Thanks Meter: 39
Yes it is working great with T-Mobile Simcard and AT&T simcard, no need for QCN after flashing.
Old 05-24-2015, 23:07   #10 (permalink)
Member: 1994657
Thanks Meter: 93
how did you root the phone?
Old 05-25-2015, 02:18   #11 (permalink)
Member: 2076039
Thanks Meter: 648
If you PROPERLY repair the IMEI on a Verizon device you don't need to write a working QCN to it. If you've wiped the EFS on a Verizon device, you've done it wrong.
The Following User Says Thank You to ecs87 For This Useful Post:
Old 05-25-2015, 02:26   #12 (permalink)
Member: 2183509
Thanks Meter: 68
After writing cert to a verizon Note 4, do I have to match MEID with IMEI using DFS Tool? Or it works perfect just after writing a new cert? Thanks
Old 05-25-2015, 22:33   #13 (permalink)
OscarR87's Avatar
Member: 2213954
Thanks Meter: 39
I always match it and it seems to work for me. So I would have to say...Yes, match the MEID to the IMEI.
The Following User Says Thank You to OscarR87 For This Useful Post:
Old 05-25-2015, 23:57   #14 (permalink)
toutanje's Avatar
Member: 945085
Thanks Meter: 70
does anyone else get problem when using at&r or one of their mvno on verizon samsung device with the "+" coming with incoming calls? tmobile network seem fine just at&t and its mvno has this problem...
Old 05-26-2015, 00:24   #15 (permalink)
Member: 2183509
Thanks Meter: 68
I have a G900V that I wrote a new cert to, but it wont get any service. I tried to match MEID to the IMEI using DFS CDMA tool, but nothing has changed on the IMEI part. Still the same. It seems the changes doesnot apply at all. I must be doing something wrong or missing something.
Any body would care giving a step by step instructions on how to match MEID to IMEI using DFS tool so I/We can get signal on verizon phones, that would be very helpful. Thanks a lot guys!
Page generated in 0.22281 seconds with 9 queries
