04-27-2016, 09:46 | #16081 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung GT-E1200i Unlock Code: Operation: Read Codes Selected model: GT-E1200I Selected port: COM31 SPRD U2S Diag, Software version: 20.5 Reading phone info... OK IMEI Master: 353601075768273 Product code: GT-E1200ZKIVOP Phone HW: MP 0.400 Phone S/N: R21G732NG9 Reading codes... OK Please wait, calculating codes... OK (time - 00:00:33) Freeze code: 05728172 NET lock: 91681419 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool v.20.5 |
04-27-2016, 13:22 | #16082 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Africa.uganda
Member: 562975 Status: Offline Sonork: better tomorow Thanks Meter: 247 | GT-S5600 unlock done. Operation: Unlock Selected model: GT-S5600 Selected port: COM207 ALCATEL Diagnostics Interface 6000 Software version: 25.2 Searching Samsung modem... detected COM206 Reading phone info... Model: GT-S5600 Country code: ½ºÆäÀÎ Cal date: 2009-05-19 Factory SW: S5600BGIE5 Unique number: 60370000113696 Memory phone: K5R2G1GACC(S5600)S Reading sysinfo... OK Searching local files... error (files corrupted) Switching to remote unlock Searching server... OK Writing sysinfo... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.25.2 |
04-27-2016, 20:31 | #16084 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Samsung S2 Direct Unlock done.. UNLOCK INSTRUCTIONS: Micro-UART cable: 1. Phone must be powered on. 2. Type *#7284# and choose Modem for UART and PDA for USB options. 3. Type *#9090# and choose UART. 4. Reboot phone. 5. Connect the phone to UART port. 6. Choose correct COM port in port settings. 7. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Micro-USB cable: 1. Phone must be powered on. 2. Type *#7284# and choose Modem for USB and PDA for UART options. 3. Type *#9090# and choose HS-USB. 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: SGH-T989 Selected port: COM127 SAMSUNG Mobile USB Serial Port Software version: 25.2 Reading phone info... Model: SGH-T989 Country code: ªU Cal date: ªU Factory SW: T989UVLI4 Unique number: CKY25460A7ABF30 Memory phone: ªU Phone S/N: R31D31EE0D PDA/CSC version: T989UVLI4/none Phone HW: SW VERSI Cal date: e Reading IMEI... OK IMEI: 359858047079XXX Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.25.2 |
The Following User Says Thank You to razib143 For This Useful Post: |
04-28-2016, 08:32 | #16085 (permalink) |
Product Supporter Join Date: Jul 2011 Location: ISLAMIC & INDIA WITH MIRACLE T Age: 37
Member: 1617868 Status: Offline Sonork: 100.1625996 Thanks Meter: 2,028 | Samsung c3312r simlock remowe Selected model: C3312R Selected port: COM15 Z3X BOX Serial Port Selected port speed: 921600 Connect phone in flash mode Waiting phone... OK Sending preloader... OK Sending loader... OK Checking Flash ID... OK Detected Flash ID: 003000EC Reading security... OK Writing security... OK Rebooting phone... OK If phone not powered ON - turn ON phone Searching Samsung modem... detected COM41 Reading phone info... Model: GT-C3312R Country code: OPEN Factory SW: C3312RDDMG2_RODDMF2 Unique number: 27251402059838 Memory phone: K5W1G12ACP(C3312)S Software version: C3312RDDMG2/C3312RODDMF2 IMEI: 3568410+++++++ Bypass MSL... OK Unlocking... OK Done with Samsung Tool v.19.1 Done with Samsung Tool v.19.1 |
The Following User Says Thank You to .::THE ROCK::. For This Useful Post: |
04-28-2016, 12:37 | #16086 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung GT-E1270 Unlock Code: Selected model: E1270 Selected port: COM31 SPRD U2S Diag Selected port speed: 921600 Reading phone info... OK IMEI Master: 353009073135315 Product code: Phone HW: MP 0.800 Phone S/N: RV1G91C1S4 Unlocking... OK Done with Samsung Tool v.18.0 |
The Following User Says Thank You to Tanha0321 For This Useful Post: |
04-29-2016, 19:45 | #16087 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Somewhere on earth
Member: 2014742 Status: Offline Thanks Meter: 167 | Samsung Focus Unlock Operation: Read Codes Selected model: SGH-I917R Selected port: COM7 Z3X BOX Serial Port Software version: 25.2 Checking phone at COM7 Reading phone info... OK Model: SGH-I917R Country code: ij³ª´Ù/RWC Cal date: 2010-10-13 Factory SW: UXJJ2 Unique number: 75710000374614 Memory phone: MT29C8G96MAZA(I917) Phone S/N: R5xxxxxxxxx PDA/CSC version: i917RUXKI4/i917RRWCKI4 Phone version: i917RUXKI3 Phone HW: REV1.3 Cal date: 2010.12.09 Reading IMEI... OK IMEI: 35xxxxxxxxxxxx Reseting MSL... OK Bypass MSL... OK Reading codes... OK Freeze code: 41809579 NET lock: 60405797 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.25.2 |
The Following User Says Thank You to A4L For This Useful Post: |
04-30-2016, 06:47 | #16088 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2556769 Status: Offline Thanks Meter: 0 | Operation: Unlock UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Applications'-'Development' for Android 2.x or 'Settings'-'Developer options' for Android 4.x. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: GT-S6810P Software version: 25.2 Waiting ADB device... OK Reading phone info... Model: GT-S6810P Android version: 4.1.2 Product code: Phone version: S6810PNEAMB2 PDA version: S6810PXXAMB4 CSC version: S6810PH3GAMB2 CSC country code: UK CSC sales code: H3G HW version: MP 0.400 Phone S/N: RF1D74C8B5L Modem board: RF cal date: 20130717 IMEI: 357082053575376 Checking Super user right... false Rooting phone, please wait... OK Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.25.2 |
04-30-2016, 12:30 | #16089 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Cote d'Ivoire
Member: 841640 Status: Offline Thanks Meter: 86 | SAMSUNG S5360 UNLOCKED WITH Z3x UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Applications'-'Development' for Android 2.x or 'Settings'-'Developer options' for Android 4.x. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: GT-S5360 Software version: 25.2 Waiting ADB device... OK Reading phone info... Model: GT-S5360 Android version: 2.3.6 Product code: Phone version: S5360XXMC2 PDA version: S5360XXMC2 CSC version: S5360OXXMC2 CSC country code: Switzerland CSC sales code: SUW HW version: MP 0.701 Phone S/N: Modem board: RF cal date: 20130603 IMEI: 35689805xxxxxxx Checking Super user right... true Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.25.2 |
