06-19-2012, 07:58 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 771272 Status: Offline Thanks Meter: 8 | Please help! Unlock samsung s6500!!!!!!!!!! I trying to unlock Samsung s6500 using version V12.5, When I try to unlock it, The process is Ok, However The phone STILL LOCK. Reading Phone Info... OK Model: GT-S6500T Country Code: VAU Cal Date: ªU Factory SW: S6500TDULD3 Unique Number: CSJ08B9B5224D4F Memory Phone: ªU Phone S/N: RV1C539R1G Build: 76XXU-USMSKRLYM-109806 IMEI: 35217505030**** PDA/CSC Version: S6500TDULD3/S6500TVAULD3 Phone version: S6500TDULD3 Phone HW: MP 0.400 Cal Date: 2012.05.24 Read Security... OK Bypass MSL... OK Unlocking ... OK Done with Samsung Tool ver 12.5 Reading Phone Info... OK Model: GT-S6500T Country Code: VAU Cal Date: ªU Factory SW: S6500TDULD3 Unique Number: CSJ08B9B5224D4F Memory Phone: ªU Phone S/N: RV1C539R1G Build: 76XXU-USMSKRLYM-109806 IMEI: 3521750503***** PDA/CSC Version: S6500TDULD3/S6500TVAULD3 Phone version: S6500TDULD3 Phone HW: MP 0.400 Cal Date: 2012.05.24 Read Security... OK Bypass MSL... OK Unlocking ... OK Done with Samsung Tool ver 12.5 If i try to read code, It come with: Reading Phone Info... OK Model: GT-S6500T Country Code: VAU Cal Date: ªU Factory SW: S6500TDULD3 Unique Number: CSJ08B9B5224D4F Memory Phone: ªU Phone S/N: RV1C539R1G Build: 76XXU-USMSKRLYM-109806 IMEI: 352175050304041 PDA/CSC Version: S6500TDULD3/S6500TVAULD3 Phone version: S6500TDULD3 Phone HW: MP 0.400 Cal Date: 2012.05.24 Read Security... OK Bypass MSL... OK Reading Codes... OK MCK: ž»ïfÝj/ NCK: æz;>Áwó~ NSCK: ýrçbПšÊ SPCK: ýrçbПšÊ CPCK: ýrçbПšÊ Done with Samsung Tool ver 12.5 Please advice me. thank you Tommy |
06-19-2012, 08:54 | #2 (permalink) |
No Life Poster Join Date: Sep 2010 Location: In trouble Age: 49
Member: 1388004 Status: Offline Sonork: 100.1637034 Thanks Meter: 444 | The only option I see is to flash your phone with different firmware and try again to read codes. Maybe there an issue with this particular firmware ? |
07-11-2012, 16:56 | #3 (permalink) |
Major Poster Join Date: Aug 2006 Location: Netherlands
Member: 334037 Status: Offline Thanks Meter: 5 | i had the same issue , the first time i use the c3300k cable the software says it was unlocked but it was not. so i gave the phone a factory reset wit *2767*3855# after that i tried 2 times again unlock with the cable after that the phone was unlocked and if i did code read it did still give not readable codes. so try again |
08-21-2012, 21:24 | #5 (permalink) |
Freak Poster Join Date: Mar 2010 Location: Behind your back
Member: 1258305 Status: Offline Thanks Meter: 46 | Do this : 1. Power on phone. 2. turn on usb debbuging in options 3. put *#7284# set USB 4. Restart phone and wait to phone power on 5. Wait phone to install all drivers 6. Click direct unlock on Z3X 7. Good job your phone is unlocked Ok i must say one more big thing. Afther unlock dont put batter out becouse phone will be locked again,so afther unlock turn phone off normal and then when you sure its off you can remove battery. That is the problem on all samsung android phones. Regards, LiLSaint |
The Following User Says Thank You to LiLSaint For This Useful Post: |
08-23-2012, 09:23 | #6 (permalink) | |
Junior Member Join Date: Jun 2009
Member: 1062062 Status: Offline Thanks Meter: 15 | Quote:
The Following User Says Thank You to GSManywhere For This Useful Post: |
07-29-2013, 13:53 | #9 (permalink) |
Freak Poster Join Date: May 2007
Member: 504184 Status: Offline Thanks Meter: 55 | Use UART Cable C3300K Tested 100% unlocked. Selected model: S6500 Selected port: COM5 Z3X BOX Serial Port Selected port speed: 11 Selected model: S6500 Selected port: COM5 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Model: GT-S6500 Country code: ªU Cal date: ªU Factory SW: S6500BVLK2 Unique number: CS502F53B520440 Memory phone: ªU PDA/CSC version: S6500BVLK2/S6500TMULK2 Phone version: S6500BVLK2 Phone HW: MP 0.301 Cal date: 2013.05.28 Reading IMEI... OK IMEI: 354312055****** Phone S/N: RF1D57JTQW Build: 76XXU-USMSKRLYM-109806 Reading security... OK Bypass MSL... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool v.15.0 |
