Old 05-13-2016, 03:07   #1 (permalink)
Crazy Poster
Member: 558071
Thanks Meter: 3
Pla Add sm-j120az and sm-j320az
Welcome to Octoplus/Octopus Box Samsung software version 2.2.5
To connect SM-N910V phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Go to dial window.
11. Enter "##366633#" number.
12. Set "Diag config" to "[1]DM/DUM over HS-USB" value.
13. Restart phone.
14. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM1
Selected model: SM-J120F
Searching for a phone. Please wait...
ADB server killed.
Please, press "OK" button on the phone to allow USB debugging..
Phone found.
Detected phone model: SM-J120AZ
Firmware compiled date: Fri Mar 4 15:24:34 KST 2016
PDA version: J120AZTUU1APC4
CSC version: J120AZAIO1APC4
SW version: J120AZTUU1APC4
Phone SN: R58H34MXB0E
Android version: 6.0.1 (MMB29K)
Country: USA
HW platform: exynos3
HW Chip: exynos3475
HW Modem: SHANNON308
Codename: j1xltetu
Performed by 2.2.5 software version
Selected port: COM1
Warning: Selected model (SM-J120F) differs from the detected one
(SM-J120AZ)!
If you want select (SM-J120AZ) as (SM-J120F) model, please check
"manual select".
Phone unlocking failed
Selected port: COM1
(SM-J120AZ)!
"manual select".
Read codes failed
To connect SM-J120H phone you have to perform the following steps:
Selected port: COM1
Selected model: SM-J120H
Warning: Selected model (SM-J120H) differs from the detected one
(SM-J120AZ)!
If you want select (SM-J120AZ) as (SM-J120H) model, please check
"manual select".
Read codes failed
To connect SM-J111M phone you have to perform the following steps:
Selected port: COM1
Selected model: SM-J111M
Warning: Selected model (SM-J111M) differs from the detected one
(SM-J120AZ)!
If you want select (SM-J120AZ) as (SM-J111M) model, please check
"manual select".
Read codes failed
To connect SM-G350 phone you have to perform the following steps:
3. Tap on "Build number" 7 times to enable developer options.
7. Enter "*#7284#" number.
8. Set "UART" radio button to "MODEM" value.
9. Set "USB" radio button to "PDA" value.
10. Press "Save and Reset", phone will restart.
11. Press "Read Info" in software.
Platform: Samsung Broadcom
Selected port: COM1
Selected model: SM-G350
Connecting to phone on COM1274
Warning: Selected model (SM-G350) differs from the detected one (SM-
J120AZ)!
Phone model is not supported
Phone connection failed
Connecting to phone on COM1273
Phone was not found on the selected port!
Selected port: COM1
Reading info, please wait...
(SM-J120AZ)!
"manual select".
Selected port: COM1
Phone found.
Country: USA
HW Chip: exynos3475
Codename: j1xltetu
Old 06-22-2016, 21:59   #2 (permalink)
Member: 2028636
I've been waiting for that model to be added too! I tried to root it through a lot of ways but havent get any luck yet, hope they add those models soon
I have z3x and Im using Samsung tool pro 25.7
Old 10-27-2016, 11:00   #3 (permalink)
Member: 2341189
Sonork: 100.1668003
Thanks Meter: 20
Searching Samsung modem... detected COM115
Reading phone info... OK
Model: SM-J120AZ
AP version: J120AZTUU1APD2
CSC version: J120AZAIO1APD2
CP version: J120AZTUU1APD2
Product code: SM2J120AZKZAIO
Phone SN: R58H51213GB
Unique number: CFN008964CC6543
Reading IMEI... OK
IMEI: xxxxxxxxxxxxx (SIGN: OK)
Reading data from phone... OK
Unlocking... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool PRO v.26.9
Old 01-08-2017, 00:52   #4 (permalink)
Member: 430155
Thanks Meter: 40
Selected port: COM4
Selected model: SM-J120AZ
Found phone on COM48
Reading info...
HW Version: SM2J120AZKZAIO
PDA version: J120AZTUU1APD2
Phone SN: R58H44578FN
Phone IMEI: 356419-07-210942-6
Unlocking phone...
Phone is successfully unlocked
To finish the operation, please restart the phone via phone's menu.
Performed by 2.4.5 Software version.
Old 01-08-2017, 00:56   #5 (permalink)
Member: 255072
Thanks Meter: 46
Change port to samsung diag after 0808
Selected port: COM1
Old 03-13-2017, 17:45   #6 (permalink)
Member: 1549859
Thanks Meter: 13
Searching Samsung modem... detected COM160
Reading phone info... Ok
Model: SM-J120AZ
AP version: J120AZTUU2APJ2
CSC version: J120AZAIO2APJ2
CP version: J120AZTUU2APJ2
Phone SN: R58HC47V32P
Unique number: CFN00201CF2CBB3
Reading IMEI... Ok
IMEI: 356419077xxxxx (SIGN: OK)
Please wait, generating hash codes file, this can take few minutes... Ok
Reading data from phone... Ok
Modem board: SHANNON308
HWID: E6 A9 76 5E 33 9E AA 0D F2 C8 40 F5 F5 5B 26 0E
Reading NV data... Ok
Checking NV data... Ok
Calculating... Ok
Please wait, calculating codes... OK (time - 00:00:03)
Freeze code: 86816420
NET lock: 57208691
SUB lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.27.8
thank you z3x team
Old 03-13-2017, 21:48   #7 (permalink)
GalaxyVibe's Avatar
Member: 2577670
Thanks Meter: 883
The number one Z3X Team! NO COPY PASTE
The Following User Says Thank You to GalaxyVibe For This Useful Post:
Page generated in 0.18047 seconds with 8 queries
