05-24-2013, 14:27 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Indonesia
Member: 901949 Status: Offline Thanks Meter: 50 | Please make revision on your HELP (tutorial) in Samsung tool v.14.5, it's incorrect When we are doing job without internet connections, we rely on the tutorial in the software itself, if it's incorrect than we cannot do unlocking job, luckily many users here post their successful logs and how to unlock in this forum, many thanks to them. i try to unlock T889 using your tutorial like this and fail (using micro uart cable, i'm not using usb cable because it keeps asking for qualcomm msm modem driver) : Phone band:GSM 850/900/1800/1900, HSDPA 850/1700/1900/2100 Manuals: 1. Read info micro-uart cable: 1. Phone must be powered on. 2. Connect the phone to UART port. 3. Choose correct COM port in port settings 4. Press "Read info" button. micro-USB cable: 1. Phone must be powered on. 2. Type *#7284# and choose Modem for both options. 3. Type *#9090# and choose USB Diag. 4. Reboot phone. 5. Connect USB cable, install drivers. 6. Select diagnostic port in port settings. 7. Press "Read info" button. 2. Flashing 1. Choose correct flash file(s).Check flashing options if needed (Re-partition, EFS clear, Boot update) 2. Power on phone in download mode (turn off phone, hold Volume Down + Home(Central) + Power.) 3. Connect phone to PC, install drivers if needed. 4. Press "Flash" button. 3. Unlocking micro-uart cable: 1. Phone must be powered on. 2. Connect the phone to UART port. 3. Choose correct COM port in port settings. 4. Press "Unlock" button. micro-USB cable: 1. Phone must be powered on. 2. Type *#7284# and choose Modem for both options. 3. Type *#9090# and choose USB Diag. 4. Reboot phone. 5. Connect USB cable, install drivers. 6. Select diagnostic port in port settings. 7. Press "Unlock" button. 4. Read codes micro-uart cable: 1. Phone must be powered on. 2. Connect the phone to UART port. 3. Choose correct COM port in port settings. 4. Press "Read codes" button. micro-USB cable: 1. Phone must be powered on. 2. Type *#7284# and choose Modem for both options. 3. Type *#9090# and choose USB Diag. 4. Reboot phone. 5. Connect USB cable, install drivers. 6. Select diagnostic port in port settings. 7. Press "Read codes" button. and always fail, not detected by software... after i try using others tutorial by tatoapf posted in here : http://forum.gsmhosting.com/vbb/f453...obile-1561823/ i have succesfully unlock this phone using method like this - Use UART Cable - Select T999 - Dial *#7284# and select "UART --> Modem", "USB --> Modem" - Open Qualcomm USB Settings and select: "DM+ MODEM + ADB" - Hit OK and Click SAVE and RESET - Dial *#9090# and select "[4] DM over UART" - Restart the phone with the power button, DO NOT RESTART IT TAKING THE BATTERY OUT - Connect the phone to UART and just click direct Unlock Phone Unlocked! and using the original tutorial by Z3x team it says after *#9090# choose USB Diag, i don't even see that menu in *#9090#, so please "kindly verify and make fixes", i think it will help us novice/beginner users of Z3x Samsung tool box as we don't want many open threads here asking a lot of question on how to unlocking phones right? it will be a mess and very confusing..... |
The Following User Says Thank You to frosted For This Useful Post: |
05-24-2013, 15:02 | #2 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | yes we know some tutorial have a mistake dont worry we will fix this problem very soon this information i passed blang i hope he clear out this problem very very soon anyway thanks for the report |
