02-16-2018, 02:09 | #1 (permalink) |
Junior Member Join Date: May 2014
Member: 2180898 Status: Offline Thanks Meter: 9 | Please Blang or Team Help! Server error A500M Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose 'DM/DUN over HSIC' (ignore it, if it's not available). 4. Reboot phone. Or use 'Activate Diag' function from 'Repair' tab. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-A500M Selected port: COM256 SAMSUNG Mobile USB Serial Port Software version: 30.8 Checking Login and Password... OK Ballance: 20 crd. You have 20 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-A500M Android version: 6.0.1 Product code: SM-A500MZKACDR Phone version: A500MUBU1CPI1 PDA version: A500MUBS1CPL1 CSC version: A500MCDR1CPI2 CSC country code: Dominican Republic CSC sales code: CDR HW version: MP 1.100 Phone SN: RF8XXXXXXXX Chip name: MSM8916 Modem board: MSM8916 Security patch: 2016-12-01 RF cal date: 2015.02.04 IMEI: 356XXXXXXXXXXXX Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM33 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... error (1) Done with Samsung Tool PRO v.30.8 I tried 3 or 4 times with the same error. Please help customer waiting. Thanks Last edited by thetechxperts; 02-16-2018 at 02:16. |
02-20-2018, 03:32 | #3 (permalink) |
Freak Poster Join Date: Feb 2017 Location: D.R
Member: 2684440 Status: Offline Thanks Meter: 218 | Downgrade your phone versión to 5.0.2 .and unlock it...after this upgrade and enjoy Enviado desde mi Moto G (4) mediante Tapatalk |
The Following User Says Thank You to GSM_FIX For This Useful Post: |
