04-27-2016, 16:15 | #1 (permalink) |
No Life Poster Join Date: Mar 2010
Member: 1271541 Status: Offline Thanks Meter: 35 | patch certificate Running zTool, please wait... error (7.7.8) ?? Operation: Patch Certificate Selected model: SM-G920F Software version: 25.2 Waiting ADB device... OK Reading phone info... Model: SM-G920F Android version: 6.0.1 Product code: Phone version: G920FXXU3DPBT PDA version: G920FXXS3DPD5 CSC version: G920FOJV3DPC1 CSC country code: MOROCCO CSC sales code: MWD HW version: Phone S/N: RF8G41VJARM Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... error (7.7.8) Current version can not be patched Done with Samsung Tool PRO v.25.2 |
04-27-2016, 16:17 | #2 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Downgrade modem andit should work Sent from my GT-I9500 using Tapatalk |
The Following User Says Thank You to souma_k For This Useful Post: |
04-27-2016, 17:20 | #3 (permalink) |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 417 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-G920I Software version: 25.2 Waiting ADB device... OK Reading phone info... Model: SM-G920I Android version: 6.0.1 Product code: Phone version: G920IDVU3EPC3 PDA version: G920IDVU3EPC6 CSC version: CSC country code: CSC sales code: HW version: Phone S/N: 00000000000 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... error (7.7.8) Current version can not be patched Done with Samsung Tool PRO v.25.2 same mistake in g925i |
04-27-2016, 17:22 | #4 (permalink) | |
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Quote:
Sent from my GT-I9500 using Tapatalk | |
04-28-2016, 17:23 | #9 (permalink) |
Member: 2235684 Status: Offline Thanks Meter: 417 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Repair DRK (Use it if you have DRK damaged (phone stuck on boot)): 1. Power on phone in download mode (turn off phone, hold vol.down + Camera + Power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Repair DRK' button. Operation: Patch Certificate Selected model: SM-G920I Software version: 25.2 Waiting ADB device... OK Reading phone info... Model: SM-G920I Android version: 5.1.1 Product code: Phone version: G920IDVU3DOJ6 PDA version: G920IDVU3DOJ6 CSC version: G920IOLC3DOJ6 CSC country code: SINGAPORE CSC sales code: XSP HW version: Phone S/N: 00000000000 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... OK Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.25.2 I could do after flash by octopus g920idvu3doj6_g920iolc3doj6_xsp_android_5.1.1.oct |
09-30-2016, 19:18 | #10 (permalink) |
Junior Member Join Date: May 2015
Member: 2392433 Status: Offline Thanks Meter: 1 | Same problem any solution tried writing modem Operation: Patch Certificate Selected model: SM-G925F Software version: 26.8 Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 6.0.1 Product code: Phone version: G925FXXS4DPG1 PDA version: G925FXXS4DPG2 CSC version: G925FBTU3DPD2 CSC country code: UK & IRE CSC sales code: BTU HW version: Phone SN: Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Initialization zTool... OK Running zTool, please wait... error (7.7.8) Current version can not be patched Done with Samsung Tool PRO v.26.8 |
12-11-2016, 18:10 | #14 (permalink) |
Junior Member Join Date: Sep 2014
Member: 2250283 Status: Offline Thanks Meter: 1 | Waiting ADB device... Ok Reading phone info... Model: SM-G920I Android version: 5.1.1 Product code: Phone version: G920IDVU3DOJ6 PDA version: G920IDVU3DOJ6 CSC version: G920IOLC3DOJ6 CSC country code: SINGAPORE CSC sales code: XSP HW version: Phone SN: RF1D45EJGGR Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.5 hlap me |
12-13-2016, 00:45 | #15 (permalink) |
No Life Poster Join Date: Jul 2008 Location: ESPAŅA
Member: 808967 Status: Offline Thanks Meter: 155 | Operation: Repair Selected model: SM-G925I Software version: 27.5 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G925I Android version: 6.0.1 Product code: Phone version: G925IDVU3DOJ6 PDA version: G925IDVS3EPIC CSC version: G925ICOM3EPFC CSC country code: COLOMBIA CSC sales code: COM HW version: Phone SN: RF8G505JF3X Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Initialization zTool... Exception: Cannot open file ''. El nombre de archivo, el nombre de directorio o la sintaxis de la etiqueta del volumen no son correctos Done with Samsung Tool PRO v.27.5 |
