09-07-2018, 13:03 | #21016 (permalink) |
Freak Poster Join Date: Oct 2005 Location: Georgia, Zugdidi Age: 48
Member: 195717 Status: Offline Thanks Meter: 54 | Operation: Read Codes via Server Selected model: SM-J330FN Software version: 33.7 Checking Login and Password... OK Ballance: 15 crd. You have 15 credit(s) left. This operation takes 5 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-J330FN Android version: 7.0 PDA version: J330FNXXU2AQK8 CSC version: J330FNXEF2AQK2 Phone version: J330FNXXU2AQK8 Product code: SM-J330FZDNXEF CSC country code: France CSC sales code: XEF Phone SN: R58K13489QF IMEI: 355730090239222 HW version: MP 0.500 RF cal date: 20180115 Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2017-12-01 Boot Warranty bit: 0 Searching server... OK Checking server answer... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Executing... OK Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 30382918 NET lock: 57182730 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.33.7 |
09-07-2018, 16:07 | #21017 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Sm-g925f imei repair done REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Repair Selected model: SM-G925F Software version: 33.7 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 7.0 PDA version: G925FXXU6ERF5 CSC version: G925FVFG6ERF1 Phone version: G925FXXU6ERF7 Product code: SM-G925FZKFSIM CSC country code: Slovenia CSC sales code: SIM Phone SN: RF8G60M46VK IMEI: 359522060778016 HW version: MP 0.60V RF cal date: 20150609 Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2018-06-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... OK HWID: 88 66 C7 74 55 04 00 00 00 00 00 00 00 00 00 00 Calculating... OK Repairing... OK Writing NV data... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.33.7 REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Patch Certificate Selected model: SM-G925F Software version: 33.7 Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 7.0 PDA version: G925FXXU6ERF5 CSC version: G925FVFG6ERF1 Phone version: G925FXXU6ERF7 Product code: SM-G925FZKFSIM CSC country code: Slovenia CSC sales code: SIM Phone SN: RF8G60M46VK IMEI: 356678686798870 HW version: MP 0.60V RF cal date: 20150609 Chip name: EXYNOS7420 Modem board: SHANNON333 Security patch: 2018-06-01 Boot Warranty bit: 1 Checking Super user right... true Initialization zTool... OK Running zTool, please wait... OK Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.33.7 |
09-07-2018, 16:08 | #21018 (permalink) |
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Sm-j700h imei repair done REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. 7. Press 'Patch Certificate' if you have network problem after repairing. 7. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. Operation: Patch Certificate Selected model: SM-J700H/DS Software version: 33.7 Waiting ADB device... OK Reading phone info... Model: SM-J700H Android version: 6.0.1 PDA version: J700HXXU2BPG4 CSC version: J700HOJV2BPG1 Phone version: J700HXXU2BPG1 Product code: SM-J700HZDDXFA CSC country code: SOUTH AFRICA CSC sales code: XFA Phone SN: RF1HA02S6AA IMEI: 356567676500000 HW version: MP 0.401 RF cal date: 20161024 Chip name: EXYNOS7580 Modem board: SHANNON310 Security patch: 2016-08-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.33.7 |
09-07-2018, 19:32 | #21019 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Operation: Unlock Selected model: SM-J700P Software version: 33.7 Waiting ADB device... OK Reading phone info... Model: SM-J700P Android version: 6.0.1 PDA version: J700PVPS1AQD1 CSC version: J700PSPT1AQD1 Phone version: J700PVPS1AQD1 Product code: Not Active CSC country code: USA CSC sales code: BST Phone SN: 00000000000 IMEI: 355628075294735 HW version: J700P.03 RF cal date: 2016.11.29 Chip name: MSM8929 Modem board: MSM8929 Security patch: 2017-04-01 Boot Warranty bit: 1 Writing AT RIL... OK Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.33.7 |
09-08-2018, 13:54 | #21020 (permalink) |
No Life Poster Join Date: Dec 2016 Location: .
