07-30-2016, 10:21 | #16561 (permalink) |
Freak Poster Join Date: Jan 2008 Location: philippines
Member: 669596 Status: Offline Sonork: 1657504 Thanks Meter: 136 | Code: Selected model: N5100 Selected port: COM9 Z3X BOX Serial Port Selected port speed: 115200 Waiting ADB device... OK Reading phone info... Model: GT-N5100 Android version: 4.4.2 Product code: Not Active Phone version: N5100DXDNG1 PDA version: N5100XXDNJ2 CSC version: N5100OLBDNJ2 IMEI: 004999010640000 Phone S/N: RF2F109920R Checking Super user right... true Reading nv data... OK Reading modem... OK Patching modem... OK Writing modem... OK Reading kernel... OK Checking magic... OK Running zTool, please wait... OK Writing nv data... OK Rebooting phone... OK Repair done Done with Samsung Tool v.19.1 Done with Samsung Tool v.19.1 |
07-31-2016, 09:24 | #16563 (permalink) |
Freak Poster Join Date: Oct 2011 Location: Annaba, ALGERIA
Member: 1678953 Status: Offline Thanks Meter: 67 | S6 edge g925f unlock S6 edge G925f Unlock done in 3 sec without root Code: Searching Samsung modem... detected COM14 Reading phone info... OK Model: SM-G925F AP Version: G925FXXS3DPF1 CSC Version: G925FOXX3DPD1 CP Version: G925FXXU3DPDP Product code: SM-G925FZDAXEF Phone S/N: RF8H62X3YGL Imei: 3564200******** Unique number: 051603007194C422 Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.2 |
07-31-2016, 09:26 | #16564 (permalink) |
Member: 1678953 Status: Offline Thanks Meter: 67 | S6 edge G925f read EFS Code: Operation: Read EFS Selected model: SM-G925F Software version: 26.2 Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 6.0.1 Product code: SM-G925FZDAXEF Phone version: G925FXXU3DPDP PDA version: G925FXXS3DPF1 CSC version: G925FOXX3DPD1 CSC country code: France CSC sales code: XEF HW version: MP 0.710 Phone S/N: RF8H62X3YGL Modem board: SHANNON333 RF cal date: 20160628 IMEI: Checking Super user right... true Reading EFS from phone... OK Saved to C:\Program Files (x86)\Z3X\Samsung\SamsungToolPRO\backup\EFS\EFS_SM-G925F_G925FXXS3DPF1__RF8H62X3YGL_31-7-2016_9-18-15.tar Done with Samsung Tool PRO v.26.2 |
07-31-2016, 09:44 | #16565 (permalink) |
Member: 1678953 Status: Offline Thanks Meter: 67 | S6 edge g925g read cert it could not read cert, the modem must be downgraded Code: Operation: Read CERT Selected model: SM-G925F Software version: 26.2 Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 6.0.1 Product code: SM-G925FZDAXEF Phone version: G925FXXU3DPDP PDA version: G925FXXS3DPF1 CSC version: G925FOXX3DPD1 CSC country code: France CSC sales code: XEF HW version: MP 0.710 Phone S/N: RF8H62X3YGL Modem board: SHANNON333 RF cal date: 20160628 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... error (9) Done with Samsung Tool PRO v.26.2 Code: Operation: Flash Selected model: SM-G925F Software version: 26.2 File analysis... OK Total file size: 0xE16AAE00 (3606 Mb) Searching USB Flash Interface... detected COM27 Setup connection... OK Set PIT file... Error Done with Samsung Tool PRO v.26.2 Code: Operation: Reset FRP/React/EE Selected model: SM-G925F Software version: 26.2 Searching Samsung USB Flash Interface... detected COM27 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... error Done with Samsung Tool PRO v.26.2 Thanks |
07-31-2016, 10:36 | #16566 (permalink) |
Member: 1678953 Status: Offline Thanks Meter: 67 | when i use DRK repair to downgrade modem : Code: Operation: Repair DRK Selected model: SM-G925F Software version: 26.2 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM55 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... time out Phone not found Done with Samsung Tool PRO v.26.2 |
07-31-2016, 11:44 | #16567 (permalink) |
