04-05-2017, 20:02 | #18076 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Cox`s Bazar, Bangladesh Age: 33
Member: 2097333 Status: Offline Sonork: 100.1675582 Thanks Meter: 44 | SM-J106B 6.0 Read Unlock Code done by Z3X BoX SM-J106B 6.0 Read Unlock Code done Without Root by Z3X BoX Code: UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-J106B Software version: 27.7 Searching Samsung modem... detected COM49 Reading phone info... Ok Model: SM-J106B Version: J106BDXU0APK2/J106BOLB0APL2/J106BDXU0APJ2/J106BDXU0APK2 Product code: SM-J106BZWDXME Phone SN: R21HB03WAQJ IMEI: 354614081152654 Unique number: C8G010532D4D9A3 Reading codes... Ok Please wait, calculating codes... OK (time - 00:04:01) Freeze code: 94758094 NET lock: 50620795 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.7 |
The Following User Says Thank You to ripon074 For This Useful Post: |
04-05-2017, 20:08 | #18077 (permalink) |
Member: 2097333 Status: Offline Sonork: 100.1675582 Thanks Meter: 44 | SM-J500H FRP Reset Done without Combination firmware by Z3X BOX Code: UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Unlock' button for direct unlock. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP/React/EE Selected model: SM-J500H Selected port: COM1 Communications Port Software version: 27.7 Searching Samsung USB Flash interface... COM31 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP lock... Ok Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.27.7 |
04-05-2017, 20:12 | #18078 (permalink) |
Member: 2097333 Status: Offline Sonork: 100.1675582 Thanks Meter: 44 | SM-J120F Read Unlock Code done without Root Device By Z3X BOX Code: UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Read Codes Selected model: SM-J120F Software version: 27.8 Searching Samsung modem... detected COM178 Reading phone info... Ok Model: SM-J120F AP version: J120FXXU1APJ1 CSC version: J120FOJV1APJ5 CP version: J120FXXU1APJ2 Product code: SM-J120FZDDKSA Phone SN: R58HB6LQSQD Unique number: CFN007629F20CA3 Reading IMEI... Ok IMEI: 352719089681547 (SIGN: OK) IMEI 2: 352720089681545 (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON308 HWID: 70 D2 92 BE F5 7E 32 5B 29 A4 98 24 7A EE 12 6D Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:15) Freeze code: 13918248 NET lock: 51405374 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.8 |
04-05-2017, 20:14 | #18079 (permalink) |
Member: 2097333 Status: Offline Sonork: 100.1675582 Thanks Meter: 44 | SM-J710F 6.0 Read Unlock Code done by Z3X BOX Code: UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. Operation: Read Codes Selected model: SM-J710F Software version: 27.8 Searching Samsung modem... detected COM185 Reading phone info... Ok Model: SM-J710F AP version: J710FXXU1APLM CSC version: J710FOJV1APJ1 CP version: J710FXXU1APH4 Product code: SM-J710FZDDKSA Phone SN: RF8H92924CP Unique number: CAJ033E24F04993 Reading IMEI... Ok IMEI: 357412075180022 (SIGN: OK) IMEI 2: 357413075180020 (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON315 HWID: 36 00 00 00 00 00 00 00 00 00 00 00 94 E4 D1 71 Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:02:18) Freeze code: 85847026 NET lock: 07573815 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.8 |
04-05-2017, 20:15 | #18080 (permalink) |
Member: 2097333 Status: Offline Sonork: 100.1675582 Thanks Meter: 44 | SM-J106B Read Unlock Code done by Z3X Box Code: UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-J106B Software version: 27.9 Searching Samsung modem... detected COM18 Reading phone info... Ok Model: SM-J106B Version: J106BDXU0APL3/J106BOLB0APL2/J106BDXU0APJ2/J106BDXU0APL3 Product code: SM-J106BZKDXME Phone SN: RV1J21ARLEW IMEI: 355002084358735 Unique number: C8G013472C63A24 Reading codes... Ok Please wait, calculating codes... OK (time - 00:03:31) Freeze code: 72502919 NET lock: 83685393 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.9 |
04-06-2017, 01:00 | #18083 (permalink) |
Junior Member Join Date: Jul 2016 Location: Colombia
