Old 07-09-2016, 07:13   #16441 (permalink)
abdulhaq_majroh's Avatar
Member: 1600947
Sonork: 100.1627298
Thanks Meter: 771
UNLOCK INSTRUCTIONS:
1. Power on the phone.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and select 'DM/DUN over HSIC'.
Or use 'Activate Diag' function from 'Repair' tab.
4. Connect phone to PC with USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Unlock' button for direct unlock.
To reset Google account activation or Samsung reactivation lock:
1. Power on phone in download mode (turn off phone, press vol.down + home + power).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)
Operation: Unlock
Selected model: SM-J500FN
Selected port: COM54 SAMSUNG Mobile USB Serial Port
Software version: 25.5
Reading phone info...
Reading IMEI... OK
IMEI: 358990075644021
Unlocking... OK
Reseting... OK
Unlock done
Done with Samsung Tool PRO v.25.5
Old 07-09-2016, 08:59   #16442 (permalink)
Member: 2478777
Sonork: 1669951
Thanks Meter: 101
gt-s5610k unlock done
Operation: Unlock
Selected model: GT-S5610K
Selected port: COM6 Z3X BOX Serial Port
Software version: 25.9
Connect phone and press power button
Phone detected
Switch phone in TAT mode... OK
Reading phone info... OK
Phone version: S5610KJVLK1
CSC version: S5610KOJVLK1
IMEI: 35************
Phone SN: RZ1D505FWS
Phone BT: 00:6B:CA:E8:56:91
Bypass MSL... OK
Unlocking... OK
Rebooting phone... OK
Unlock done
Codes set to default value
Done with Samsung Tool PRO v.25.9
Old 07-09-2016, 10:06   #16443 (permalink)
Member: 2478777
Sonork: 1669951
Thanks Meter: 101
sgh-c140 imei repair done
Selected model: C140
Selected com port: COM6
Selected speed port: 460800
Phone must be ON!
Please, connect phone
Entering TestMode... OK
Start repair IMEI......
SW: C140JVGB2
IMEI: 35817300533645
MSL DEACTIVATED - TRUE
Imei store to RAM
Imei store to flash
Repair IMEI - ok
Elapsed time: 10 second, sw ver: 3.5.0040
Old 07-09-2016, 14:59   #16444 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,455
Samsung J500h FRP Reset
Operation: Reset FRP/React/EE
Selected model: SM-J500H
Selected port:
Searching Samsung USB Flash Interface... detected COM131
Setup connection... OK
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP... OK
Searching Reactivation lock... not supported
Searching EE lock... OK
Erasing EE lock... OK
Reset done
Old 07-09-2016, 15:25   #16445 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,455
Samsung G530h Cert Write
Operation: Write CERT
Selected model: SM-G530H
Selected port: COM1 Communications Port
Checking certificate file... OK
KEY ID: 0504
Waiting ADB device... OK
Model: SM-G530H
Android version: 4.4.4
Product code: SM-G800HZKAXSG
Phone version: G530HXXU1ANIJ
PDA version: G530HXXU1ANIJ
CSC version: G530HOJV1ANJ1
CSC country code: UAE
CSC sales code: XSG
HW version: MP 0.600
Phone S/N: R31F501H9NP
Modem board: MSM8216
RF cal date: 2014.11.20
IMEI: 353697060119399
Initialization AT RIL... OK
Bypass MSL... OK
Checking for compatible phone and cert... OK
Phone KEY ID: 0504
Writing CERT... OK
Checking CERT status... OK
Writing Slave CERT... OK
Checking Slave CERT status... OK
Old 07-09-2016, 17:40   #16446 (permalink)
Member: 2478777
Sonork: 1669951
Thanks Meter: 101
Selected model: SM-G361H
Searching Samsung USB Flash Interface... detected COM98
Erasing FRP... OK
Reset done
Old 07-10-2016, 07:29   #16447 (permalink)
Muhammadsaqib11's Avatar
Member: 1602407
Sonork: 100.1648061
Thanks Meter: 347
SM-J110H/DS hang and restart problem solved by flashing
Infected by Viruses
Br,
GSM City
Old 07-10-2016, 09:07   #16448 (permalink)
Member: 1678953
Thanks Meter: 58
Repair DRK S6 Edge SM-G925F
Operation: Repair DRK
Selected model: SM-G925F
Checking local file... OK
Searching server... OK
Compare local and server file... OK (up to date)
Searching USB Flash Interface... detected COM11
Reading data from phone... OK
Sending data to phone... OK
Android version: 6.0.1
Boot version: G925FXXS3DPD5
Platform: exynos7420
Boot serial: 0715f7c28a3c0436
Product board: zerolte
Initializating zTool... OK
Running zTool, please wait...
Start... OK
Init... OK
Generate and check client proof... OK
Verify proof by client... OK
Checking DRK status... NG!
