08-06-2016, 13:51 | #16607 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | j120g Searching Samsung modem... detected COM45 Reading phone info... OK Model: SM-J120G AP Version: J120GDXU1APF2 CSC Version: J120GOLB1APF3 CP Version: J120GDXU1APF3 Product code: SM-J120GZDDXME Phone S/N: R58H7083AMD Imei: 357204071285677 Unique number: CFN00DE02A1BF53 Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done |
08-06-2016, 17:01 | #16608 (permalink) |
No Life Poster Join Date: Jul 2013 Location: in my company
Member: 1984825 Status: Offline Thanks Meter: 222 | unlock g920f without root Operation: Read Codes Selected model: SM-G920F Software version: 26.3 Searching Samsung modem... detected COM62 Reading phone info... OK Model: SM-G920F AP Version: G920FXXU2COH7 CSC Version: G920FFTM2COH8 CP Version: G920FXXU2COH2 Product code: SM-G920FZKAFTM Phone S/N: RF8GA0QETFY Imei: **************** Unique number: 0815F86B5E0E3605 Checking hash file... OK Reading data from phone... OK HWID: 48 F9 42 CF 8C 06 00 00 00 00 00 00 00 00 00 00 Modem board: SHANNON333 Please wait, calculating codes... OK (time - 00:00:14) Freeze code: 29317351 NET lock: 70524647 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.26.3 |
The Following User Says Thank You to tikourine For This Useful Post: |
08-06-2016, 17:37 | #16609 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button. Operation: Unlock Selected model: SM-J120AZ Software version: 26.3 Searching Samsung modem... detected COM346 Reading phone info... OK Model: SM-J120AZ AP Version: J120AZTUU1APC4 CSC Version: J120AZAIO1APC4 CP Version: J120AZTUU1APC4 Product code: SM2J120AZKZAIO Phone S/N: R58H34HSKFJ Imei: 356419070595618 Unique number: CFN00C785962123 Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.3 |
08-07-2016, 13:13 | #16615 (permalink) |
Junior Member Join Date: Dec 2007 Location: Bangladesh Age: 39
Member: 656861 Status: Offline Sonork: 123123 Thanks Meter: 15 | sm-p601 write cert problem BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-P601 Software version: 26.3 Checking certificate file... OK KEY ID: 0121 Waiting ADB device... OK Reading phone info... Model: SM-P601 Android version: 5.1.1 Product code: Phone version: PDA version: P601XXUDPD3 CSC version: P601OJVDPD1 CSC country code: UAE CSC sales code: XSG HW version: Phone S/N: RF2F11EPHFY Modem board: RF cal date: IMEI: Checking Super user right... true Reading nv data... OK Checking magic... OK Running zTool, please wait... error Done with Samsung Tool PRO v.26.3 |
08-07-2016, 13:20 | #16616 (permalink) |
Member: 656861 Status: Offline Sonork: 123123 Thanks Meter: 15 | sm-p601 write cert problem with z3x BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-P601 Software version: 26.3 Checking certificate file... OK KEY ID: 0121 Waiting ADB device... OK Reading phone info... Model: SM-P601 Android version: 5.1.1 Product code: Phone version: PDA version: P601XXUDPD3 CSC version: P601OJVDPD1 CSC country code: UAE CSC sales code: XSG HW version: Phone S/N: Modem board: RF cal date: IMEI: Checking Super user right... true Reading nv data... OK Checking magic... SSNV not found Done with Samsung Tool PRO v.26.3 |
08-07-2016, 14:30 | #16617 (permalink) | |
Freak Poster Join Date: Jan 2011 Location: Assam
Member: 1482831 Status: Offline Thanks Meter: 29 | Quote:
bro how to repair unknown baseband,imei null, | |
08-08-2016, 09:09 | #16618 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,999 | Samsung Edge Plus G928F Flashing Code: Operation: Flash Selected model: SM-G928F Software version: 26.3 File analysis... OK Total file size: 0x2008FC80 (512 Mb) Searching USB Flash Interface... detected COM9 Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending sboot.bin... OK Sending param.bin... OK Sending cm.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending userdata.img... OK Sending modem.bin... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:03:50) Done with Samsung Tool PRO v.26.3 |
08-08-2016, 11:57 | #16619 (permalink) |
Freak Poster Join Date: Oct 2015
Member: 2478777 Status: Offline Sonork: 1669951 Thanks Meter: 103 | SM-G361H/DS Imei Repair Operation: Repair Selected model: SM-G361H/DS Software version: 26.3 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G361H Android version: 5.1.1 Product code: SM-G361HZSDAFG Phone version: G361HXXU0AOJ1 PDA version: G361HXXU0AOJ1 CSC version: G361HOXE0AOJ1 CSC country code: Russia CSC sales code: SER HW version: MP 0.200 Phone S/N: R51G90W8R8K Modem board: SC7730SE RF cal date: 20150908 IMEI: Checking Super user right... true Checking MSL... OK Initialization AT RIL... OK Bypass MSL... OK Repairing IMEI... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.26.3 |
08-08-2016, 13:38 | #16620 (permalink) |
Member: 2478777 Status: Offline Sonork: 1669951 Thanks Meter: 103 | Sm-g920f unlock Operation: Unlock Selected model: SM-G920F Software version: 26.3 Searching Samsung modem... detected COM160 Reading phone info... OK Model: SM-G920F AP Version: G920FXXS3DPDA CSC Version: G920FDBT3DPC4 CP Version: G920FXXU3DPCA Product code: SM-G920FZKADBT Phone S/N: R********** Imei: 354************ Unique number: 0416044C16BC3902 Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.26.3 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