Member: 2593809 Status: Offline Thanks Meter: 7 | Operation: Repair Selected model: SM-G313M Software version: 28.0 Waiting ADB device... Ok Reading phone info... Model: SM-G313M Android version: 4.4.2 Product code: SM-G313MHAHZTA Phone version: G313MUBU0ANK2 PDA version: G313MUBU0ANK2 CSC version: G313MTFG0ANK1 CSC country code: OPEN CSC sales code: TFG HW version: MP 0.301 Phone SN: R21F85MHAMD Modem board: RF cal date: 20140826 IMEI: Checking Super user right... true Reading data from phone... Ok Writing data to phone... Ok Patching CERT check... Ok Rebooting phone... Ok Repair done Done with Samsung Tool PRO v.28.0 |
The Following User Says Thank You to vinrkx For This Useful Post: |
04-06-2017, 16:11 | #18085 (permalink) |
Freak Poster Join Date: Jun 2010 Location: South Azerbaycan Age: 40
Member: 1333047 Status: Offline Sonork: 100.1618775 Thanks Meter: 278 | SM-J700F Network Unlock w/o root Note: try with regular method (not new unlock) Searching Samsung modem... detected COM9 Reading phone info... Ok Model: SM-J700F AP version: J700FXXU1APA2 CSC version: J700FOJV1AOFJ CP version: J700FXXU2APE1 Product code: SM-J700FZKDXSG Phone SN: RZ8HA0TM7NE Unique number: CAJ03E8CE424193 Reading IMEI... Ok IMEI: 352347085217759 (SIGN: OK) IMEI 2: 352348085217757 (SIGN: OK) Reading data from phone... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.27.9 |
The Following User Says Thank You to aydin.gsm1 For This Useful Post: |
04-06-2017, 16:46 | #18086 (permalink) |
Major Poster Join Date: Jun 2008 Location: HYderabad
Member: 802298 Status: Offline Thanks Meter: 6 | Waiting ADB device... Ok Reading phone info... Model: SAMSUNG-SM-J320A Android version: 6.0.1 Product code: SM2J320AZACATT Phone version: J320AUCS2AQA1 PDA version: J320AUCS2AQA1 CSC version: J320AATT2AQA1 CSC country code: USA CSC sales code: ATT HW version: REV1.0 Phone SN: R28HB3P9L0A Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-01-01 RF cal date: 20161125 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data... Ok HWID: 00 FD 40 9E 1B -- -- -- -- -- -- -- E9 E0 9F 5D 1D Calculating... Ok Unlocking... Ok Writing NV data... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.0 |
The Following User Says Thank You to bagi768 For This Useful Post: |
04-06-2017, 18:19 | #18087 (permalink) |
Junior Member Join Date: Dec 2016
Member: 2661200 Status: Offline Thanks Meter: 6 | Operation: Unlock Selected model: GT-S5570I Software version: 28.0 Waiting ADB device... Ok Reading phone info... Model: GT-S5570I Android version: 2.3.6 Product code: Phone version: S5570IXXLH1 PDA version: S5570IBGLH1 CSC version: S5570IXECLH1 CSC country code: Spain CSC sales code: XEC HW version: MP 0.500 Phone SN: Modem board: RF cal date: 20121007 IMEI: 353139058726778 Checking Super user right... false Rooting phone, please wait... Ok Checking Super user right... true Reading data from phone... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.0 |
04-06-2017, 21:51 | #18088 (permalink) |
Freak Poster Join Date: Jul 2015
Member: 2428732 Status: Offline Thanks Meter: 22 | how to unlock g900t 6.0.1 pl1 without downgrade or RooT with Z3X https:// www. youtube.com /watch?v= _OWfzqoEts8&feature= youtu .be move the sp so you could see the video the video by me |
04-06-2017, 22:52 | #18089 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | UNLOCK INSTRUCTIONS: To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP Selected model: SM-G530T1 Software version: 28.0 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... Ok Reading phone info... Model: SM-G530T1 Android version: 5.1.1 Product code: SM2G530TRAATMB Phone version: G530T1UVU1AOH9 PDA version: G530T1UVU1AOH9 CSC version: G530T1TMB1AOH9 CSC country code: USA CSC sales code: TMB HW version: REV0.1 Phone SN: R28GA0WPMBL Chip name: MSM8916 Modem board: MSM8916 RF cal date: 2015.10.13 IMEI: Bypass FRP... Ok For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.28.0 |
04-08-2017, 02:26 | #18090 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Unlock Selected model: SM-J700P Software version: 28.0 Waiting ADB device... Please, allow USB debugging on phone... Ok Reading phone info... Model: SM-J700P Android version: 6.0.1 Product code: Not Active Phone version: J700PVPS1AQA2 PDA version: J700PVPS1AQA2 CSC version: J700PSPT1AQA2 CSC country code: USA CSC sales code: BST HW version: J700P.03 Phone SN: 00000000000 Modem board: MSM8929 RF cal date: 2016.09.29 IMEI: Writing AT RIL... Ok Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.0 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
