04-19-2014, 19:04 | #1 (permalink) |
Freak Poster Join Date: Mar 2011 Location: Dallas
Member: 1543792 Status: Offline Sonork: N/A Thanks Meter: 12 | Please Help me Recover I317 Can you guys please help me. |
04-19-2014, 21:08 | #4 (permalink) |
Member: 1543792 Status: Offline Sonork: N/A Thanks Meter: 12 | Selected model: I317 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SAMSUNG-SGH-I317 Android version: 4.3 Product code: Not Active Phone version: I317UCUBMK6 PDA version: I317UCUBMK6 CSC version: I317ATTBMK6 IMEI: Unknown Phone S/N: R31D707LKCZ Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM4 Backuping NVM... error Done with Samsung Tool v.17.3 Selected model: I317 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SAMSUNG-SGH-I317 Android version: 4.3 Product code: Not Active Phone version: I317UCUBMK6 PDA version: I317UCUBMK6 CSC version: I317ATTBMK6 IMEI: Unknown Phone S/N: R31D707LKCZ Checking Super user right... true Backuping MMCBLK... OK Writing data to phone... OK Reseting EFS... OK Rebooting phone... OK Waiting phone... OK Bypass MSL... error Done with Samsung Tool v.17.3 |
The Following User Says Thank You to jub2k3 For This Useful Post: |
04-20-2014, 19:08 | #9 (permalink) |
Member: 1543792 Status: Offline Sonork: N/A Thanks Meter: 12 | 16.8 does the same thing and imei stays at 00. Unlocked but no network and no wifi. If I flash the t-mo qcn it gives me signal and network but badly and does not have an imei. Selected model: I317 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Phone not found Done with Samsung Tool v.16.8 Selected model: I317 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SAMSUNG-SGH-I317 Android version: 4.3 Product code: Not Active Phone version: I317UCUBMK6 PDA version: I317UCUBMK6 CSC version: I317ATTBMK6 IMEI: Unknown Phone S/N: 00000000000 Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Checking phone at COM4 OK Repairing IMEI... OK Repairing network settings... OK Reseting... OK Repair done Done with Samsung Tool v.16.8 |
04-21-2014, 04:55 | #11 (permalink) |
Freak Poster Join Date: Dec 2012 Location: The North
Member: 1861077 Status: Offline Thanks Meter: 89 | Ok here is what you must do... First EDIT the T-Mobile QCN file you have using HEX Editor such as XV132 (There are many tools I am not familiar with but this is what I uses) Flash the T-Mobile QCN file on the phone. Your IMEI will be back but you have mentioned that phone is so slow so I am assuming that you mean data is so slow and network connectivity is very poor. Then download QXDM and connect to the port, and look for line "1877 RF Band Configuration" and edit it to 115868544. After that reset the phone from the tool. Phone will reboot and you should have working phone, with working IMEI and stable network connectivity. Good Luck |
04-22-2014, 00:37 | #12 (permalink) |
Member: 1543792 Status: Offline Sonork: N/A Thanks Meter: 12 | I was able to pull the full nvm off of another i317 and flashed it to the phone then I used NV item Reader and Writer to change the imei. Now the i317 works but I am having funky results with a similar 4.3 t999. When ever I fix with z3x 16.8 4g shows and imei is correct but when ever I place a call the signal bars drop to nothing and the call fails. I have tried many different versions of z3x and have pulled the QCN and NVM full from a working t999 but after I flash either I get no imei or 00/0 and not network at all. Any tips on this phone?? |
04-22-2014, 00:38 | #13 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | similar error Selected model: E250S Selected port: COM1 Communications Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.17.3 Selected model: E250S Selected port: COM5 USB Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.17.3 Selected model: E250S Selected port: COM1 Communications Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.17.3 Selected model: E250S Selected port: COM7 Z3X BOX Serial Port Selected port speed: 115200 Port open fail COM7 Done with Samsung Tool v.17.3 Selected model: E250S Selected port: COM5 USB Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.17.3 Selected model: E250S Selected port: COM5 USB Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.17.3 Selected model: E250S Selected port: COM5 USB Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... Please, allow USB debugging on phone... OK Reading phone info... Model: SHV-E250S Android version: 4.3 Product code: Not Active Phone version: E250SKSUEML1 PDA version: E250SKSUENA1 CSC version: E250SSKTENA1 IMEI: 000000000000000 Phone S/N: 00000000000 Checking Super user right... true Backuping MMCBLK... OK Writing data to phone... OK Reseting EFS... OK Rebooting phone... OK Waiting phone... Please, allow USB debugging on phone... OK Bypass MSL... error Done with Samsung Tool v.17.3 Selected model: E250S Selected port: COM5 USB Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SHV-E250S Android version: 4.3 Product code: Not Active Phone version: E250SKSUEML1 PDA version: E250SKSUENA1 CSC version: E250SSKTENA1 IMEI: 000000000000000 Phone S/N: Unknown Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM5 Operation aborted Done with Samsung Tool v.17.3 Selected model: E250S Selected port: COM5 USB Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SHV-E250S Android version: 4.3 Product code: Not Active Phone version: E250SKSUEML1 PDA version: E250SKSUENA1 CSC version: E250SSKTENA1 IMEI: 000000000000000 Phone S/N: Unknown Checking Super user right... true Backuping MMCBLK... OK Writing data to phone... OK Reseting EFS... OK Rebooting phone... OK Waiting phone... Please, allow USB debugging on phone... OK Bypass MSL... error Done with Samsung Tool v.17.3 Selected model: E250S Selected port: COM5 USB Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SHV-E250S Android version: 4.3 Product code: Not Active Phone version: E250SKSUEML1 PDA version: E250SKSUENA1 CSC version: E250SSKTENA1 IMEI: 000000000000000 Phone S/N: 00000000000 Checking Super user right... true Backuping MMCBLK... OK Writing data to phone... OK Rebooting phone... OK Waiting phone... Please, allow USB debugging on phone... OK Bypass MSL... error Done with Samsung Tool v.17.3 |
