02-26-2016, 13:34 | #15691 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Punjabi University India
Member: 788946 Status: Offline Sonork: 100.1682685 Thanks Meter: 502 | Operation: Unlock Selected model: SM-N910W8 Selected port: COM362 SAMSUNG Mobile USB Serial Port Software version: 24.4 Reading phone info... Reading IMEI... OK IMEI: 35459506xxxxxxx Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.4 Thanks z3x Team |
The Following User Says Thank You to sr8787 For This Useful Post: |
02-26-2016, 16:22 | #15695 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Dhaka Bangladesh Age: 33
Member: 348877 Status: Offline Sonork: 1601289 Thanks Meter: 1,178 | Samsung Galaxy Light Unlock done... Selected model: T399 Selected port: COM25 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SGH-T399N Android version: 4.4.2 Product code: Unknown Phone version: T399NUVUANH1 PDA version: T399NUVUANH1 CSC version: T399NTMBANH1 IMEI: 350695200123951 Phone S/N: RV8F90F432B Checking Super user right... true Reading modem... OK Patching modem... OK Writing modem... OK Rebooting phone... OK Done with Samsung Tool v.19.1 |
02-26-2016, 21:17 | #15696 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | UNLOCK DONE SM-G530AZ UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Unlock' button for direct unlock. Operation: Unlock Selected model: SM-G530AZ Selected port: COM151 SAMSUNG Mobile USB Serial Port Software version: 24.3 Reading phone info... Reading IMEI... OK IMEI: 357549066792305 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.3 |
02-26-2016, 22:22 | #15697 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1123307 Status: Offline Thanks Meter: 0 | UNLOCK INSTRUCTIONS: UART cable: 1. Phone must be powered on. 2. Connect the phone to UART cable. 3. Choose correct COM port in port settings. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. USB cable: 1. Phone must be powered on. 2. Type *#7284# and choose phone USB. 3. Type *#197328640#, select: Common - Diag Config - USB diag. 4. Reboot phone. 5. Connect USB cable, install drivers if needed. 6. Select diagnostic port in port settings. 7. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Unlock Selected model: GT-I8260 Selected port: COM34 SAMSUNG Mobile USB Serial Port Software version: 24.4 Reading phone info... OK Model: GT-I8260 Country code: ªU Cal date: ªU Factory SW: I8260XXAML3 Unique number: CL708F9DB8AB5B0 Memory phone: ªU Phone S/N: RF1DB69S1D PDA/CSC version: I8260XXAML3/I8260XECANA1 Phone version: SW VERSION :None Phone HW: MP 0.801 Cal date: 2013.11.22 Reading IMEI... OK IMEI: 3598260522XXXX Bypass MSL... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.24.4 |
02-27-2016, 17:33 | #15703 (permalink) |
No Life Poster Join Date: Jun 2014 Location: GSM FORUM ♥
Member: 2207555 Status: Offline Thanks Meter: 1,622 | UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-J200G Software version: 24.4 Searching Samsung USB Flash Interface... detected COM9 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.24.4 |
The Following User Says Thank You to rehansk8879 For This Useful Post: |
02-27-2016, 22:30 | #15704 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Romania
Member: 1475064 Status: Offline Thanks Meter: 347 | Operation: Unlock Selected model: SM-G928A Software version: 24.4 Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G928A Android version: 5.1.1 Product code: SM4G928AZDEATT Phone version: G928AUCU1AOGG PDA version: G928AUCU1AOGG CSC version: G928AATT1AOGG CSC country code: USA CSC sales code: ATT HW version: REV0.1 Phone S/N: R38G80PVTCF Modem board: SHANNON333 RF cal date: 20150821 IMEI: Checking Super user right... true Initialization AT RIL... OK Check version... OK Initializating zTool... OK Running zTool, please wait... OK Reading nv data... OK Checking NV data... OK Calculating... OK Writing nv data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.24.4 |
02-28-2016, 08:37 | #15705 (permalink) |
Member: 2207555 Status: Offline Thanks Meter: 1,622 | J700f frp reset done UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-J700F/DS Software version: 24.4 Searching Samsung USB Flash Interface... detected COM52 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.24.4 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
