07-10-2017, 16:42 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Gela
Member: 293758 Status: Offline Thanks Meter: 39 | Possible downgrade g925f v.7 to 6.0.1? Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-G925F Android version: 7.0 Product code: Phone version: PDA version: G925FXXU5EQEG CSC version: G925FVFG5EQEG CSC country code: ITALY CSC sales code: OMN HW version: Phone SN: R58G50GLEBL Chip name: EXYNOS7420 Modem board: Security patch: 2017-05-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... error Security damaged (4 13) Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.28.1 Last edited by italiano.a; 07-10-2017 at 16:52. |
07-10-2017, 17:08 | #4 (permalink) |
No Life Poster Join Date: May 2006 Location: iran,isfahan
Member: 269202 Status: Offline Thanks Meter: 281 | Hi Try with latest z3x software version if not done: Download and flash any firmware include G925FXXU5D with z3x software then flash modem part from lower version for your action |
07-10-2017, 18:13 | #5 (permalink) |
Member: 293758 Status: Offline Thanks Meter: 39 | I have flashing last 6.0.1 firmware and later modem old, but i see always this error : Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.28.1 |
07-10-2017, 19:27 | #6 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Bro downgrade modem to modem from combination binary 5 and you are done Quote:
IF YOU.LIKE WHAT I POST PRESS❤ THANKS BUTTON | |
07-10-2017, 20:24 | #8 (permalink) |
Member: 1933823 Status: Offline Thanks Meter: 1,273 | |
07-11-2017, 06:40 | #9 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
Unlock? Then flash all parts from firmware with G925FXXU4xxxx WITHOUT Bootloader and CP part [ aka modem ] . After this load on AP line combination FW COMBINATION_OXA_FA50_G925FXXU5APK6_OXA5APK6_CL6658 768_QB11572664_REV02_user_mid_noship.tar and select to flash ONLY modem ... Wait process to finish, let you see phone at adb and make unlock [simple unlock, without root ... ] - all be fine. You can update to Android 7 [ G925FXXU5xxxx ] firmwares after this... Phone will remain unlocked. WBR, DebeliaMark, BG P.S. In case after combination modem is used for unlock, both jobs will work - read codes and unlock [old way, simple old way, without rooting] , BUT reading codes will give you wrong result - codes will not work, so use direct unlocking this time. | |
07-11-2017, 07:22 | #10 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,801 | use this version https://www.androidfilehost.com/?fid=529152257862707874 |
The Following 2 Users Say Thank You to profkefah For This Useful Post: |
