Old 02-11-2016, 10:35   #15586 (permalink)
vodafoneserver's Avatar
Member: 617174
Sonork: 100.1622609
Thanks Meter: 579
G925F 5.1.1 Red code done
UNLOCK INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
To reset Google account activation or Samsung reactivation lock:
1. Power on phone in download mode (turn off phone, press vol.down + home + power).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Read Codes
Selected model: SM-G925F
Software version: 24.2
Checking hash file... OK
Waiting ADB device... OK
Reading phone info...
Model: SM-G925F
Android version: 5.1.1
Product code: SM-G925FZDEVOD
Phone version: G925FXXU3QOKN
PDA version: G925FXXU3QOKN
CSC version: G925FVFG3QOKN
CSC country code: UK
CSC sales code: VOD
HW version: MP 0.70V
Phone S/N: R58G71KRNZK
Modem board: SHANNON333
RF cal date: 20150727
IMEI:
Checking Super user right... true
Initialization AT RIL... OK
Check version... OK
Initializating zTool... OK
Running zTool, please wait... OK
Reading nv data... OK
Checking NV data... OK
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:05)
Freeze code: 20617380
NET lock: 84131808
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Done with Samsung Tool PRO v.24.2
Old 02-11-2016, 12:04   #15587 (permalink)
maanarman's Avatar
Member: 686395
Sonork: 100.1608345
Thanks Meter: 3,819
Samsung l600 unlock
    Direct Unlock:
  2. Type ##3424# and select 'DM + MDM + ADB'.
  3. Select 'Qualcomm USB Settings' and choose 'DM/DUN over HSIC'.
  4. Connect phone to PC with USB cable, install drivers if needed.
  5. Choose diagnostic port in port settings.
  6. Press 'Unlock' button.
    Domestic Unlock:
  2. Enable 'USB debugging' in 'Settings'-'Developer options',
     tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options'.
  5. Press 'Unlock Domestic' button.
Operation: Unlock SPRNT
Selected model: SPH-L600
Selected port:
Software version: 24.0
Model: SPH-L600
Android version: 4.4.2
Product code: Not Active
Phone version: L600VPUBOH1
PDA version: L600VPUBOH1
CSC version: L600SPTBOH1
CSC country code: USA
CSC sales code: SPR
HW version: L600.04
Phone S/N: 00000000000
Modem board: MSM8930AB
RF cal date: 2014.04.16
IMEI: 990004486659653
Unlocking... OK
Rebooting phone... OK
Unlock done
Done with Samsung Tool PRO v.24.0
Old 02-11-2016, 17:21   #15588 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,169
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on phone in download mode (turn off phone, press vol.down + home + power).
5. Connect phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Flash
Selected model: GT-I9023
File analysis... OK
Total file size: 0x0CF1DF90 (207 Mb)
Searching USB Flash Interface... detected COM92
Setup connection... OK
Reading PIT from phone... OK
Sending bootloader.img... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending system.img... OK
Sending userdata.img... OK
Flashing done (time - 00:01:16)
Old 02-11-2016, 18:08   #15589 (permalink)
razib143's Avatar
Member: 348877
Sonork: 1601289
Thanks Meter: 1,169
Selected model: T399
Selected port: COM93 SAMSUNG Mobile USB Serial Port
Selected port speed: 115200
Model: SGH-T399N
Product code: Unknown
Phone version: T399NUVUANH1
PDA version: T399NUVUANH1
CSC version: T399NTMBANH1
IMEI: 350695200123951
Phone S/N: RV8F90DH0RY
Reading modem... OK
Patching modem... OK
Writing modem... OK
Repair done
Old 02-12-2016, 05:16   #15590 (permalink)
Member: 2444830
Thanks Meter: 151
Operation: Write CERT
Selected model: SM-G900V
Selected port: COM25 USB Serial Port
Checking certificate file... OK
KEY ID: 0478
Model: SM-G900V
Android version: 5.0
Phone version: G900VVRU2BOK3
PDA version: G900VVRU2BOK3
CSC version: G900VVZW2BOK3
CSC sales code: VZW
HW version: G900V.05
Modem board: MSM8974PRO
RF cal date: 2014.07.30
IMEI:
Bypass SPC... OK
Checking for compatible phone and cert... OK
Phone KEY ID: 0478
Writing CERT... OK
Checking CERT status... OK
Old 02-12-2016, 05:50   #15591 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,457
LG 2-3G Tool v8.9
supported models: 1116
Check Android Lollipop...
Stage #1 OK
Mode: Normal
Model: WX_PROJE
Build version: Aug 17 201521:00:30Feb 12 201405:00:00WX_PROJE
SW Version: M8610B-AAAANAZM-1.0.6038
IMEI: 01403800568448-9
BlueTooth Address: 00:00:00:00:00:00
Phone Code: default
SPC: 000000
Elapsed: 0 secs. --> (v8.9)
Stage #1 OK
Mode: Normal
Model: WX_PROJE
BlueTooth Address: 00:00:00:00:00:06
Phone Code: default
SPC: 000000
Direct unlock
Working with security zone
Checking phone at COM23
Reboot phone
Phone detected!
Repair IMEI...
Search LG Modem port...
