09-10-2012, 21:54 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Netherlands Age: 69
Member: 16473 Status: Offline Thanks Meter: 13 | Phone blocked after several unlock trials Because this phone is blocked, I cannot put this phone in Samsung or USB mode. I only can enter block code or call SOS What can I do to make contact with this phone wit Z3x box sio I can unlock? My phone is Samsung S5600V Vodafone Netherlands |
09-11-2012, 09:59 | #3 (permalink) |
Member: 16473 Status: Offline Thanks Meter: 13 | Count supported models - 309 Reading Phone Info... OK Reading SysInfo... Error Access Denied Done with Samsung Tool ver 12.5 Reading Phone Info... OK Reading SysInfo... Error Access Denied Done with Samsung Tool ver 12.5 Reading Phone Info... OK Reading SysInfo... Error Access Denied Done with Samsung Tool ver 12.5 |
09-11-2012, 14:21 | #5 (permalink) |
No Life Poster Join Date: Apr 2007 Location: romania
Member: 492293 Status: Offline Thanks Meter: 324 | qualcomm mode *#782872# use short cable !! no long cable !!! or: Power on phone. Type *#197328640# -> common -> usb config -> Qualcomm mode Connect USB cable, setup drivers. Choise qualcomm diagnostic port in port settings. Choise unlock method: Read codes or Direct. Press Unlock SP button |
09-11-2012, 22:23 | #7 (permalink) |
Member: 16473 Status: Offline Thanks Meter: 13 | I only can enter code which is for blocked phone. It is not possible to enter qualcomm mode *#782872# or anything else. I cannot come into the menu to put the phone in USB or Samsing mode. Even without SIM phone ask for code. |
09-11-2012, 22:59 | #10 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | download multiloader v5.56 download wanted firmware launch multiloader and select mam6275/msm6280/msm6290 tick full download click on bootfiles, select bootfiles directory of your firmware select other files in firmware directory, you can drag and drop them into multiloader. put phone in download mode : vol down+camera+power and connect to pc. Install drivers, and then click search port. When phone found, click download. Post result when finished. |
09-11-2012, 23:05 | #11 (permalink) |
Member: 16473 Status: Offline Thanks Meter: 13 | Thanks a lot, I will reply tomorrow. Because I cannot see which firmware is inside phone, I don't know which version I need. Can you advice me which version with Dutch language? |
09-14-2012, 14:41 | #14 (permalink) |
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | Is your phone recognized when you turn it in download mode ? I mean is there any reactions from your pc ? If you installed kies, drivers should be installed. |
09-14-2012, 19:21 | #15 (permalink) |
Member: 16473 Status: Offline Thanks Meter: 13 | After enter first Download programm downloaded firmware I couldn't reset phone, so I took battery out. After this I receive: Download Start Ch[0] Warning : Securaty fail!! |
