Old 09-11-2010, 16:22   #1516 (permalink)
JINDALGSM™'s Avatar
Member: 467045
Sonork: 100.1603919
Thanks Meter: 1,705
samsung e2130 blinking repair successfully
samsung e2130 blinking repair successfully just flash with this version (E2130DDIL1)
Selected model: E2130
Selected com port: COM9
Selected speed port: 921600
Please, connect phone and press power button 3 seconds
Phone Detected
Sending loader1... OK
Flash ID: 08
Sending loader2... OK
Start TFS format... OK
Start NOR flash
NOR flash - ok
Start Flash TFS
Download - ok
Elapsed time: 707 second, sw ver: 3.4.0066
Old 09-11-2010, 17:44   #1517 (permalink)
champions1's Avatar
Member: 1157490
Sonork: 100.1638346
Thanks Meter: 74
s3370 successfully unlocked
Count supported models - 203
Model: GT-S3370
CountryCode: H3G
Factory SW: S3370NEJD1_3UKJD1
UniqueNumber: 74050001854575
MemoryPhone: K522H1HACC(S3370)S
IMEI: 358663030xxx68/9
Phone S/N: R2YZ537269
Build: Q6270B-KPVZL-1.5.55011ST
Searching SysInfo... OK
Reading SysInfo... OK
Calculating codes... OK (time - 00:01:06)
Freeze code: 63974084
NET lock: #7465625*638*68647157#
Sub lock: #7465625*782*00000000#
SP lock: #7465625*77*00000000#
CP lock: #7465625*27*00000000#
Multi lock: #7465625*685*00000000#
For check lock status: *#7465625#
Old 09-11-2010, 18:04   #1518 (permalink)
netmobile's Avatar
Member: 746276
Sonork: 100.1609752
Thanks Meter: 675
Samsung A177 locked to at&t, unlocked without any problem.
Old 09-11-2010, 19:31   #1519 (permalink)
Member: 306410
Thanks Meter: 58
Selected model: J600E
Selected com port: COM12
Selected speed port: 460800
Start generation to file...
00666666
Encode *.s3 - wait... OK
EEP saved to file-> D:\Program Files\Z3X\Samsung\All\J600E_RPQS114969H_.sre
Phone must be ON!
Entering TestMode... OK
Start calibrate NVM
Calibrate NVM field - fail
Calibrate NVM - Ok
Repair OTP - ok
Elapsed time: 78 second, sw ver: 3.4.0066
Phone must be ON!
Start unlock........
SW: 600EXXHB1
IMEI: 35367502088087
MSL DEACTIVATED - TRUE
NET and SIM lock - deactivated
Phone password change into -> 00000000
Unlock - ok
Elapsed time: 19 second, sw ver: 3.4.0066
cant rep+unlock with ust no work
Old 09-11-2010, 19:32   #1520 (permalink)
Member: 306410
Thanks Meter: 58
Selected model: M620
Phone must be OFF with battery
Please, connect phone and press shortly power button
Syncing phone... OK
Sending loader 1... OK
Syncing phone... OK
Sending loader 2... OK
Syncing phone... OK
Syncing phone... OK
Flash ID: 0100003D7E22
Syncing phone... OK
Format FFS - wait...
Format FFS - ok
Elapsed time: 257 second, sw ver: 3.4.0066
3 day rep with ust no work
Old 09-11-2010, 19:33   #1521 (permalink)
Member: 306410
Thanks Meter: 58
Reading file... OK
Model: S8500
Version: S8500XEJH2
Info: Patched for Unlock and IMEI repair v2
Searching Samsung USB Flash interface... detected (COM6)
Sending amss... sended
Sending apss... sended
Sending rsrc1... sended
Sending rsrc2... sended
Sending ffs... sended
Sending csc... sended
Sending app... sended
Sending pfs... sended
Flashing done (time - 00:16:04)
Searching Samsung USB interface... not found
Searching Samsung USB interface... detected (COM7)
Model: GT-S8500
SW: S8500XEJH2
IMEI: 35922303369344/6
MSL Adr: R2YZ642005
CountryCode: FTM
Factory SW: S8500BVJE7_FTMJE7_1
UniqueNumber: 74320001435999
MemoryPhone: KAC007021M(S8500)
Bypass MSL... OK
Reading codes... OK
Calculating codes... OK (time - 00:00:10)
Freeze code: 03969503
NET lock: #7465625*638*16308068#
SIM lock: #7465625*746*00000000#
not supported with ust-dead
Old 09-12-2010, 23:05   #1522 (permalink)
unlockmachine44's Avatar
Member: 1350724
Thanks Meter: 188
s3650 unlock done by z3x
Selected model: S3650
Selected com port: COM7
Phone must be ON
Search modem ... OK
Search modem on:COM8
Phone IMEI: 35xxxxxxxxx
Phone S/N: RDOZ704680
Detecting UART port..... OK
Repower phone - please wait
Reconnect cable on phone for init modem
Search modem ... OK
Search modem on:COM10
Net locks - cleared
Reset phone code to - > 00000000
Reset sim block code to - > 00000000
Elapsed time: 49 second, sw ver: 3.4.0066
Old 09-13-2010, 10:28   #1523 (permalink)
Crazy Poster
Member: 420744
Thanks Meter: 5
Hello there can you please help me with this problem.
