Old 02-22-2016, 16:37   #15661 (permalink)
Member: 2476003
Sonork: 100.1664157
Thanks Meter: 11
problem
how to change imei samsung sm-G530h
Old 02-22-2016, 16:57   #15662 (permalink)
creconinfo's Avatar
Member: 2527669
Sonork: 100.1672079
Thanks Meter: 33
S6 Edge+ SM-G928T 5.1.1, not worked after root - arter97.com
"UNLOCK ERROR. - NOT WORK"
i want to know from you that which root method you have used for s6 edge+ sm-g928 5.1.1
waiting for your help
Operation: Unlock
Selected model: SM-G928T
Software version: 24.2
Waiting ADB device... OK
Reading phone info...
Model: SM-G928T
Android version: 5.1.1
Product code: SM-G928TZKATMB
Phone version: G928TUVS2COKC
PDA version: G928TUVS2COKC
CSC version: G928TTMB2COKC
CSC country code: USA
CSC sales code: TMB
HW version: REV1.0
Phone S/N: R58G71BKJSY
Modem board: SHANNON333
RF cal date: 20150723
IMEI:
Checking Super user right... true
Initialization AT RIL... error (0)
Done with Samsung Tool PRO v.24.3
The Following User Says Thank You to creconinfo For This Useful Post:
Old 02-22-2016, 19:40   #15663 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,178
UNLOCK INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or
tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button for direct unlock.
Operation: Unlock
Selected model: GT-I9300
Software version: 24.3
Model: GT-I9300
Android version: 4.3
Product code: Not Active
Phone version: I9300BUUGMJ3
PDA version: I9300XXUGMJ9
CSC version: I9300VFGGMJ5
CSC country code: Germany
CSC sales code: VD2
HW version: REV__
Phone S/N: RF1D954VLEN
Modem board:
RF cal date: 2013.9.19
IMEI: 359040053816669
Reading nv data... OK
Checking magic... OK
Running zTool, please wait... OK
Detected new type of security version 0
Calculating... OK
Unlocking... OK
Rebooting phone... OK
Unlock done
The Following User Says Thank You to razib143 For This Useful Post:
Old 02-23-2016, 03:38   #15664 (permalink)
Gambitv01's Avatar
Member: 1475064
Thanks Meter: 347
Operation: Write CERT
Selected model: SM-G920A
Please, allow USB debugging on phone... OK
Model: SAMSUNG-SM-G920A
Android version: 5.0.2
Product code: SM-G920AZWAATT
Phone version: G920AUCU1AOE2
PDA version: G920AUCU1AOE2
CSC version: G920AATT1AOE2
CSC sales code: ATT
HW version: REV1.0
Phone S/N: R58G30W2YMA
RF cal date: 20150407
IMEI:
Initialization AT RIL... OK
Checking certificate file... OK
KEY ID: 0346
Check version... OK
Initializating zTool... OK
Checking NV data... OK
Calculating... OK
Writing nv data... OK
Write CERT done
Operation: Unlock
CSC sales code: ATT
HW version: REV1.0
IMEI:
Check version... OK
Calculating... OK
Unlock done
The Following User Says Thank You to Gambitv01 For This Useful Post:
Old 02-23-2016, 06:52   #15665 (permalink)
Member: 1972619
Thanks Meter: 2
Samsung j200F Sucsesfuly unlock with z3x Box
Operation: Read Codes
[ Read Codes ] Selected model: SM-J200F
[ Read Codes ] Software version: 24.2
[ Read Codes ]
[ Read Codes ] Checking hash file... OK
[ Read Codes ] Waiting ADB device... OK
[ Read Codes ] Reading phone info...