05-01-2016, 05:37 | #16090 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | n920a unlock done Code: UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-N920A Software version: 25.2 Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-N920A Android version: 5.1.1 Product code: SM2N920AZKAATT Phone version: N920AUCU2AOJ1 PDA version: N920AUCU2AOJ1 CSC version: N920AATT2AOJ1 CSC country code: USA CSC sales code: ATT HW version: REV1.0 Phone S/N: RF8H31FZC2J Modem board: SHANNON333 RF cal date: 20160312 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK Reading nv data... OK Checking NV data... OK Calculating... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.25.2 |
05-01-2016, 14:45 | #16091 (permalink) |
Junior Member Join Date: Apr 2012
Member: 1751903 Status: Offline Thanks Meter: 2 | N900A Phone Not Allowed MM#6 Fix Phone Not Allowed on Mobile Network after unlock. so i decided to write CERT to Repair/Change IMEI. Initialization AT Ril error kept repeating until i restored all backups and then attempt cert write Again and then got success which also fixed my phone not allowed issue. but even though i flashed back to stock to remove custom flag on boot screen it remains flagged even though i no longer have root. currently on 5.0. but except custom flag, job was a success. any suggestion on custom flag removal? [ 30/04/2016 11:46:00 PM SM-N900A Unlock ] Operation: Unlock [ 30/04/2016 11:46:00 PM SM-N900A Unlock ] Selected model: SM-N900A [ 30/04/2016 11:46:00 PM SM-N900A Unlock ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 30/04/2016 11:46:00 PM SM-N900A Unlock ] Software version: 25.2 [ 30/04/2016 11:46:00 PM SM-N900A Unlock ] [ 30/04/2016 11:46:00 PM SM-N900A Unlock ] Reading phone info... [ 30/04/2016 11:46:00 PM SM-N900A Unlock ] Reading IMEI... OK [ 30/04/2016 11:46:00 PM SM-N900A Unlock ] IMEI: 358579052959054 [ 30/04/2016 11:46:00 PM SM-N900A Unlock ] Unlocking... OK [ 30/04/2016 11:46:00 PM SM-N900A Unlock ] Reseting... OK [ 30/04/2016 11:46:00 PM SM-N900A Unlock ] Unlock done [ 30/04/2016 11:46:00 PM SM-N900A Unlock ] [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] Operation: Read EFS [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] Selected model: SM-N900A [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] Software version: 25.2 [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] Waiting ADB device... OK [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] Reading phone info... [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] Model: SAMSUNG-SM-N900A [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] Android version: 4.3 [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] Product code: SM-N900AZKEATT [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] Phone version: N900AUCUBMI1 [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] PDA version: N900AUCUBMI1 [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] CSC version: N900AATTBMI1 [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] CSC country code: USA [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] CSC sales code: ATT [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] HW version: REV0.3 [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] Phone S/N: R31DB0FH3TE [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] Modem board: MSM8974 [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] RF cal date: 2013.11.09 [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] IMEI: 358579052959054 [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] Checking Super user right... true [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] Reading EFS from phone... OK [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] Saved to C:\Program Files (x86)\Z3X\Samsung\SamsungToolPRO\backup\EFS\EFS_SA MSUNG-SM-N900A_N900AUCUBMI1_358579052959054_R31DB0FH3TE_30-4-2016_23-50-19.tar [ 30/04/2016 11:50:00 PM SM-N900A Read EFS ] [ 30/04/2016 11:50:00 PM SM-N900A Read QCN ] Operation: Read QCN [ 30/04/2016 11:50:00 PM SM-N900A Read QCN ] Selected model: SM-N900A [ 30/04/2016 11:50:00 PM SM-N900A Read QCN ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 30/04/2016 11:50:00 PM SM-N900A Read QCN ] Software version: 25.2 [ 30/04/2016 11:50:00 PM SM-N900A Read QCN ] [ 30/04/2016 11:50:00 PM SM-N900A Read QCN ] Reading ID... OK [ 30/04/2016 11:50:00 PM SM-N900A Read QCN ] Detected ID: 00000FF3 (MSM8974) [ 30/04/2016 11:50:00 PM SM-N900A Read QCN ] SW Version: M8974A-AAAANAZM-1.0.180064 [ 30/04/2016 11:50:00 PM SM-N900A Read QCN ] Reading ESN... OK [ 30/04/2016 11:50:00 PM SM-N900A Read QCN ] Backuping RFNV... OK [ 30/04/2016 11:51:00 PM SM-N900A Read QCN ] Backuping Feature Mask... OK [ 30/04/2016 11:51:00 PM SM-N900A Read QCN ] Backuping NV Item... OK [ 30/04/2016 11:53:00 PM SM-N900A Read QCN ] Backuping NV Item SIM1... OK [ 30/04/2016 11:55:00 PM SM-N900A Read QCN ] Backuping NV Item SIM2... OK [ 30/04/2016 11:57:00 PM SM-N900A Read QCN ] Backuping Provisioning Item Files... OK [ 30/04/2016 11:57:00 PM SM-N900A Read QCN ] Reading QCN done success [ 30/04/2016 11:57:00 PM SM-N900A Read QCN ] [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] Operation: Read SEC [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] Selected model: SM-N900A [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] Software version: 25.2 [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] Waiting ADB device... OK [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] Reading phone info... [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] Model: SAMSUNG-SM-N900A [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] Android version: 4.3 [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] Product code: SM-N900AZKEATT [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] Phone version: N900AUCUBMI1 [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] PDA version: N900AUCUBMI1 [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] CSC version: N900AATTBMI1 [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] CSC country code: USA [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] CSC sales code: ATT [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] HW version: REV0.3 [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] Phone S/N: R31DB0FH3TE [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] Modem board: MSM8974 [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] RF cal date: 2013.11.09 [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] IMEI: 358579052959054 [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] Checking