03-14-2017, 19:58 | #1 (permalink) |
Major Poster Join Date: Jan 2014 Location: USA
Member: 2107135 Status: Offline Thanks Meter: 6 | Note 5 No signal Help needed I got the IMEI fixed. I got it back to PK1. Its unrooted, and all stock. It reads a SIM Card, but can not connect to Network. IMEI is a clean IMEI on both AT&T and T-Mobile. Now it just can not get signal. I am out of ideas of what to try now. Seeing if any of you have a suggestion. |
03-15-2017, 04:25 | #4 (permalink) |
Member: 2107135 Status: Offline Thanks Meter: 6 | I used a CERT from another N920A that I had laying around didn't patch it. Never had to before when using a valid cert. Just did the *#0011# IMEI shows: NG But its not Null when i do the *#06#. |
03-15-2017, 05:36 | #5 (permalink) |
Member: 2107135 Status: Offline Thanks Meter: 6 | Thanks for your help there. That just makes me feel like a jackass. Never had this happen to me yet. If anyone is having this issue, and want to know the fix for IMEI: NG: 1. Shoot the Factory Combination file on it. (or root it) 2. Re-flash the Certificate. 3. Reboot 4. check IMEI and *#0011# if its ok. Thats all you have to do. You might need to repeat it a few times, but you will get it after a bit. |
03-15-2017, 05:42 | #6 (permalink) | |
Freak Poster Join Date: Aug 2007
Member: 558861 Status: Offline Thanks Meter: 26 | Quote:
flash with combination file fix imei with certi file than reflash with stock rom you will bee fine | |