[ Read Codes ] Model: SM-J200F
[ Read Codes ] Android version: 5.1.1
[ Read Codes ] Product code: SM-J200FZKDKSA
[ Read Codes ] Phone version: J200FXXU1AOI5
[ Read Codes ] PDA version: J200FXXU1AOI6
[ Read Codes ] CSC version:
[ Read Codes ] CSC country code:
[ Read Codes ] CSC sales code:
[ Read Codes ] HW version: MP 0.300
[ Read Codes ] Phone S/N: R28GB53MD0Y
[ Read Codes ] Modem board: SHANNON308
[ Read Codes ] RF cal date: 20151126
[ Read Codes ] IMEI:
[ Read Codes ] Checking Super user right... true
[ Read Codes ] Initialization AT RIL... OK
[ Read Codes ] Initializating zTool... OK
[ Read Codes ] Running zTool, please wait... OK
[ Read Codes ] Reading nv data... OK
[ Read Codes ] Checking NV data... OK
[ Read Codes ] Calculating... OK
[ Read Codes ] Please wait, calculating codes... OK (time - 00:00:06)
[ Read Codes ] Freeze code: 81529030
[ Read Codes ] NET lock: 37083805
[ Read Codes ] Sub lock: 00000000
[ Read Codes ] SP lock: 00000000
[ Read Codes ] CP lock: 00000000
[ Read Codes ] SIM lock: 00000000
[ Read Codes ] For check lock status: *#7465625#
The Following 2 Users Say Thank You to stanweer For This Useful Post:
Old 02-23-2016, 11:43   #15666 (permalink)
Member: 167213
Thanks Meter: 21
samsung b5722 unlock with cable rj45 for j750
Selected model: B5722_m
Selected com port: COM116
Selected speed port: 115200
Please, connect phone and press shortly power button
Phone Detected
Sending loader1... OK
ARM version 3B11
Sending loader2... OK
Flash ID: 00EC2206000100000034
Unlock - ok
If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000#
Elapsed time: 638 second, sw ver: 3.5.0040
Old 02-23-2016, 13:20   #15667 (permalink)
Member: 2332708
Thanks Meter: 7
Micro-USB cable:
1. Phone must be powered on.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and choose 'DM/DUN over HSIC'.
4. Reboot phone.
Or use 'Activate Diag' function from 'Repair' tab.
5. Connect USB cable, install drivers if needed.
6. Select Samsung diagnostic port in port settings.
7. Press 'Unlock' button for direct unlock.
Operation: Unlock
Selected model: SM-G850A
Selected port: COM34 SAMSUNG Mobile USB Serial Port
Reading IMEI... OK
IMEI: 35xxxx
Unlocking... OK
Reseting... OK
Unlock done
Done with Samsung Tool PRO v.24.2
Old 02-23-2016, 14:12   #15668 (permalink)
Member: 2332708
Thanks Meter: 7
Micro-USB cable:
4. Reboot phone.
Operation: Unlock
Reading IMEI... OK
IMEI: 35xxxx
Unlocking... OK
Reseting... OK
Unlock done
Old 02-23-2016, 14:45   #15669 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,178
Selected model: T399
Selected port: COM20 SAMSUNG Mobile USB Serial Port
Selected port speed: 115200
Model: SGH-T399N
Android version: 4.4.2
Product code: Unknown
Phone version: T399NUVUAOH3
PDA version: T399NUVUAOH3
CSC version: T399NTMBAOH3
IMEI: 350695200123951
Phone S/N: RV8F90AKVJK
Reading modem... OK
Patching modem... OK
Writing modem... OK
Repair done
Old 02-23-2016, 19:55   #15670 (permalink)
Member: 2332708
Thanks Meter: 7
Unlock Note 4 Sprint America
Operation: Unlock
Selected model: SM-N910P
Selected port: COM37 SAMSUNG Mobile USB Serial Port
Reading IMEI... OK
IMEI: 990xxx
Unlocking... OK
Reseting... OK
Unlock done
Old 02-23-2016, 22:10   #15671 (permalink)
Member: 2489757
Thanks Meter: 6
Micro-USB cable:
4. Reboot phone.
Operation: Unlock
Selected model: SM-G900A
Selected port: COM33 SAMSUNG Mobile USB Serial Port
Reading IMEI... OK
IMEI: 353920062723210
Unlocking... OK
Reseting... OK
Unlock done
Old 02-24-2016, 02:21   #15672 (permalink)
Gambitv01's Avatar
Member: 1475064
Thanks Meter: 347
Operation: Unlock SPRNT
Selected model: SPH-L720
Selected port: COM16 SAMSUNG Mobile USB Serial Port
Model: SPH-L720
Android version: 5.0.1
Phone version: L720VPUGOK3
PDA version: L720VPUGOK3
CSC version: L720SPTGOK3
CSC sales code: SPR
HW version: L720.08
Phone S/N: 00000000000
Modem board: MDM9615M
RF cal date: 2013.07.01
IMEI:
Unlocking... OK
Unlock done
Old 02-24-2016, 07:28   #15673 (permalink)
mr.luckytarun's Avatar
Member: 1195083
Sonork: QQ:3208821449
Thanks Meter: 1,348
GT-S7580 Flash Done
[IMG][/IMG]
Old 02-24-2016, 11:41   #15674 (permalink)
trenac's Avatar
Member: 1246981
Sonork: 100.1590424
Thanks Meter: 316
g361f unlock done
peration: Unlock
[ 24-Feb-16 11:31:00 ] Selected model: SM-G361F
[ 24-Feb-16 11:31:00 ] Software version: 24.4
[ 24-Feb-16 11:31:00 ] Waiting ADB device... OK
[ 24-Feb-16 11:31:00 ] Reading phone info...
[ 24-Feb-16 11:31:00 ] Model: SM-G361F
[ 24-Feb-16 11:31:00 ] Android version: 5.1.1
[ 24-Feb-16 11:31:00 ] Product code: SM2G361FHAAMBM
[ 24-Feb-16 11:31:00 ] Phone version: G361FXXU1AOGD
[ 24-Feb-16 11:31:00 ] PDA version: G361FXXU1AOG1
[ 24-Feb-16 11:31:00 ] CSC version:
[ 24-Feb-16 11:31:00 ] CSC country code:
[ 24-Feb-16 11:31:00 ] CSC sales code:
[ 24-Feb-16 11:31:00 ] HW version: MP 0.100
[ 24-Feb-16 11:31:00 ] Phone S/N: RV8GB2AYXAF
[ 24-Feb-16 11:31:00 ] Modem board:
[ 24-Feb-16 11:31:00 ] RF cal date: 20151128
[ 24-Feb-16 11:31:00 ] IMEI:
[ 24-Feb-16 11:31:00 ] Checking Super user right... true
[ 24-Feb-16 11:31:00 ] Reading nv data... OK
[ 24-Feb-16 11:31:00 ] Analysing SEC file... OK
[ 24-Feb-16 11:31:00 ] Initialization AT RIL... OK
[ 24-Feb-16 11:31:00 ] Bypass MSL... OK
[ 24-Feb-16 11:31:00 ] Unlocking... OK
[ 24-Feb-16 11:31:00 ] Rebooting phone... OK
[ 24-Feb-16 11:31:00 ] Unlock done
Old 02-24-2016, 14:46   #15675 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,178
UART cable:
2. Connect the phone to UART cable.
3. Choose correct COM port in port settings.
4. Check security type ('Old Security' or 'New Security').
5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
USB cable with 'Old Security' option:
2. Type *#782872# to switch phone to Qualcomm USB mode,
(after operations you can enter *#726872# to switch back to Samsung USB mode.)
3. Connect USB cable, install drivers.
4. Select diagnostic port in port settings.
If you got 'Calculating ... error' or 'Reading sysinfo ... access denied' errors,
then you must check 'New security' option.
USB cable with 'New Security' option:
2. Type *#726872# to switch phone to Samsung USB mode.
4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
Operation: Unlock
Selected model: GT-S8300
Selected port: COM187 ALCATEL Diagnostics Interface 6000
Software version: 24.1
Searching Samsung modem... detected COM185
Model: GT-S8300
Country code: ¿µ±¹
Cal date: 2009-10-27
Factory SW: S8300XXIJ2
Unique number: 12340000227709
Memory phone: K5R2G1GACC(S8300)S
Reading sysinfo... OK
Searching server... OK
Writing sysinfo... OK
Reseting... OK
Unlock done
Done with Samsung Tool PRO v.24.1
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1841 07-06-2022 14:14
Post here successfully unlock or IMEI repair Infinity Box R@ZIB-BD Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG R@ZIB-BD Z3X-Team Products 2 02-01-2011 17:29
Page generated in 0.42779 seconds with 11 queries