Super user right... true [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] Backuping MMCBLK... OK [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] Saved to C:\Program Files (x86)\Z3X\Samsung\SamsungToolPRO\backup\SEC\SM-N900A_1-5-2016_2-32-15_backup.tar [ 01/05/2016 2:32:00 AM SM-N900A Read SEC ] [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] Operation: Write CERT [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] Selected model: SM-N900A [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] Software version: 25.2 [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] Checking certificate file... OK [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] KEY ID: 0813 [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] Waiting ADB device... OK [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] Reading phone info... [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] Model: SAMSUNG-SM-N900A [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] Android version: 4.3 [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] Product code: SM-N900AZKEATT [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] Phone version: N900AUCUBMI1 [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] PDA version: N900AUCUBMI1 [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] CSC version: N900AATTBMI1 [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] CSC country code: USA [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] CSC sales code: ATT [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] HW version: REV0.3 [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] Phone S/N: R31DB0FH3TE [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] Modem board: MSM8974 [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] RF cal date: 2013.11.09 [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] IMEI: 358579052959054 [ 01/05/2016 2:41:00 AM SM-N900A Write CERT ] Initialization AT RIL... error [ 01/05/2016 2:42:00 AM SM-N900A Write CERT ] [ 01/05/2016 2:42:00 AM SM-N900A Reset MSL ] Operation: Reset MSL [ 01/05/2016 2:42:00 AM SM-N900A Reset MSL ] Selected model: SM-N900A [ 01/05/2016 2:42:00 AM SM-N900A Reset MSL ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 2:42:00 AM SM-N900A Reset MSL ] Software version: 25.2 [ 01/05/2016 2:42:00 AM SM-N900A Reset MSL ] [ 01/05/2016 2:42:00 AM SM-N900A Reset MSL ] Reading phone info... [ 01/05/2016 2:42:00 AM SM-N900A Reset MSL ] Reading IMEI... OK [ 01/05/2016 2:42:00 AM SM-N900A Reset MSL ] IMEI: 358579052959054 [ 01/05/2016 2:42:00 AM SM-N900A Reset MSL ] Reseting MSL security... OK [ 01/05/2016 2:42:00 AM SM-N900A Reset MSL ] Reseting... OK [ 01/05/2016 2:42:00 AM SM-N900A Reset MSL ] Reset MSL done [ 01/05/2016 2:42:00 AM SM-N900A Reset MSL ] [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] Operation: Write CERT [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] Selected model: SM-N900A [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] Software version: 25.2 [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] Checking certificate file... OK [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] KEY ID: 0813 [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] Waiting ADB device... OK [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] Reading phone info... [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] Model: SAMSUNG-SM-N900A [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] Android version: 4.3 [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] Product code: SM-N900AZKEATT [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] Phone version: N900AUCUBMI1 [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] PDA version: N900AUCUBMI1 [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] CSC version: N900AATTBMI1 [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] CSC country code: USA [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] CSC sales code: ATT [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] HW version: REV0.3 [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] Phone S/N: R31DB0FH3TE [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] Modem board: MSM8974 [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] RF cal date: 2013.11.09 [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] IMEI: 358579052959054 [ 01/05/2016 2:43:00 AM SM-N900A Write CERT ] Initialization AT RIL... error [ 01/05/2016 2:44:00 AM SM-N900A Write CERT ] [ 01/05/2016 2:45:00 AM SM-N900A Wipe EFS/NVM ] Operation: Wipe EFS/NVM [ 01/05/2016 2:45:00 AM SM-N900A Wipe EFS/NVM ] Selected model: SM-N900A [ 01/05/2016 2:45:00 AM SM-N900A Wipe EFS/NVM ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 2:45:00 AM SM-N900A Wipe EFS/NVM ] Software version: 25.2 [ 01/05/2016 2:45:00 AM SM-N900A Wipe EFS/NVM ] [ 01/05/2016 2:45:00 AM SM-N900A Wipe EFS/NVM ] Searching Samsung USB Flash Interface... not found [ 01/05/2016 2:45:00 AM SM-N900A Wipe EFS/NVM ] [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Operation: Reset EFS [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Selected model: SM-N900A [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Software version: 25.2 [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Waiting ADB device... OK [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Reading phone info... [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Model: SAMSUNG-SM-N900A [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Android version: 4.3 [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Product code: SM-N900AZKEATT [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Phone version: N900AUCUBMI1 [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] PDA version: N900AUCUBMI1 [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] CSC version: N900AATTBMI1 [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] CSC country code: USA [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] CSC sales code: ATT [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] HW version: REV0.3 [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Phone S/N: R31DB0FH3TE [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Modem board: MSM8974 [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] RF cal date: 2013.11.09 [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] IMEI: 358579052959054 [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Checking Super user right... true [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Backuping EFS... OK [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Reseting EFS... OK [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] Rebooting phone... OK [ 01/05/2016 2:45:00 AM SM-N900A Reset EFS ] [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] Operation: Write CERT [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] Selected model: SM-N900A [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] Software version: 25.2 [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] Checking certificate file... OK [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] KEY ID: 0813 [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] Waiting ADB device... OK [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] Reading phone info... [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] Model: SAMSUNG-SM-N900A [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] Android version: 4.3 [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] Product code: SM-N900AZKEATT [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] Phone version: N900AUCUBMI1 [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] PDA version: N900AUCUBMI1 [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] CSC version: N900AATTBMI1 [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] CSC country code: USA [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] CSC sales code: ATT [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] HW version: REV0.3 [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] Phone S/N: [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] Modem board: MSM8974 [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] RF cal date: 2013.11.09 [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] IMEI: 358579052959054 [ 01/05/2016 2:46:00 AM SM-N900A Write CERT ] Initialization AT RIL... error [ 01/05/2016 2:49:00 AM SM-N900A Wipe EFS/NVM ] Operation: Wipe EFS/NVM [ 01/05/2016 2:49:00 AM SM-N900A Wipe EFS/NVM ] Selected model: SM-N900A [ 01/05/2016 2:49:00 AM SM-N900A Wipe EFS/NVM ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 2:49:00 AM SM-N900A Wipe EFS/NVM ] Software version: 25.2 [ 01/05/2016 2:49:00 AM SM-N900A Wipe EFS/NVM ] [ 01/05/2016 2:49:00 AM SM-N900A Wipe EFS/NVM ] Searching Samsung USB Flash Interface... not found [ 01/05/2016 2:49:00 AM SM-N900A Wipe EFS/NVM ] [ 01/05/2016 2:50:00 AM SM-N900A Wipe EFS/NVM ] Operation: Wipe EFS/NVM [ 01/05/2016 2:50:00 AM SM-N900A Wipe EFS/NVM ] Selected model: SM-N900A [ 01/05/2016 2:50:00 AM SM-N900A Wipe EFS/NVM ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 2:50:00 AM SM-N900A Wipe EFS/NVM ] Software version: 25.2 [ 01/05/2016 2:50:00 AM SM-N900A Wipe EFS/NVM ] [ 01/05/2016 2:50:00 AM SM-N900A Wipe EFS/NVM ] Searching Samsung USB Flash Interface... not found [ 01/05/2016 2:50:00 AM SM-N900A Wipe EFS/NVM ] [ 01/05/2016 2:50:00 AM SM-N900A Wipe EFS/NVM ] Operation: Wipe EFS/NVM [ 01/05/2016 2:50:00 AM SM-N900A Wipe EFS/NVM ] Selected model: SM-N900A [ 01/05/2016 2:50:00 AM SM-N900A Wipe EFS/NVM ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 2:50:00 AM SM-N900A Wipe EFS/NVM ] Software version: 25.2 [ 01/05/2016 2:50:00 AM SM-N900A Wipe EFS/NVM ] [ 01/05/2016 2:50:00 AM SM-N900A Wipe EFS/NVM ] Searching Samsung USB Flash Interface... not found [ 01/05/2016 2:50:00 AM SM-N900A Wipe EFS/NVM ] [ 01/05/2016 2:50:00 AM SM-N900A Disable Factory Mode ] Operation: Disable Factory Mode [ 01/05/2016 2:50:00 AM SM-N900A Disable Factory Mode ] Selected model: SM-N900A [ 01/05/2016 2:50:00 AM SM-N900A Disable Factory Mode ] Selected port: COM10 Easy Jtag Control Port [ 01/05/2016 2:50:00 AM SM-N900A Disable Factory Mode ] Software version: 25.2 [ 01/05/2016 2:50:00 AM SM-N900A Disable Factory Mode ] [ 01/05/2016 2:50:00 AM SM-N900A Disable Factory Mode ] ADB device not selected [ 01/05/2016 2:50:00 AM SM-N900A Disable Factory Mode ] [ 01/05/2016 2:51:00 AM SM-N900A Wipe EFS/NVM ] Operation: Wipe EFS/NVM [ 01/05/2016 2:51:00 AM SM-N900A Wipe EFS/NVM ] Selected model: SM-N900A [ 01/05/2016 2:51:00 AM SM-N900A Wipe EFS/NVM ] Selected port: COM10 Easy Jtag Control Port [ 01/05/2016 2:51:00 AM SM-N900A Wipe EFS/NVM ] Software version: 25.2 [ 01/05/2016 2:51:00 AM SM-N900A Wipe EFS/NVM ] [ 01/05/2016 2:51:00 AM SM-N900A Wipe EFS/NVM ] Searching Samsung USB Flash Interface... detected COM4 [ 01/05/2016 2:51:00 AM SM-N900A Wipe EFS/NVM ] Setup connection... OK [ 01/05/2016 2:51:00 AM SM-N900A Wipe EFS/NVM ] Reading PIT from phone... OK [ 01/05/2016 2:51:00 AM SM-N900A Wipe EFS/NVM ] Erasing MODEMST1... OK [ 01/05/2016 2:51:00 AM SM-N900A Wipe EFS/NVM ] Erasing MODEMST2... OK [ 01/05/2016 2:51:00 AM SM-N900A Wipe EFS/NVM ] Erasing FSG... OK [ 01/05/2016 2:51:00 AM SM-N900A Wipe EFS/NVM ] Wipe NVM done [ 01/05/2016 2:51:00 AM SM-N900A Wipe EFS/NVM ] [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] Operation: Write CERT [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] Selected model: SM-N900A [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] Software version: 25.2 [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] Checking certificate file... OK [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] KEY ID: 0813 [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] Waiting ADB device... OK [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] Reading phone info... [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] Model: SAMSUNG-SM-N900A [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] Android version: 4.3 [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] Product code: Not Active [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] Phone version: N900AUCUBMI1 [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] PDA version: N900AUCUBMI1 [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] CSC version: N900AATTBMI1 [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] CSC country code: USA [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] CSC sales code: ATT [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] HW version: N900A.00 [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] Phone S/N: [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] Modem board: MSM8974 [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] RF cal date: NONE [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] IMEI: [ 01/05/2016 3:05:00 AM SM-N900A Write CERT ] Initialization AT RIL... error [ 01/05/2016 3:10:00 AM SM-N900A Write CERT ] [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] Operation: Write CERT [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] Selected model: SM-N900A [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] Selected port: COM10 Easy Jtag Control Port [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] Software version: 25.2 [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] Checking certificate file... OK [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] KEY ID: 0813 [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] Waiting ADB device... OK [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] Reading phone info... [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] Model: SAMSUNG-SM-N900A [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] Android version: 4.3 [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] Product code: Not Active [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] Phone version: N900AUCUBMI1 [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] PDA version: N900AUCUBMI1 [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] CSC version: N900AATTBMI1 [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] CSC country code: USA [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] CSC sales code: ATT [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] HW version: N900A.00 [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] Phone S/N: [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] Modem board: MSM8974 [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] RF cal date: NONE [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] IMEI: [ 01/05/2016 6:15:00 AM SM-N900A Write CERT ] Initialization AT RIL... error [ 01/05/2016 6:19:00 AM SM-N900A Write CERT ] [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] Operation: Write CERT [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] Selected model: SM-N900A [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] Selected port: COM10 Easy Jtag Control Port [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] Software version: 25.2 [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] Checking certificate file... OK [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] KEY ID: 0813 [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] Waiting ADB device... OK [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] Reading phone info... [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] Model: SAMSUNG-SM-N900A [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] Android version: 4.3 [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] Product code: Not Active [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] Phone version: N900AUCUBMI1 [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] PDA version: N900AUCUBMI1 [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] CSC version: N900AATTBMI1 [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] CSC country code: USA [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] CSC sales code: ATT [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] HW version: N900A.00 [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] Phone S/N: [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] Modem board: MSM8974 [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] RF cal date: NONE [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] IMEI: [ 01/05/2016 6:40:00 AM SM-N900A Write CERT ] Initialization AT RIL... error [ 01/05/2016 6:43:00 AM SM-N900A Write CERT ] [ 01/05/2016 6:45:00 AM SM-N900A Reset MSL ] Operation: Reset MSL [ 01/05/2016 6:45:00 AM SM-N900A Reset MSL ] Selected model: SM-N900A [ 01/05/2016 6:45:00 AM SM-N900A Reset MSL ] Selected port: COM10 Easy Jtag Control Port [ 01/05/2016 6:45:00 AM SM-N900A Reset MSL ] Software version: 25.2 [ 01/05/2016 6:45:00 AM SM-N900A Reset MSL ] [ 01/05/2016 6:45:00 AM SM-N900A Reset MSL ] Reading phone info... no answer from phone [ 01/05/2016 6:45:00 AM SM-N900A Reset MSL ] [ 01/05/2016 6:46:00 AM SM-N900A Reset MSL ] Operation: Reset MSL [ 01/05/2016 6:46:00 AM SM-N900A Reset MSL ] Selected model: SM-N900A [ 01/05/2016 6:46:00 AM SM-N900A Reset MSL ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 6:46:00 AM SM-N900A Reset MSL ] Software version: 25.2 [ 01/05/2016 6:46:00 AM SM-N900A Reset MSL ] [ 01/05/2016 6:46:00 AM SM-N900A Reset MSL ] Reading phone info... [ 01/05/2016 6:46:00 AM SM-N900A Reset MSL ] Reading IMEI... OK [ 01/05/2016 6:46:00 AM SM-N900A Reset MSL ] IMEI: 0 [ 01/05/2016 6:46:00 AM SM-N900A Reset MSL ] Reseting MSL security... OK [ 01/05/2016 6:46:00 AM SM-N900A Reset MSL ] Reseting... OK [ 01/05/2016 6:46:00 AM SM-N900A Reset MSL ] Reset MSL done [ 01/05/2016 6:46:00 AM SM-N900A Reset MSL ] [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] Operation: Write CERT [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] Selected model: SM-N900A [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] Software version: 25.2 [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] Checking certificate file... OK [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] KEY ID: 0813 [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] Waiting ADB device... OK [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] Reading phone info... [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] Model: SAMSUNG-SM-N900A [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] Android version: 4.3 [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] Product code: Not Active [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] Phone version: N900AUCUBMI1 [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] PDA version: N900AUCUBMI1 [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] CSC version: N900AATTBMI1 [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] CSC country code: USA [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] CSC sales code: ATT [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] HW version: N900A.00 [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] Phone S/N: [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] Modem board: MSM8974 [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] RF cal date: NONE [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] IMEI: [ 01/05/2016 6:47:00 AM SM-N900A Write CERT ] Initialization AT RIL... error [ 01/05/2016 6:51:00 AM SM-N900A Write CERT ] [ 01/05/2016 6:52:00 AM SM-N900A Wipe EFS/NVM ] Operation: Wipe EFS/NVM [ 01/05/2016 6:52:00 AM SM-N900A Wipe EFS/NVM ] Selected model: SM-N900A [ 01/05/2016 6:52:00 AM SM-N900A Wipe EFS/NVM ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 6:52:00 AM SM-N900A Wipe EFS/NVM ] Software version: 25.2 [ 01/05/2016 6:52:00 AM SM-N900A Wipe EFS/NVM ] [ 01/05/2016 6:52:00 AM SM-N900A Wipe EFS/NVM ] Searching Samsung USB Flash Interface... not found [ 01/05/2016 6:52:00 AM SM-N900A Wipe EFS/NVM ] [ 01/05/2016 6:53:00 AM SM-N900A Wipe EFS/NVM ] Operation: Wipe EFS/NVM [ 01/05/2016 6:53:00 AM SM-N900A Wipe EFS/NVM ] Selected model: SM-N900A [ 01/05/2016 6:53:00 AM SM-N900A Wipe EFS/NVM ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 6:53:00 AM SM-N900A Wipe EFS/NVM ] Software version: 25.2 [ 01/05/2016 6:53:00 AM SM-N900A Wipe EFS/NVM ] [ 01/05/2016 6:53:00 AM SM-N900A Wipe EFS/NVM ] Searching Samsung USB Flash Interface... detected COM4 [ 01/05/2016 6:53:00 AM SM-N900A Wipe EFS/NVM ] Setup connection... OK [ 01/05/2016 6:53:00 AM SM-N900A Wipe EFS/NVM ] Reading PIT from phone... OK [ 01/05/2016 6:53:00 AM SM-N900A Wipe EFS/NVM ] Erasing MODEMST1... OK [ 01/05/2016 6:53:00 AM SM-N900A Wipe EFS/NVM ] Erasing MODEMST2... OK [ 01/05/2016 6:53:00 AM SM-N900A Wipe EFS/NVM ] Erasing FSG... OK [ 01/05/2016 6:53:00 AM SM-N900A Wipe EFS/NVM ] Wipe NVM done [ 01/05/2016 6:53:00 AM SM-N900A Wipe EFS/NVM ] [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] Operation: Write CERT [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] Selected model: SM-N900A [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] Software version: 25.2 [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] Checking certificate file... OK [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] KEY ID: 0813 [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] Waiting ADB device... [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] Please, allow USB debugging on phone... OK [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] Reading phone info... [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] Model: SAMSUNG-SM-N900A [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] Android version: 4.3 [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] Product code: Not Active [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] Phone version: N900AUCUBMI1 [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] PDA version: N900AUCUBMI1 [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] CSC version: N900AATTBMI1 [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] CSC country code: USA [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] CSC sales code: ATT [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] HW version: N900A.00 [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] Phone S/N: [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] Modem board: MSM8974 [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] RF cal date: NONE [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] IMEI: [ 01/05/2016 7:01:00 AM SM-N900A Write CERT ] Initialization AT RIL... error [ 01/05/2016 7:03:00 AM SM-N900A Write CERT ] [ 01/05/2016 7:03:00 AM SM-N900A Flash ] Operation: Flash [ 01/05/2016 7:03:00 AM SM-N900A Flash ] Selected model: SM-N900A [ 01/05/2016 7:03:00 AM SM-N900A Flash ] Software version: 25.2 [ 01/05/2016 7:03:00 AM SM-N900A Flash ] [ 01/05/2016 7:03:00 AM SM-N900A Flash ] Searching phone and switching to flash mode... OK [ 01/05/2016 7:03:00 AM SM-N900A Flash ] [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Operation: Flash [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Selected model: SM-N900A [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Software version: 25.2 [ 01/05/2016 7:04:00 AM SM-N900A Flash ] [ 01/05/2016 7:04:00 AM SM-N900A Flash ] File analysis... OK [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Total file size: 0x7CD652C0 (1997 Mb) [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Searching USB Flash Interface... detected COM4 [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Setup connection... OK [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Reading PIT from phone... OK [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Sending sbl1.mbn... OK [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Sending aboot.mbn... OK [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Sending rpm.mbn... OK [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Sending tz.mbn... OK [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Sending sdi.mbn... OK [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Sending NON-HLOS.bin... OK [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Sending boot.img... OK [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Sending recovery.img... OK [ 01/05/2016 7:04:00 AM SM-N900A Flash ] Sending system.img.ext4... OK [ 01/05/2016 7:08:00 AM SM-N900A Flash ] Sending modem.bin... OK [ 01/05/2016 7:08:00 AM SM-N900A Flash ] Sending cache.img.ext4... OK [ 01/05/2016 7:08:00 AM SM-N900A Flash ] Flashing done (time - 00:04:13) [ 01/05/2016 7:08:00 AM SM-N900A Flash ] [ 01/05/2016 7:11:00 AM SM-N900A Write CERT ] Operation: Write CERT [ 01/05/2016 7:11:00 AM SM-N900A Write CERT ] Selected model: SM-N900A [ 01/05/2016 7:11:00 AM SM-N900A Write CERT ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 7:11:00 AM SM-N900A Write CERT ] Software version: 25.2 [ 01/05/2016 7:11:00 AM SM-N900A Write CERT ] [ 01/05/2016 7:11:00 AM SM-N900A Write CERT ] Checking certificate file... OK [ 01/05/2016 7:11:00 AM SM-N900A Write CERT ] KEY ID: 0813 [ 01/05/2016 7:11:00 AM SM-N900A Write CERT ] Waiting ADB device... OK [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] Reading phone info... [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] Model: SAMSUNG-SM-N900A [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] Android version: 4.3 [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] Product code: Not Active [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] Phone version: N900AUCUBMI9 [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] PDA version: N900AUCUBMI9 [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] CSC version: N900AATTBMI9 [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] CSC country code: USA [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] CSC sales code: ATT [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] HW version: N900A.00 [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] Phone S/N: [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] Modem board: MSM8974 [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] RF cal date: NONE [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] IMEI: [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] Initialization AT RIL... error [ 01/05/2016 7:12:00 AM SM-N900A Write CERT ] [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] Operation: Write EFS [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] Selected model: SM-N900A [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] Software version: 25.2 [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] Waiting ADB device... OK [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] Reading phone info... [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] Model: SAMSUNG-SM-N900A [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] Android version: 4.3 [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] Product code: Not Active [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] Phone version: N900AUCUBMI9 [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] PDA version: N900AUCUBMI9 [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] CSC version: N900AATTBMI9 [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] CSC country code: USA [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] CSC sales code: ATT [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] HW version: N900A.00 [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] Phone S/N: [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] Modem board: MSM8974 [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] RF cal date: NONE [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] IMEI: [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] Checking Super user right... false [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] This model not supported for auto root [ 01/05/2016 7:13:00 AM SM-N900A Write EFS ] [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Operation: Write EFS [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Selected model: SM-N900A [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Software version: 25.2 [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Waiting ADB device... OK [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Reading phone info... [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Model: SAMSUNG-SM-N900A [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Android version: 4.3 [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Product code: Not Active [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Phone version: N900AUCUBMI9 [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] PDA version: N900AUCUBMI9 [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] CSC version: N900AATTBMI9 [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] CSC country code: USA [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] CSC sales code: ATT [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] HW version: N900A.00 [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Phone S/N: [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Modem board: MSM8974 [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] RF cal date: NONE [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] IMEI: [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Checking Super user right... true [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Extracting EFS file... OK [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Converting img to ext4... OK [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Writing EFS to phone... OK [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] Rebooting phone... OK [ 01/05/2016 7:20:00 AM SM-N900A Write EFS ] [ 01/05/2016 7:23:00 AM SM-N900A Write QCN ] Operation: Write QCN [ 01/05/2016 7:23:00 AM SM-N900A Write QCN ] Selected model: SM-N900A [ 01/05/2016 7:23:00 AM SM-N900A Write QCN ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 7:23:00 AM SM-N900A Write QCN ] Software version: 25.2 [ 01/05/2016 7:23:00 AM SM-N900A Write QCN ] [ 01/05/2016 7:23:00 AM SM-N900A Write QCN ] Reading QCN file... OK [ 01/05/2016 7:23:00 AM SM-N900A Write QCN ] Reading ID... OK [ 01/05/2016 7:23:00 AM SM-N900A Write QCN ] Detected ID: 00000FF3 (MSM8974) [ 01/05/2016 7:23:00 AM SM-N900A Write QCN ] SW Version: SET_BY_CM [ 01/05/2016 7:23:00 AM SM-N900A Write QCN ] Checking paths... OK [ 01/05/2016 7:23:00 AM SM-N900A Write QCN ] Restoring EFS Backup... OK [ 01/05/2016 7:24:00 AM SM-N900A Write QCN ] Restoring NV Items... OK [ 01/05/2016 7:24:00 AM SM-N900A Write QCN ] Restoring NV Item SIM1... OK [ 01/05/2016 7:24:00 AM SM-N900A Write QCN ] Restoring NV Item SIM2... OK [ 01/05/2016 7:24:00 AM SM-N900A Write QCN ] Restoring Provisioning Item Files... OK [ 01/05/2016 7:24:00 AM SM-N900A Write QCN ] Restore QCN done [ 01/05/2016 7:24:00 AM SM-N900A Write QCN ] [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Operation: Write SEC [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Selected model: SM-N900A [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Software version: 25.2 [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Waiting ADB device... OK [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Reading phone info... [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Model: SAMSUNG-SM-N900A [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Android version: 4.3 [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Product code: Not Active [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Phone version: N900AUCUBMI9 [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] PDA version: N900AUCUBMI9 [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] CSC version: N900AATTBMI9 [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] CSC country code: USA [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] CSC sales code: ATT [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] HW version: N900A.00 [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Phone S/N: R31DB0FH3TE [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Modem