Member: 1678953 Status: Offline Thanks Meter: 67 | full flash with 4 files firmware Code: Operation: Flash Selected model: SM-G925F Software version: 26.2 File analysis... OK Total file size: 0x152E0920 (338 Mb) Searching USB Flash Interface... detected COM27 Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Sending modem.bin... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:06:07) Done with Samsung Tool PRO v.26.2 Code: Operation: Repair DRK Selected model: SM-G925F Software version: 26.2 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM27 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Sending data to phone... OK Waiting ADB device... time out Phone not found Done with Samsung Tool PRO v.26.2 |
08-01-2016, 05:17 | #16568 (permalink) |
Junior Member Join Date: Sep 2015
Member: 2457283 Status: Offline Sonork: paloma Thanks Meter: 2 | UNLOCK INSTRUCTIONS: READ CODES: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read codes' to read security codes. DIRECT UNLOCK: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button. Operation: Read Codes Selected model: SM-G890A Software version: 26.2 Checking hash file... OK Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-G890A Android version: 5.0.2 Product code: SM2G890AZAAATT Phone version: G890AUCU3AOK1 PDA version: FA50_G890AUCU3AOK2 CSC version: CSC country code: CSC sales code: HW version: REV0.5 Phone S/N: R38G90GCMYR Modem board: SHANNON333 RF cal date: 20150916 IMEI: Checking Super user right... true Initializating zTool... OK Running zTool, please wait... Start... OK Init... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 48 6C A8 B6 D4 05 00 00 00 00 00 00 00 00 00 00 Reading nv data... OK Checking NV data... OK Calculating... OK Please wait, calculating codes... OK (time - 00:00:21) Freeze code: 80703836 NET lock: 85030729 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.26.2 |
08-01-2016, 09:23 | #16570 (permalink) |
No Life Poster Join Date: Apr 2008 Location: gsmsolution Age: 34
Member: 755480 Status: Offline Sonork: 100.1609798 Thanks Meter: 233 | J200f no root direct unlock done Code: Searching Samsung modem... detected COM447 Reading phone info... OK Model: SM-J200F AP Version: J200FXXU1AOJ3 CSC Version: J200FOJV1AOJ4 CP Version: J200FXXU1AOJ2 Product code: SM-J200FZDDTHR Phone S/N: R58HXX Imei: 357091X Unique number: C8G011190986653 Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.2 |
08-01-2016, 10:17 | #16573 (permalink) |
Freak Poster Join Date: Oct 2015
Member: 2478777 Status: Offline Sonork: 1669951 Thanks Meter: 103 | GT-E1080F Imei Repair Selected model: E1080 Selected com port: COM3 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Please wait for patching firmware... Patch block Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master IMEI: 354************ Phone slave IMEI: 354************ Phone SW: E1080FJVJE1 Phone CSC: Phone BT ADDR: 0000-00-000000 Phone SN: RF1C357YZM Deactivated MSL - TRUE Write imei - ok Repair - ok Elapsed time: 40 second, sw ver: 3.5.0040 ------------------------------------------------------------------------------- |
08-01-2016, 11:35 | #16574 (permalink) |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Samsung J200G FRP reset when other tool fail Searching Samsung USB Flash Interface... detected COM35 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.26.2 |
08-02-2016, 01:10 | #16575 (permalink) |
Freak Poster Join Date: Apr 2016
Member: 2554552 Status: Offline Thanks Meter: 21 | Operation: Unlock SPRNT Selected model: SM-N920P Software version: 26.2 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-N920P Android version: 5.1.1 Product code: Not Active Phone version: N920PVPS2AOK3 PDA version: N920PVPS2AOK3 CSC version: N920PSPT2AOK3 CSC country code: USA CSC sales code: SPR HW version: N920P.04 Phone S/N: 00000000000 Modem board: MDM9635M RF cal date: 2015.11.18 IMEI: Initialization AT RIL... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.2 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