Member: 2659717 Status: Offline Thanks Meter: 487 | g965u unlock done Checking Login and Password... OK Ballance: 30 crd. You have 30 credit(s) left. This operation takes 10 credits.Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G965U Android version: 8.0.0 PDA version: G965USQU2ARF7 CSC version: G965UOYN2ARF7 Phone version: G965USQU2ARF7 Product code: SM2G965UZPATMB CSC country code: USA CSC sales code: TMB Phone SN: R28K430HHBR IMEI: 354644091663705 HW version: REV1.1 RF cal date: 2018.05.02 Chip name: SDM845 Modem board: SDM845 Security patch: 2018-06-01 Boot Warranty bit: 0 Searching Samsung diag port... not found Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM32 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... error (0.1) Retry 1... Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.33.7 |
09-08-2018, 15:12 | #21021 (permalink) |
No Life Poster Join Date: Oct 2017
Member: 2766801 Status: Offline Thanks Meter: 182 | Sm-g925f b6 frp ufs done UNLOCK INSTRUCTIONS: New Securiry Type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. 6. Press 'Read codes' button and select 'Read codes New' to read security codes. Old Securiry Type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. 5. Press 'Read codes' button and select 'Read codes' to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Reset FRP UFS Selected model: SM-G925T Selected port: COM97 USB Serial Port Software version: 32.7 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM97 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G925T) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.32.7 |
09-08-2018, 18:42 | #21022 (permalink) |
Freak Poster Join Date: Nov 2006 Location: NJ, USA
Member: 399404 Status: Offline Thanks Meter: 70 | FRP ON J320A DONE USING G925T Old Securiry Type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. 5. Press 'Read codes' button and select 'Read codes' to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. To reset Google account activation lock with UART cable: 1. Phone must be powered off 2. Connect the phone to UART cable. 3. Select correct COM port in port settings. 4. Press 'Reset FRP UFS' and follow the instructions in program. Operation: Reset FRP/React/EE Selected model: SM-G925T Software version: 33.7 Searching Samsung USB Flash interface... COM49 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.33.7 |
09-09-2018, 17:19 | #21024 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2779090 Status: Offline Thanks Meter: 0 | Waiting ADB device... OK Reading phone info... Model: SM-G935F Android version: 7.0 PDA version: G935FXXU2DRC6 CSC version: G935FNEE2DRB5 Phone version: G935FXXU2DRB6 Product code: SM-G935FZDABTU CSC country code: Nordic CSC sales code: NEE Phone SN: RF8HB2VS7AN IMEI: HW version: MP 0.801 RF cal date: 20161123 Chip name: EXYNOS8890 Modem board: SHANNON335 Security patch: 2018-03-01 Boot Warranty bit: Incorrect model selected. This may damage your phone. Continue? Yes Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.33.8 This does not work for me at all. I have G935f and I tried this way you described incl that I even tried G935F and did this also and still doesn't work. Last edited by Sgtcrack; 09-09-2018 at 17:25. |
09-09-2018, 19:30 | #21025 (permalink) |
No Life Poster Join Date: Dec 2006 Location: egypt Age: 37
