03-04-2016, 18:55 | #15737 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | t999 unlock Code: UNLOCK INSTRUCTIONS: Micro-USB cable: 1. Phone must be powered on. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and choose USB (or 'DM/DUN over HSIC'). 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select Samsung diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SGH-T999 Selected port: COM89 SAMSUNG Mobile USB Serial Port Software version: 24.0 Reading phone info... Reading IMEI... OK IMEI: 353022056325787 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.0 |
03-04-2016, 18:56 | #15738 (permalink) |
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | j7 frp Code: UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-J700H/DS Software version: 24.0 Searching Samsung USB Flash Interface... detected COM49 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.24.0 |
03-04-2016, 22:59 | #15740 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Unlock Selected model: SM-N915T Selected port: COM57 SAMSUNG Mobile USB Serial Port Software version: 24.6 Reading phone info... Reading IMEI... OK IMEI: 35502XXXXXXXX Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.6 |
03-05-2016, 00:21 | #15742 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SGH-M919 Software version: 24.6 File analysis... OK Total file size: 0x96FE9CF8 (2415 Mb) Searching USB Flash Interface... detected COM4 Setup connection... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending sbl2.mbn... OK Sending sbl3.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... OK Sending modem.bin... OK Sending NON-HLOS.bin... OK Flashing done (time - 00:14:06) Done with Samsung Tool PRO v.24.6 |
03-05-2016, 02:49 | #15743 (permalink) |
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Unlock Selected model: SM-G900A Selected port: COM29 SAMSUNG Mobile USB Serial Port Software version: 24.4 Reading phone info... Reading IMEI... OK IMEI: 353920XXXXXXXXX Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.4 Operation: Unlock Selected model: SM-G900A Selected port: COM35 SAMSUNG Mobile USB Serial Port Software version: 24.4 Reading phone info... Reading IMEI... OK IMEI: 352132XXXXXXXX Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.4 Operation: Unlock Selected model: SM-G900A Selected port: COM38 SAMSUNG Mobile USB Serial Port Software version: 24.4 Reading phone info... Reading IMEI... OK IMEI: 35469106XXXXXX Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.4 Operation: Unlock Selected model: SM-G900A Selected port: COM41 SAMSUNG Mobile USB Serial Port Software version: 24.4 Reading phone info... Reading IMEI... OK IMEI: 35392006XXXXXXXX Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.4 Operation: Unlock Selected model: SM-G900A Selected port: COM26 SAMSUNG Mobile USB Serial Port Software version: 24.4 Reading phone info... Reading IMEI... OK IMEI: 3539200XXXXXXX Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.4 |
03-05-2016, 05:53 | #15744 (permalink) | |
Junior Member Join Date: Feb 2014
Member: 2125684 Status: Offline Thanks Meter: 0 | try version 23.5 Quote:
03-05-2016, 07:56 | #15747 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 320655 Status: Offline Thanks Meter: 28 | unlock done I317M Selected model: I317M Selected port: COM10 Qualcomm HS-USB Diagnostics 9004 Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179550 Done with Samsung Tool v.19.1 Selected model: I317M Selected port: COM10 Qualcomm HS-USB Diagnostics 9004 Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179550 Reading security... OK Searching server... OK NET lock: 16314049 Sub lock: 00000000 SP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool v.19.1 Selected model: I317M Selected port: COM10 Qualcomm HS-USB Diagnostics 9004 Selected port speed: 115200 Reading phone info... Build: M9615ACEHWMAZD179550 Reading security... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.19.1 Done with Samsung Tool v.19.1 |
03-05-2016, 08:33 | #15748 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Romania,Sinaia
Member: 637351 Status: Offline Thanks Meter: 167 | Samsung S6500d unlocked done Code: Checking phone at COM343 Reading phone info... OK Model: GT-S6500D Country code: ªU Cal date: ªU Factory SW: S6500DXXMD1 Unique number: CS50299EF7E9F21 Memory phone: ªU Phone S/N: RF1D31QVJE PDA/CSC version: S6500DXXMD1/none Phone version: S6500DXXMD1 Phone HW: MP 0.300 Cal date: 2013.03.06 Reading IMEI... OK IMEI: 3529920562xxxxx Bypass MSL... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool v.20.5 |
03-05-2016, 10:24 | #15750 (permalink) |
Registered User Join Date: Feb 2016 Location: United Arab Emirates
Member: 2538950 Status: Offline Sonork: 100.1672378:mota Thanks Meter: 5 | g928f unloking falid[QUOTE[ 3/5/2016 1:55:00 PM ] Operation: Unlock [ 3/5/2016 1:55:00 PM ] Selected model: SM-G928F [ 3/5/2016 1:55:00 PM ] Software version: 24.4 [ 3/5/2016 1:55:00 PM ] [ 3/5/2016 1:55:00 PM ] Waiting ADB device... OK [ 3/5/2016 1:55:00 PM ] Reading phone info... [ 3/5/2016 1:55:00 PM ] Model: SM-G928F [ 3/5/2016 1:55:00 PM ] Android version: 5.1.1 [ 3/5/2016 1:55:00 PM ] Product code: SM-G928FZDAEVR [ 3/5/2016 1:55:00 PM ] Phone version: G928FXXU1AOH3 [ 3/5/2016 1:55:00 PM ] PDA version: G928FXXU1AOH3 [ 3/5/2016 1:55:00 PM ] CSC version: G928FEVR1AOH1 [ 3/5/2016 1:55:00 PM ] CSC country code: UK [ 3/5/2016 1:55:00 PM ] CSC sales code: EVR [ 3/5/2016 1:55:00 PM ] HW version: MP 0.500 [ 3/5/2016 1:55:00 PM ] Phone S/N: R58G819H89L [ 3/5/2016 1:55:00 PM ] Modem board: SHANNON333 [ 3/5/2016 1:55:00 PM ] RF cal date: 20150818 [ 3/5/2016 1:55:00 PM ] IMEI: [ 3/5/2016 1:55:00 PM ] Checking Super user right... true [ 3/5/2016 1:55:00 PM ] Initialization AT RIL... error (0) [ 3/5/2016 1:55:00 PM ] [ 3/5/2016 1:58:00 PM ] Operation: Unlock [ 3/5/2016 1:58:00 PM ] Selected model: SM-G928F [ 3/5/2016 1:58:00 PM ] Software version: 24.6 [ 3/5/2016 1:59:00 PM ] [ 3/5/2016 1:59:00 PM ] Waiting ADB device... OK [ 3/5/2016 1:59:00 PM ] Reading phone info... [ 3/5/2016 1:59:00 PM ] Model: SM-G928F [ 3/5/2016 1:59:00 PM ] Android version: 5.1.1 [ 3/5/2016 1:59:00 PM ] Product code: SM-G928FZDAEVR [ 3/5/2016 1:59:00 PM ] Phone version: G928FXXU1AOH3 [ 3/5/2016 1:59:00 PM ] PDA version: G928FXXU1AOH3 [ 3/5/2016 1:59:00 PM ] CSC version: G928FEVR1AOH1 [ 3/5/2016 1:59:00 PM ] CSC country code: UK [ 3/5/2016 1:59:00 PM ] CSC sales code: EVR [ 3/5/2016 1:59:00 PM ] HW version: MP 0.500 [ 3/5/2016 1:59:00 PM ] Phone S/N: R58G819H89L [ 3/5/2016 1:59:00 PM ] Modem board: SHANNON333 [ 3/5/2016 1:59:00 PM ] RF cal date: 20150818 [ 3/5/2016 1:59:00 PM ] IMEI: [ 3/5/2016 1:59:00 PM ] Checking Super user right... true [ 3/5/2016 1:59:00 PM ] Initialization AT RIL... error (0) ][/QUOTE] |
The Following User Says Thank You to mota ali For This Useful Post: |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
