08-03-2017, 23:28 | #3 (permalink) |
Freak Poster Join Date: Aug 2013 Location: in ur mind
Member: 2014880 Status: Offline Sonork: 100.1673441 Thanks Meter: 26 | sm-t377w now u can unlock and remove frp with z3x pro without adb t377 now u can unlock and remove frp[ with z3x pro without adb just open 29.0 select model j510f 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE Done with Samsung Tool PRO v.29.0 no need any conbination files too |
The Following 6 Users Say Thank You to julius1461 For This Useful Post: |
03-17-2018, 17:30 | #6 (permalink) |
Freak Poster Join Date: Nov 2012 Location: batna.algeria
Member: 1834802 Status: Offline Sonork: 100.1659078 Thanks Meter: 89 | it work's for me T377WVLU2API2 ANDROID 6.0.1 eration: Reset FRP/React/EE Selected model: SM-J510F Software version: 30.2.2 Searching Samsung USB Flash interface... COM38 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.2.2 |
04-27-2018, 17:21 | #7 (permalink) |
Junior Member Join Date: May 2016
Member: 2579290 Status: Offline Thanks Meter: 3 | Works for me on SM-T377W using 6.0.1 Operation: Reset FRP/React/EE Selected model: SM-J510F Software version: 30.4 Searching Samsung USB Flash interface... COM11 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.30.4 |
09-02-2018, 09:08 | #8 (permalink) |
Junior Member Join Date: Apr 2004 Age: 44
Member: 62465 Status: Offline Thanks Meter: 4 | FRP Unlock SM-T377W, Unsuccessful on 7.1.1 ? [need more info] "FRP Unlock SM-T377W, Unsuccessful on 7.1.1 ? Help Please" I have SM-T377W with 7.1.1 I tried to flash it with this COMBINATIONS firmware COMBINATION_OYA_FA60_T377WVLU3ARG1 Then I used the Z3x Tool to reset FRP, it says "OK" however, then when I put it again on Download mode it is still Locked FRP Also when I re-flash it with OEM it still ask for Google Verification I also tried to flash it with TWRP to Root it but I keep getting Custom Binary Block by FRP Lock IS THERE A WAY TO REMOVE FRP FROM THIS DEVICE ? --------- OEM flash in this device is ---------- Canada (Rogers) PDA: T377WVLU3BRG4 Product Code: RWC CSC: T377WOYA3BRG4 Phone: T377WVLU3BRG4 ------------------------------------- Any Suggestions Guys ? Regards |
09-02-2018, 11:46 | #9 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
10-22-2019, 18:27 | #10 (permalink) |
Junior Member Join Date: Nov 2011 Location: Ghana
Member: 1685613 Status: Offline Thanks Meter: 0 | Works for me too Operation: Reset FRP/React/EE Selected model: SM-J510F Selected port: COM1 Communications Port Software version: 37.0 Searching Samsung USB Flash interface... COM52 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.37.0 |
11-09-2019, 16:38 | #11 (permalink) |
No Life Poster Join Date: Jul 2013 Location: in my company
Member: 1984825 Status: Offline Thanks Meter: 222 | Operation: Reset FRP/React/EE Selected model: SM-J510F Software version: 38.2 Searching Samsung USB Flash interface... COM8 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.38.2 |