Member: 419703 Status: Offline Thanks Meter: 123 | To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP Selected model: SM-J700F/DS Software version: 33.8 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-J701F Android version: 7.0 PDA version: J701FXXU3ARB1 CSC version: J701FOJV3ARB1 Phone version: J701FXXU3ARA1 Product code: SM-J701FZSDEGY CSC country code: Egypt CSC sales code: EGY Phone SN: RF8J83VGGEH IMEI: 351569098962912 HW version: MP 0.400 RF cal date: 20170831 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-02-01 Boot Warranty bit: 0 Incorrect model selected. This may damage your phone. Continue? Yes Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.33.8 |
09-09-2018, 19:30 | #21026 (permalink) |
Member: 419703 Status: Offline Thanks Meter: 123 | SM-J700F/DS FRP Reset Done To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP Selected model: SM-J700F/DS Software version: 33.8 You must activate ADB before reset FRP Yes Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes Waiting ADB device... OK Reading phone info... Model: SM-J701F Android version: 7.0 PDA version: J701FXXU3ARB1 CSC version: J701FOJV3ARB1 Phone version: J701FXXU3ARA1 Product code: SM-J701FZSDEGY CSC country code: Egypt CSC sales code: EGY Phone SN: RF8J83VGGEH IMEI: 351569098962912 HW version: MP 0.400 RF cal date: 20170831 Chip name: EXYNOS7870 Modem board: SHANNON315 Security patch: 2018-02-01 Boot Warranty bit: 0 Incorrect model selected. This may damage your phone. Continue? Yes Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.33.8 |
09-10-2018, 03:39 | #21027 (permalink) |
Freak Poster Join Date: Jul 2016 Location: U.S.A
Member: 2604559 Status: Offline Sonork: Ventaslaredo Thanks Meter: 131 | G900T write cert done by z3x box BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-G900T Selected port: COM182 SAMSUNG Mobile USB Serial Port Software version: 32.7 Checking CERT file... OK KEY ID: 0478 Waiting ADB device... OK Reading phone info... Model: SM-G900T Android version: 4.4.2 PDA version: G900TUVU1BNH5 CSC version: G900TTMB1BNH5 Phone version: G900TUVU1BNH5 Product code: SM2G900TZKATMB CSC country code: USA CSC sales code: TMB Phone SN: R38FB07C3RN IMEI: 35255806XXXXXXX HW version: REV1.0 RF cal date: 2014.11.06 Chip name: MSM8974PRO Modem board: MSM8974PRO Boot Warranty bit: 1 Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0478 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.32.7 |
09-10-2018, 11:11 | #21028 (permalink) |
Freak Poster Join Date: May 2015 Location: Ukraine, Lviv
Member: 2396025 Status: Offline Thanks Meter: 78 | A530F Unlock done 08.09.2018 17:35:40 ] Операція: Read Codes via Server [ 08.09.2018 17:35:40 ] Вибрана модель: SM-A530F [ 08.09.2018 17:35:40 ] Версія програми: 33.7 [ 08.09.2018 17:35:40 ] [ 08.09.2018 17:35:40 ] Checking Login and Password... Добре [ 08.09.2018 17:35:41 ] Ballance: 25 crd. [ 08.09.2018 17:35:42 ] You have 25 credit(s) left. This operation takes 5 credits.Continue? Так [ 08.09.2018 17:35:43 ] Очікую на пристрій ADB... Добре [ 08.09.2018 17:35:45 ] Читання інформації з телефону... [ 08.09.2018 17:35:45 ] Модель: SM-A530F [ 08.09.2018 17:35:45 ] Android версія: 8.0.0 [ 08.09.2018 17:35:45 ] PDA версія: A530FXXS3BRH1 [ 08.09.2018 17:35:45 ] CSC версія: A530FOXM3BRG1 [ 08.09.2018 17:35:45 ] Phone версія: A530FXXU3ARH3 [ 08.09.2018 17:35:45 ] Код продукту: SM-A530FZVDPHE [ 08.09.2018 17:35:45 ] Код країни CSC: SPAIN [ 08.09.2018 17:35:45 ] Код продаж CSC: PHE [ 08.09.2018 17:35:45 ] Телефон SN: R58K5042LQJ [ 08.09.2018 17:35:45 ] IMEI: 355624098965922 [ 08.09.2018 17:35:45 ] HW версія: REV0.3 [ 08.09.2018 17:35:45 ] RF cal дата: 20180502 [ 08.09.2018 17:35:45 ] Назва процесора: EXYNOS7885 [ 08.09.2018 17:35:45 ] Ревізія модему: SHANNON327 [ 08.09.2018 17:35:45 ] Security patch: 2018-08-01 [ 08.09.2018 17:35:45 ] Boot Warranty bit: 0 [ 08.09.2018 17:35:47 ] Пошук сервера... Добре [ 08.09.2018 17:35:49 ] Checking server answer... modem required [ 08.09.2018 