11-25-2016, 06:41 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: kolkatta
Member: 1204828 Status: Offline Sonork: 123456 Thanks Meter: 64 | pls help z3x j700f unlock 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J700F Software version: 27.1 Searching Samsung modem... detected COM21 Reading phone info... ok Model: SM-J700F AP version: J700FXXU3BPJ3 CSC version: J700FODD3BPJ2 CP version: J700FXXU3BPJ4 Product code: SM-J700FZDDXSG Phone SN: RF8H92NNC4T Unique number: CAJ03026A506E83 Reading IMEI... ok IMEI: 358688074549064 (SIGN: OK) IMEI 2: 358689074549062 (SIGN: OK) Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.1 |