Detected LG Modem port at COM4
Reboot phone
Done
Elapsed: 49 secs. --> (v8.9)
The Following User Says Thank You to ghacks For This Useful Post:
Old 02-12-2016, 07:54   #15592 (permalink)
Member: 2419703
imei repair N928T
Selected model: SM-G928T
Model: SM-G928T
Product code: SM2G928TZDATMB
Phone version: G928TUVS2COKC
PDA version: G928TUVS2COKC
CSC version: G928TTMB2COKC
CSC sales code: TMB
HW version: REV1.0
RF cal date: 20151125
IMEI:
KEY ID: 0784
Check version... OK
Calculating... OK
Writing nv data... OK
Write CERT done
Old 02-12-2016, 10:39   #15593 (permalink)
Member: 2240742
Thanks Meter: 76
Operation: Unlock
Selected model: GT-I8190N
Model: GT-I8190N
Android version: 4.1.2
Product code: GT-I8190RWNBTU
Phone version: I8190NXXAMJ2
PDA version: I8190NXXAMJ2
CSC version: I8190NBTUAMJ1
CSC country code: UK & IRE
CSC sales code: BTU
HW version: MP 0.700
Phone S/N: RF1D9803xxx
Modem board: DB8520H
RF cal date: 2013.10.02
IMEI: 3560360547xxxxx
Reading data from phone... OK
Analysing SEC file... OK
Bypass MSL... OK
Unlocking... OK
Unlock done
Thanx z3x
Old 02-12-2016, 10:47   #15594 (permalink)
canliyayin's Avatar
Member: 311558
Thanks Meter: 431
b350e no network done
Operation: Patch Certificate
Selected model: SM-B350E
Selected port:
Waiting phone... detected COM18
Sending FDL... OK
Reconnecting phone... OK
Sending FDL2... OK
Reading data from phone ... OK
Writing data to phone... OK
Patching CERT check... done
Old 02-12-2016, 10:55   #15595 (permalink)
Member: 2240742
Thanks Meter: 76
Operation: Unlock
Selected model: SM-J100H
Model: SM-J100H
Android version: 4.4.4
Product code: SM-J100HZKATSC
Phone version: J100HXCU0AOG1
PDA version: J100HXCU0AOG1
CSC version: J100HOXX0AOG1
CSC sales code: TSC
HW version: MP 0.201
Phone S/N: R51G71Zxxxx
Modem board: sc7727s
RF cal date: 20150717
IMEI: 3528300734xxxxx
Unlocking... OK
Unlock done
Old 02-12-2016, 13:43   #15596 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 10,058
GT-I9300 IMEI Repair Done By Write CERT
KEY ID: 0455
Model: GT-I9300
Android version: 4.3
Product code: GT-I9300RWDNZC
Phone version: I9300XXUGNB1
PDA version: I9300XXUGOA2
CSC version: I9300NZCGOA1
CSC country code: New Zealand
CSC sales code: NZC
HW version: MP 1.400
Phone S/N: RV1D10P8V3D
Modem board:
RF cal date: 2013.1.8
IMEI: 357868678575472
Checking magic... OK
Detected new type of security version 0
Calculating... OK
Write CERT done
__________________
Use Search Button to get Instant Result | Follow Forum Rules
Avoid Spams in the forum to prevent ban your account.
Old 02-12-2016, 13:44   #15597 (permalink)
Moderator
Member: 1162626
GT-I9500 IMEI Repair By Write CERT
KEY ID: 0833
Please, allow USB debugging on phone... OK
Model: GT-I9500
Phone version: I9500XXUEMJ8
PDA version: I9500XXUEMJ8
CSC version: I9500OJVEMJ8
CSC country code: SOUTH AFRICA
CSC sales code: XFA
HW version: REV__
Phone S/N: RF1D455LD9H
Modem board: XMM6360
RF cal date: Unknown
IMEI: 004999010640000
Calculating... OK
Write CERT done
__________________
Old 02-12-2016, 16:15   #15598 (permalink)
Member: 2240742
Thanks Meter: 76
Operation: Unlock
Model: GT-I8190N
Product code: GT-I8190RWNSFR
Phone version: I8190NXXAMG3
PDA version: I8190NXXAMG3
CSC version: I8190NVFGAMF3
CSC country code: France
CSC sales code: SFR
Phone S/N: RF1D4519xxx
RF cal date: 2013.04.21
IMEI: 356036050xxxxxxx
Bypass MSL... OK
Unlocking... OK
Unlock done
Old 02-12-2016, 17:22   #15599 (permalink)
Gambitv01's Avatar
Member: 1475064
Thanks Meter: 345
Selected model: SM-N915A
Selected port: COM14 SAMSUNG Mobile USB Serial Port
KEY ID: 0208
Model: SAMSUNG-SM-N915A
Product code: SM2N915AZKEATT
Phone version: N915AUCU2COI2
PDA version: N915AUCU2COI2
CSC version: N915AATT2COI2
CSC sales code: ATT
HW version: REV0.1
Phone S/N:
Modem board: MDM9225M
RF cal date: 2015.08.18
IMEI:
Bypass MSL... OK
Phone KEY ID: 0208
Writing CERT... OK
Operation: Unlock
Reading IMEI... OK
IMEI: XXXXXXXXXXXXXXXXX
Unlocking... OK
Reseting... OK
Unlock done
The Following User Says Thank You to Gambitv01 For This Useful Post:
Old 02-13-2016, 02:25   #15600 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,457
2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or
tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+.
5. Press 'Unlock' button for direct unlock.
Operation: Unlock
Selected model: SGH-T399N
Model: SGH-T399N
Product code: SGH2T399RNATMB
Phone version: T399NUVUANK3
PDA version: T399NUVUANK3
CSC version: T399NTMBANK3
CSC sales code: TMB
HW version: REV1.0
Phone S/N: RV8G11993LJ
Modem board: SS222
RF cal date: 20150127
IMEI: 358765060187370
Calculating... OK
Unlocking... OK
Unlock done
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1802 12-23-2019 14:44
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 17:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 17:29
Page generated in 0.51583 seconds with 9 queries