board: MSM8974 [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] RF cal date: 2013.11.09 [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] IMEI: [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Checking Super user right... true [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Writing files... OK [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Rebooting phone... OK [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] Write SEC done [ 01/05/2016 7:26:00 AM SM-N900A Write SEC ] [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Operation: Write CERT [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Selected model: SM-N900A [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Selected port: COM44 SAMSUNG Mobile USB Serial Port [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Software version: 25.2 [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Checking certificate file... OK [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] KEY ID: 0813 [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Waiting ADB device... OK [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Reading phone info... [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Model: SAMSUNG-SM-N900A [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Android version: 4.3 [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Product code: SM-N900AZKEATT [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Phone version: N900AUCUBMI9 [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] PDA version: N900AUCUBMI9 [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] CSC version: N900AATTBMI9 [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] CSC country code: USA [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] CSC sales code: ATT [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] HW version: REV0.3 [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Phone S/N: R31DB0FH3TE [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Modem board: MSM8974 [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] RF cal date: 2013.11.09 [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] IMEI: 358579052959054 [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Initialization AT RIL... OK [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Bypass MSL... OK [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Checking for compatible phone and cert... OK [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Phone KEY ID: 0813 [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Writing CERT... OK [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Checking CERT status... OK [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] Rebooting phone... OK [ 01/05/2016 7:28:00 AM SM-N900A Write CERT ] [ 01/05/2016 7:46:00 AM SM-N900A Flash ] Operation: Flash [ 01/05/2016 7:46:00 AM SM-N900A Flash ] Selected model: SM-N900A [ 01/05/2016 7:46:00 AM SM-N900A Flash ] Software version: 25.2 [ 01/05/2016 7:46:00 AM SM-N900A Flash ] [ 01/05/2016 7:46:00 AM SM-N900A Flash ] Searching phone and switching to flash mode... OK [ 01/05/2016 7:46:00 AM SM-N900A Flash ] [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Operation: Flash [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Selected model: SM-N900A [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Software version: 25.2 [ 01/05/2016 7:47:00 AM SM-N900A Flash ] [ 01/05/2016 7:47:00 AM SM-N900A Flash ] File analysis... OK [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Total file size: 0x9C2FFB04 (2498 Mb) [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Searching USB Flash Interface... detected COM4 [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Setup connection... OK [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Set PIT file... OK [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Reading PIT from phone... OK [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Sending aboot.mbn... OK [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Sending sbl1.mbn... OK [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Sending rpm.mbn... OK [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Sending tz.mbn... OK [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Sending sdi.mbn... OK [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Sending NON-HLOS.bin... OK [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Sending boot.img... OK [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Sending recovery.img... OK [ 01/05/2016 7:47:00 AM SM-N900A Flash ] Sending system.img.ext4... OK [ 01/05/2016 7:52:00 AM SM-N900A Flash ] Sending persist.img.ext4... OK [ 01/05/2016 7:52:00 AM SM-N900A Flash ] Sending modem.bin... OK [ 01/05/2016 7:52:00 AM SM-N900A Flash ] Sending cache.img.ext4... OK [ 01/05/2016 7:52:00 AM SM-N900A Flash ] Flashing done (time - 00:05:15) [ 01/05/2016 7:52:00 AM SM-N900A Flash ] |
05-02-2016, 00:18 | #16092 (permalink) |
Insane Poster Join Date: Jan 2016
Member: 2510231 Status: Offline Thanks Meter: 11 | Sm-g928a oj1 unlocked Operation: Unlock Selected model: SM-G928A Software version: 25.2 Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G928A Android version: 5.1.1 Product code: SM-G928AZDEATT Phone version: G928AUCU2AOJ1 PDA version: G928AUCU2AOJ1 CSC version: G928AATT2AOJ1 CSC country code: USA CSC sales code: ATT HW version: REV0.1 Phone S/N: R38G70DWJCA Modem board: SHANNON333 RF cal date: 20150805 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK Reading nv data... OK Checking NV data... OK Calculating... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.25.2 |
05-02-2016, 18:42 | #16094 (permalink) |
Freak Poster Join Date: Nov 2015 Location: Alabama, United States Age: 41
Member: 2489757 Status: Offline Thanks Meter: 6 | Operation: Unlock Selected model: SGH-M919 Selected port: COM67 SAMSUNG Mobile USB Serial Port Software version: 25.2 Reading phone info... Reading IMEI... OK IMEI: 014327002219963 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.25.2 |
05-02-2016, 19:13 | #16095 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung SM-J500g Frp Reset Code: Operation: Reset FRP/React/EE Selected model: SM-J500G Selected port: COM1 Communications Port Software version: 25.2 Searching Samsung USB Flash Interface... detected COM24 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.25.2 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
