08-02-2017, 05:40 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Basirhat
Member: 1134419 Status: Offline Sonork: 100.1621725 Thanks Meter: 452 | NOTE 5 (SM-N920TZKATMB) T-Mobile FRP I need solution of NOTE 5 (T-MOBILE) FRP. WITH Z3X PRO IF I ATTEMPT " Reset FRP/React/EE " with download mode, set stuck on download mode but software showing unlock ok , after restart the set now set showing " A error occored while updating......." I downloaded firmware and after flash set is on but still FRP. Need solution |
08-02-2017, 06:50 | #2 (permalink) |
Freak Poster Join Date: Sep 2011
Member: 1659385 Status: Offline Sonork: 100.1678591 Thanks Meter: 115 | Easy if you use UART Cable. Turn phone off Connect Cable Select Port Select Reset FRP/UFS Press vol down and power as soon as you see the message Release Power When tool tells you then release vol down. Done in seconds. Operation: Reset FRP UFS Selected model: SM-N920T Selected port: COM15 Z3X BOX Serial Port Software version: 29.0 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM15 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (N920T) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done This was done on 7.0 Firmware. |
The Following User Says Thank You to jcdes For This Useful Post: |
08-02-2017, 21:18 | #5 (permalink) |
Member: 1659385 Status: Offline Sonork: 100.1678591 Thanks Meter: 115 | All N920T are TMO that is why it has the "T". Cable is C330K is has been discussed in the update thread. |
08-03-2017, 07:28 | #6 (permalink) |
Member: 1134419 Status: Offline Sonork: 100.1621725 Thanks Meter: 452 | Thanks " jcdes " for your help . I sucessfully unlocked FRP of that set Here is log................... Operation: Reset FRP UFS Selected model: SM-N920T Selected port: COM3 Z3X BOX Serial Port Software version: 29.0 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM3 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (N920T) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.29.0 |