Am working on the sumsung but it has the following serial number what is the solution to repair it the orignal is 3576763036093645, but just check out what it is showing me below
Selected model: S5230
Selected com port: COM8
Phone must be ON
Search modem ... OK
Search modem on:COM9
Model: GT-S5230
CountryCode: ORA
Factory SW: S5230BUIF1
UniqueNumber: 55030000402055
MemoryPhone: K522H1HACA(S5230)
Phone IMEI: 12345678912345 /8
Phone S/N: RPGS950760
Phone Bluetooth ID: 60 D0 A9 45 A6 3C
Phone SW: S5230BVIJ1_IJ2
Phone HW: MP 0.610
Phone CalData ver: 20090909
Calculating security.... OK
Please wait decrypt code ... OK
[FREZEE]:12345678
[NET LOCK]:25819474
[Subset LOCK]:00000000
[SP LOCK]:00000000
[CP LOCK]:00000000
Decrypted time: 58 sec
Elapsed time: 175 second, sw ver: 3.4.0033
Phone must be ON
Search modem ... OK
Phone OLD S/N: RPGS950760
Phone OLD IMEI: 12345678912345 /8
Set SWAP as OLD msl... False
Set SWAP as NEW msl... False
Wait for boot ...
Search modem ... OK
Phone NEW IMEI: 12345678912345 /8
Phone NEW S/N: RPGS950760
Repair - sec zone ok
Old 09-13-2010, 16:48   #1524 (permalink)
champions1's Avatar
Member: 1157490
Sonork: 100.1638346
Thanks Meter: 74
Samsung Galaxy 19000 successfully unlocked.
Searching Android modem... detected (COM114)
Model: GT-I9000
SW: I9000BOJF1
IMEI: 351751049xxx82/6
CountryCode: ¿µ±¹
Factory SW: I9000BOJG3
UniqueNumber: 75910000166209
MemoryPhone: KB100D00WM(I9000)
Reading Data from phone... OK
MCK: 19308304
NET lock: 39471424
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
after this procedure put wrong sim and put net lock code.Tested work 100%,no need flashing firmware.BR
Old 09-13-2010, 17:31   #1525 (permalink)
lloydgsm's Avatar
Member: 1230787
Thanks Meter: 96
successfully flashed C5212 with z3x
Selected model: C5212_m
Selected com port: COM64
Phone Detected
ARM version 3B11
Flash ID: 00EC2206000100000034
Start NOR flash
NOR flash - ok
Start Flash TFS
Mount TFS - ok
Create DIR - ok
Download - ok
Elapsed time: 1206 second, sw ver: 3.4.0066
Old 09-13-2010, 18:05   #1526 (permalink)
fokal2008's Avatar
Member: 953931
Sonork: 1652252
Thanks Meter: 897
samsung E1080 UNLOCK DONE!!!
Selected model: E1080
Selected com port: COM146
Phone Detected
Flash ID: 06
Unlock block
Unlock block
Unlock block
Unlock block
Unlock block
Unlock block
Unlock - ok
If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000#
Elapsed time: 60 second, sw ver: 3.4.0066
Phone Detected
Flash ID: 06
Unlock - ok
Elapsed time: 56 second, sw ver: 3.4.0066
Phone Detected
Flash ID: 06
Unlock block
Unlock block
Unlock block
Unlock block
Unlock block
Unlock block
Unlock - ok
Old 09-13-2010, 18:15   #1527 (permalink)
danrachita's Avatar
Member: 428861
Sonork: 100.1619141
Thanks Meter: 1,629
C3510
C3510 succesfully unlocked.
Thank you Z3X Team.
BR.
Selected model: C3510
Selected com port: COM88
Phone Detected
ARM version 3B11
Unlock - ok
Elapsed time: 160 second, sw ver: 3.4.0066
Old 09-13-2010, 18:16   #1528 (permalink)
danrachita's Avatar
Member: 428861
Sonork: 100.1619141
Thanks Meter: 1,629
C270
C270 succesfully unlocked.
Thank you Z3X Team.
BR.
Selected model: C270
Phone Detected
Use automatic parameters
Phone in TAT MODE
Phone IMEI: 351666049xxxxxx
Phone SW: C270CWID1
Phone BT ADDR: 0000-00-000000
Phone SN: RU9Z627220
Deactivated MSL - TRUE
All Code change to -> 00000000
Unlock - ok
Elapsed time: 20 second, sw ver: 3.4.0066
Old 09-14-2010, 01:26   #1529 (permalink)
Momo_Gsm's Avatar
Member: 755709
Sonork: 100.1592000 Momo...
Thanks Meter: 6,635
i900 unlocked:
Model: SGH-I900
CountryCode: XEU
Factory SW: I900XXHG5
UniqueNumber: 74060000691272
MemoryPhone: K5D1258DCA(I900)
PDA/CSC version: i900XXHG5/MSHG1
Phone version: i900XXHG5
Phone HW: MP 0.601
IMEI: c3528190218964/
Phone S/N: R4YQ964057
Build: M6281A-KLRZ-4.0.95601S
Reading Security... OK
Bypass MSL... OK
Unlocking ... OK
Old 09-14-2010, 04:58   #1530 (permalink)
Cheater -Don't Deal with him-
Member: 488833
Thanks Meter: 52
S5620 tricky but done well
just need to read the procedure and get multiloader 5.62
Selected model: S5620
Phone must be ON
Search modem ... OK
Search modem on:COM36
Phone OLD IMEI: 35858003313790 /1
Phone SW: S5620BVJJD1/S5620ZTOJD1
Search modem ... OK
Phone detected... OK
Send loader... OK
Wait for boot ...
Search modem ... OK
Net locks - cleared
Search modem ... OK
Send loader... OK
Elapsed time: 94 second, sw ver: 3.4.0066
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1841 07-06-2022 14:14
Post here successfully unlock or IMEI repair Infinity Box R@ZIB-BD Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG R@ZIB-BD Z3X-Team Products 2 02-01-2011 17:29
Page generated in 0.41944 seconds with 11 queries
