10-01-2010, 12:00 | #1683 (permalink) |
No Life Poster Join Date: Oct 2005 Location: georgia tbilisi
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | Count supported models - 209 Searching Samsung USB interface... detected (COM30) Model: S8000 SW: S8000XEIG2 IMEI: 35704103920349/5 Done with Samsung 3G tool ver 8.4 Reading file... OK Model: S8000 Version: S8000XEIG2 Info: Patched for unlock Searching Samsung USB Flash interface... detected (COM30) Sending file 1 of 5... sended Sending file 2 of 5... sended Sending file 3 of 5... sended Sending file 4 of 5... sended Sending last file... sended Flashing done (time - 00:04:07) Done with Samsung 3G tool ver 8.4 ----------------------------- Searching Samsung USB interface... not found Done with Samsung 3G tool ver 8.4 ----------------------------- Searching Samsung USB interface... not found Done with Samsung 3G tool ver 8.4 ----------------------------- Searching Samsung USB interface... detected (COM30) Model: S8000 SW: S8000XEIG2 IMEI: 35704103920349/5 Reading codes... OK Calculating codes... OK (time - 00:00:54) Freeze code: 58202059 NET lock: #7465625*638*85395791# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# Multi lock: #7465625*685*00000000# SIM lock: #7465625*746*00000000# For check lock status: *#7465625# Done with Samsung 3G tool ver 8.4 |
The Following User Says Thank You to laduka For This Useful Post: |
10-01-2010, 12:54 | #1684 (permalink) |
No Life Poster Join Date: Jan 2007 Location: Romania
Member: 428861 Status: Offline Sonork: 100.1619141 Thanks Meter: 1,629 | E2121b E2121B succesfully unlocked. Thank you Z3X Team. BR. Selected model: E2121B Selected com port: COM29 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 51 second, sw ver: 3.4.0066 |
The Following User Says Thank You to danrachita For This Useful Post: |
10-01-2010, 18:13 | #1685 (permalink) |
Freak Poster Join Date: Dec 2009 Location: beside gsm world
Member: 1178779 Status: Offline Thanks Meter: 18 | s5620 unlock done..... ------------------------------------------------------------------------------- Selected model: S5620 Selected com port: COM24 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM56 Phone OLD IMEI: 35858003272572 /2 Phone SW: S5620JPJB4/S5620OJPJC1 Search modem ... OK Phone detected... OK Send loader... OK Wait for boot ... Reconnect cable on phone for init modem Search modem ... OK Search modem on:COM56 MSL DEACTIVATED - TRUE Net locks - cleared Reset phone code to - > 00000000 Reset sim block code to - > 00000000 Search modem ... OK Phone detected... OK Send loader... OK Elapsed time: 113 second, sw ver: 3.4.0062 ------------------------------------------------------------------------------- |
The Following User Says Thank You to jigs69 For This Useful Post: |
10-01-2010, 19:25 | #1686 (permalink) |
No Life Poster Join Date: Feb 2004
Member: 52597 Status: Offline Thanks Meter: 275 | Code: Selected model: I200 Selected com port: COM96 Selected speed port: 921600 Power On phone Press on phone keyboard code *#0228# Press Back and press 2 key Select UART-CP and connect phone on cable Phone detected [SOFTWARE]:I200XXIA1 [Unique number]:70530000267758 [IMEI]:35254602xxxxxxxxxx [Serial number]:R1XS227750 Start Bruteforce Msl code detected: 614739 Unlock - ok Elapsed time: 19678 second, sw ver: 3.4.0066 |
The Following User Says Thank You to silhouette For This Useful Post: |
10-01-2010, 23:48 | #1687 (permalink) |
No Life Poster Join Date: Mar 2006 Location: in my h.d.d
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | E1150 unlock succes Selected model: E1150 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 54 Sending loader2... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 41 second, sw ver: 3.4.0066 |
The Following User Says Thank You to algeriano_19 For This Useful Post: |
10-01-2010, 23:50 | #1688 (permalink) |
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | E2120 repaire eeprom ok Selected model: E2120 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Restore EEP - ok Elapsed time: 40 second, sw ver: 3.4.0066 |
10-01-2010, 23:51 | #1689 (permalink) |
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | E2120 repuild imei ok Selected model: E2120 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Sending loader1... OK Flash ID: 08 Sending loader2... OK Repair IMEI block Repair IMEI block Repair - ok Elapsed time: 50 second, sw ver: 3.4.0066 |
10-01-2010, 23:53 | #1690 (permalink) |
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | G600 repaire eep ok elected model: G600 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press shortly power button Phone Detected Sending loader1... OK ARM version 3541 Sending loader2... OK Flash ID: 00EC2206000100000034 Restore EEP - ok Elapsed time: 87 second, sw ver: 3.4.0066 |
10-01-2010, 23:53 | #1691 (permalink) |
Member: 252178 Status: Offline Sonork: 100.1582561 Thanks Meter: 123 | G600 repuild imie ok Selected model: G600 Selected com port: COM5 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use manual parameters Phone in TAT MODE Phone IMEI: 00000000000000 Phone SW: G600XAGJ1 Phone BT ADDR: 001D-25-99B30C Phone SN: R7UP906668 Deactivated MSL - TRUE Write imei - ok Repair - ok Elapsed time: 21 second, sw ver: 3.4.0066 |
10-02-2010, 07:13 | #1694 (permalink) |
No Life Poster Join Date: Dec 2005
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | Selected model: S3650 Selected com port: COM14 Selected speed port: 921600 Phone must be ON Search modem ... OK Search modem on:COM16 Model: GT-S3650 CountryCode: OPENاâ Factory SW: S3650XXXII4 UniqueNumber: 74380000959117 MemoryPhone: K522H1HACC(S3650) Phone IMEI: 35488103100767 /2 Phone S/N: R9YS910404 Phone Bluetooth ID: 60 D0 A9 06 A7 78 Phone SW: S3650XXII4 Phone HW: MP 0.600 Phone CalData ver: 20090915 Detecting UART port..... OK Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:81751642 [NET LOCK]:00000000 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 Decrypted time: 86 sec Elapsed time: 102 second, sw ver: 3.4.0062 ------------------------------------------------------------------------------- |
The Following User Says Thank You to abdulwajid147 For This Useful Post: |
10-02-2010, 07:43 | #1695 (permalink) |
Member: 213172 Status: Offline Sonork: 1582799 Thanks Meter: 265 | Model: GT-S5230 CountryCode: TMP Factory SW: S5230AAIF1 UniqueNumber: 55280000580517 MemoryPhone: K522H1HACA(S5230) Phone IMEI: 35795303290611 /6 Phone S/N: RPFSB11554 Phone Bluetooth ID: C8 7E 75 1F B7 2B Phone SW: S5230AAIF1 Phone HW: MP 0.610 Phone CalData ver: 20091108 Detecting UART port..... OK Calculating security.... OK Please wait decrypt code ... OK [FREZEE]:69791742 [NET LOCK]:37071962 [Subset LOCK]:00000000 [SP LOCK]:00000000 [CP LOCK]:00000000 Decrypted time: 77 sec Elapsed time: 93 second, sw ver: 3.4.0062 ------------------------------------------------------------------------------- |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