17:35:49 ] Перезавантаження телефону... Добре [ 08.09.2018 17:35:54 ] Очікую на пристрій ADB... Добре [ 08.09.2018 17:36:23 ] Ініціалізація zTool... Добре [ 08.09.2018 17:36:24 ] Запускається zTool, зачекайте... [ 08.09.2018 17:36:24 ] Старт... Добре [ 08.09.2018 17:36:27 ] Ініціалізація... Добре [ 08.09.2018 17:36:29 ] Генерація та перевірка доказу клієнта... Добре [ 08.09.2018 17:36:29 ] Перевірка доказу клієнтом... Добре [ 08.09.2018 17:36:29 ] Читання даних з телефону... Добре [ 08.09.2018 17:37:03 ] Перезавантаження телефону... Добре [ 08.09.2018 17:37:08 ] Waiting for device to become ready... Добре [ 08.09.2018 17:37:35 ] Читання даних з телефону... Добре [ 08.09.2018 17:37:52 ] Пошук сервера... Добре [ 08.09.2018 17:38:30 ] Waiting for server answer... Добре [ 08.09.2018 17:39:21 ] Checking server answer... Добре [ 08.09.2018 17:39:21 ] Ініціалізація zTool... Добре [ 08.09.2018 17:39:22 ] Запускається zTool, зачекайте... [ 08.09.2018 17:39:22 ] Старт... Добре [ 08.09.2018 17:39:25 ] Ініціалізація... Добре [ 08.09.2018 17:39:27 ] Генерація та перевірка доказу клієнта... Добре [ 08.09.2018 17:39:27 ] Перевірка доказу клієнтом... Добре [ 08.09.2018 17:39:27 ] Executing... Добре [ 08.09.2018 17:40:03 ] Читання даних з телефону... Добре [ 08.09.2018 17:40:26 ] Калькулювання... Добре [ 08.09.2018 17:40:30 ] Пошук сервера... Добре [ 08.09.2018 17:40:34 ] Waiting for server answer... Добре [ 08.09.2018 17:41:23 ] Код заморозки: 80939140 [ 08.09.2018 17:41:23 ] NET замок: 92607428 [ 08.09.2018 17:41:23 ] SUB замок: 00000000 [ 08.09.2018 17:41:23 ] SP замок: 00000000 [ 08.09.2018 17:41:23 ] CP замок: 00000000 [ 08.09.2018 17:41:23 ] SIM замок: 00000000 [ 08.09.2018 17:41:23 ] Щоб перевірити статус блокування: *#7465625# |
09-10-2018, 12:41 | #21029 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Abidjan,ivory coast
Member: 1272267 Status: Offline Sonork: 100.1667652 Thanks Meter: 408 | SM-G950F S8 Read code Done by z3x UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone using sever. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings) Operation: Read Codes via Server Selected model: SM-G950F Software version: 33.7 Checking Login and Password... OK Ballance: 35 crd. You have 35 credit(s) left. This operation takes 5 credits.Continue? Yes Searching Samsung modem... detected COM8 Reading phone info... Model: SM-G950F AP version: G950FXXU1AQJ1 CSC version: G950FOVF1AQJ1 CP version: G950FXXU1AQJ1 Product code: VOD Phone SN: RF8J42PTV6H IMEI: 358793086056205 Unique number: CE031713E9F3DC820D Searching Samsung diag port... detected COM9 Reading phone info... OK CP version: G950FXXU1AQJ1 CP build: Oct 11 2017 15:46:48 Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 04942472 NET lock: 79304131 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.33.7 |
09-10-2018, 15:37 | #21030 (permalink) |
No Life Poster Join Date: Oct 2011 Location: online
Member: 1680232 Status: Offline Sonork: 100.1611221 Thanks Meter: 226 | Waiting ADB device... OK Reading phone info... Model: SM-G930T Android version: 7.0 PDA version: G930TUVU4BQG5 CSC version: G930TTMB4BQG5 Phone version: G930TUVU4BQG5 Product code: SM-G930TZKATMB CSC country code: USA CSC sales code: TMB Phone SN: R28HC07FYAT IMEI: 359755075035929 HW version: REV0.6 RF cal date: 2016.12.03 Chip name: MSM8996 Modem board: MSM8996 Security patch: 2017-07-01 Boot Warranty bit: 0 Rebooting phone... OK Waiting ADB device... OK Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting to upload... OK Searching Ramdump interface... COM24 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.33.8 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