Writing DRK... OK
Repairing DMVT key... OK
Repair DRK done
Old 07-10-2016, 09:10   #16449 (permalink)
Member: 2594681
thanks.............perfect,,,,,,,,,,,,,,,,
Old 07-10-2016, 10:31   #16450 (permalink)
KhOliO's Avatar
Member: 21732
Sonork: 100.75816
Thanks Meter: 218
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
Operation: Read Codes
Selected model: SM-G935FD
Checking hash file... OK
Model: SM-G935F
Product code: SM-G935FZDUSER
Phone version: G935FXXU1APD9
PDA version: G935FXXU1APDH
CSC version: G935FOXE1APD1
CSC country code: Russia
CSC sales code: SER
HW version: MP 0.801
Phone S/N: RF8H526HTJP
Modem board: SHANNON335
RF cal date: 20160523
IMEI:
Checking Super user right... true
Start... OK
Init... OK
Reading data... OK
HWID: E9 4E 3D 69 5B 3A FF 23 B5 40 99 36 57 6F 7D A0
Reading nv data... OK
Checking NV data... OK
Calculating... OK
Please wait, calculating codes... OK (time - 00:00:05)
Freeze code: 75930704
NET lock: 28642930
Sub lock: 00000000
SP lock: 00000000
CP lock: 00000000
SIM lock: 00000000
For check lock status: *#7465625#
Old 07-10-2016, 14:51   #16451 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,455
Samsung Sm-G531h FRP
Selected model: SM-G531H
Erasing FRP... OK
Reset done
Old 07-11-2016, 14:20   #16452 (permalink)
Member: 2478777
Sonork: 1669951
Thanks Meter: 101
Special Thanks Z3X Team
Selected model: C3310
Selected speed port: 921600
Attention !!! Use this operation after flashing phone
Search diag port... OK (COM129)
Phone SN: RV1C756ZH3
Deactivate MSL - OK
Unlock - ok
Elapsed time: 21 second, sw ver: 3.5.0040
Old 07-12-2016, 13:43   #16453 (permalink)
tapas770's Avatar
Member: 2171294
Sonork: 100.1659207
Thanks Meter: 678
Talking G531H Unlock done without Root
Old 07-12-2016, 15:44   #16454 (permalink)
Member: 2478777
Sonork: 1669951
Thanks Meter: 101
SM-J320FN imei repair
[ 12.07.2016 17:07:00 ] Operation: Repair
[ 12.07.2016 17:07:00 ] Selected model: SM-J320FN
[ 12.07.2016 17:07:00 ] Software version: 25.9
[ 12.07.2016 17:07:00 ] Waiting ADB device...
[ 12.07.2016 17:07:00 ] Please, allow USB debugging on phone... OK
[ 12.07.2016 17:07:00 ] Reading phone info...
[ 12.07.2016 17:07:00 ] Model: SM-J320FN
[ 12.07.2016 17:07:00 ] Android version: 5.1.1
[ 12.07.2016 17:07:00 ] Product code: SM-J320FZWNPHN
[ 12.07.2016 17:07:00 ] Phone version: J320FNXXU0APB5
[ 12.07.2016 17:07:00 ] PDA version: J320FNXXU0APB4
[ 12.07.2016 17:07:00 ] CSC version: J320FNPHN0APB2
[ 12.07.2016 17:07:00 ] CSC country code: The Netherlands
[ 12.07.2016 17:07:00 ] CSC sales code: PHN
[ 12.07.2016 17:07:00 ] HW version: MP 0.400
[ 12.07.2016 17:07:00 ] Phone S/N: R58H31MY0HF
[ 12.07.2016 17:07:00 ] Modem board: SC9830i
[ 12.07.2016 17:07:00 ] RF cal date: 2016.03.11
[ 12.07.2016 17:07:00 ] IMEI:
[ 12.07.2016 17:07:00 ] Checking Super user right... true
[ 12.07.2016 17:07:00 ] Reading data from phone... OK
[ 12.07.2016 17:07:00 ] Repairing IMEI... OK
[ 12.07.2016 17:07:00 ] Writing data to phone... OK
[ 12.07.2016 17:07:00 ] Rebooting phone... OK
[ 12.07.2016 17:07:00 ] Repair done
Old 07-12-2016, 15:46   #16455 (permalink)
Member: 2478777
Sonork: 1669951
Thanks Meter: 101
SM-J320FN Unlock
[ 12.07.2016 17:31:00 ] Operation: Unlock
[ 12.07.2016 17:31:00 ] Selected model: SM-J320FN
[ 12.07.2016 17:31:00 ] Software version: 25.9
[ 12.07.2016 17:31:00 ] Searching Samsung modem... detected COM136
[ 12.07.2016 17:31:00 ] Reading phone info... OK
[ 12.07.2016 17:32:00 ] Model: SM-J320FN
[ 12.07.2016 17:32:00 ] Version: J320FNXXU0APB4/J320FNPHN0APB2/J320FNXXU0APB5/J320FNXXU0APB4
[ 12.07.2016 17:32:00 ] Product code: SM-J320FZDNPHN
[ 12.07.2016 17:32:00 ] Phone S/N: R58H31LNCJW
[ 12.07.2016 17:32:00 ] Imei: 448************
[ 12.07.2016 17:32:00 ] Unique number: CQN00E6D44FBB13
[ 12.07.2016 17:32:00 ] Unlocking... OK
[ 12.07.2016 17:32:00 ] Rebooting phone... OK
[ 12.07.2016 17:32:00 ] Unlock done
Post here successfully unlock or IMEI repair LG andrew_tm Z3X-Team Products 1809 05-29-2020 09:26
Post here successfully unlock or IMEI repair Infinity Box [email protected] Infinity-Box 3 07-04-2014 16:37
Post here successfully unlock or IMEI repair LG [email protected] Z3X-Team Products 2 02-01-2011 16:29
Page generated in 0.58323 seconds with 9 queries
